Wireless
8664 Discussions
BT5 Long Range and Extended Advertising
Matthias_V_Intel
Which Intel wireless network solutions support BT5 Long Range and Extended Advertising?
Alberto_R_Intel
MVysh, Thank you for posting in the Intel® Communities Support.
In reference to your question, in the following link you will find the Intel® Wireless cards that support Bluetooth® 5:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=99446,125192,125193,99445,130293,189347
In the picture below you will see the specifications for the Bluetooth® 5 feature, it complies with the Bluetooth® 5 standards, you can confirm that information in the link above under the "Product Brief" section for each Intel® Wireless card:
Just to confirm, could you please explain what are you referring to with "Extended Advertising"?
Alberto R.
A Contingent Worker at Intel
Matthias_V_Intel
I need a BT5 (transmitter) with the following features: 1. 2MBps (2x speed) mode 2. Coded Phy with Long Range Modes (such as 128kbps) 3. Advertising Extensions (sometimes also called Extended Advertising) which is a technique uses all 40 channels for advertising instead of just 3.
Alberto_R_Intel
Hello MVysh, Thank you very much for sharing those details.
In order to better assist you with this topic, we just wanted to confirm a few details:
Is there any specific reason why you need an Intel® Wireless card with those features?
Are you a developer?
Are you working on a project?
If you do, what is the project about?
Alberto R.
Matthias_V_Intel
Hi Alberto, I am looking for a BT module that is able to support the RemoteID requirements for Drones in the US and EU. Best Matthias
Alberto_R_Intel
Hi MVysh, Thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Alberto R.
Alberto_R_Intel
Hello MVysh, I just received an update on this matter.
In reference to your question, the three requested features listed below are supported by the following Intel® Wireless adapters with declared Bluetooth 5.0 support:
List of features requested:
Advertising Extensions (sometimes also called Extended Advertising) which is a technique uses all 40 channels for advertising instead of just three."
Alberto R.
Alberto_R_Intel
Hello MVysh, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
Alberto_R_Intel
Hello MVysh, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
