Wireless
8787 Discussions
BT-22.170.0 update caused Bluescreen during installation
Hannes_R
I just wanted to report my experience on the BT-22.170.0-32 update from BT-22.160.
Immediately after starting the actual installation the Kernel Time CPU utilization rose to 100 % (red line in Process Explorer) and the system did not react anymore. Every few minutes I saw a message that a program is not responding anymore, while the system time seemed frozen as well. After 15 minutes of waiting the system finally ended in an BSOD.
The installation worked after the following boot.
I had previously installed the WiFi-22.170.0 Update and VirtualBox 7.0.0 + a Linux VM were running. No Bluetooth device was connected, neither was Wireless turned on.
Win 11 22H2 Build 521
Intel Wi-Fi 6 AX201 160MHz
101122-15593-01.dmp 11.10.2022 23:06:24 DRIVER_POWER_STATE_FAILURE 0x0000009f 00000000`00000003 ffffa385`8885a670 fffff804`2dae6b68 ffffa385`a08b89e0 ntoskrnl.exe ntoskrnl.exe+420fb0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 10.0.22621.521 (WinBuild.160101.0800) x64 ntoskrnl.exe+420fb0 C:\WINDOWS\Minidump\101122-15593-01.dmp 8 15 22621 5 984 903 11.10.2022 23:07:49
