Wireless
8527 Discussions
Blue Screen of Death
kefrin
Hello Forum, I have had an ongoing problem with my computer shutting down, showing the BSD and restarting by itself. It happens after waking up from sleep state and it happens OFTEN. I have been on the Window's 10 Forum several times. Ran CHKDSK and other suggestions. Uploaded Minidump files and System Information (attached below) and was told on THREE occassions that it is the Intel Wireless driver that is causing the crash. Updated the driver AND BIOS (the driver twice). And its still happening. Any thoughts? Help! (ooops...the dmp files were not accepted and the .nfo format for the sysinfo file was not accepted. ) Here is a screenshot of setup.
AlHill
Insure there is adequat airflow for your device.
Clean you heatsink with compressed air.
Make sure your fans are working.
Redo your thermal paste.
Check for memory failures.
Doc
