Wireless
8575 Discussions
Bluetooth/BLE wakeup from sleep
FlyBoyBart
I'm working on a project that requires the board (an iMX8MM - with an AX200 Intel Wireless Wi-Fi/BT card) to be able to sleep for a very long time while powered on battery.  With very long, I mean weeks to months.  The OS I'm using is Linux, our own build/maintained distribution, using Buildroot.
I managed to wakeup the board via Wi-Fi, using the WAKE hardware signal available on the AX200.  In sleep mode the AX200 still consumes about 600 milli-watt which gives me a max sleep period of 3 days - not enough :(.
But what about Bluetooth wakeup?  I read that Bluetooth wakeup is very power consuming, but I know IoT devices, using BLE, power up for a second to see if someone is waking up the device.  If no wake-signal has been detected, the device goes into sleep again for a few seconds.  During this deep sleep, the BLE device consumes very little (a few milliwatt) as its CPU is put into deep sleep and the RX hardware powered OFF.  Is this behaviour possible on the AX200 as well?
If yes, how to configure this?
BartT
DeividA_Intel
Hello FlyBoyBart,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html
2. If the tool does not work, provide the motherboard band and model names as well as the BIOS version, the wireless adapter driver version.
3. Can you share more details about your project?
4. Can you share any like from the place you read about the Bluetooth Wake-up feature?
5. Are you having issues with the Wake-up feature? Or do you want to change the power consumption features for the device?
Deivid A.
FlyBoyBart
Hi Deivid,
let me answer your questions:
  1. We are using a custom board with a custom distribution.  The Intel Support Utility is not included. The board we are using is a Compulab UCM-IMX8M Evaluation board.  The CPU is an iMX8M-Mini.  The Wireless card is the AX200 module.  Details are in the attached picture.
  2. As mentioned in 1, it no standard motherboard, it is the Compulab UCM-IMX8M Evaluation board.  The OS Linux, kernel version 5.4.24, the Wireless driver in the iwlwifi backport, version core62.
  3. Sorry, other then the info already provided, I cannot share.
  4. https://community.intel.com/t5/Intel-NUCs/Wake-on-Bluetooth-after-sleep/td-p/581792
  5. The main goal is to reduce power consumption of the board, specially in suspend to ram mode, with a wireless wakeup capability enabled.
DeividA_Intel
Hello FlyBoyBart,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello FlyBoyBart,
I would like to let you know that we have a specific forum for this kind of issue, it is called the Intel Developer Zone. There you will receive the appropriate support on this and other concerns you may have related to this product.
Here you will find the links to access the website and the community forums:
- https://software.intel.com/content/www/us/en/develop/home.html
- https://community.intel.com/t5/Software/ct-p/software-products
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
FooF
Over three years after the original question, I encountered the same issue with my Gigabyte Ryzen 7 4800u based mini PC with Intel Corp. AX200 Bluetooth (this I can tell because `lsusb` output), running Ubuntu 24.04 Linux.
After the computer wakes up from sleep there is no trace of Bluetooth, though the associated kernel modules were still loaded. I fixed the problem by simply unloading  and reloading the related kernel modules:
$ sudo rmmod btusb btintel
$ sudo modprobe btusb btintel
I found the kernel modules by grepping `lsmod` output for `bluetooth` and found `btintel` which could not be removed alone, hence the two modules above. This solved the problem for me. I have this now scripted in case I wish to use Bluetooth after waking up. Maybe there is a way to automatically do this after waking up, but this is good enough for me now.
FooF
Sorry for noise, I think I did not initially read the original question very well. This was the top results for my Google search before I found a way to reactivate the bluetooth after sleep, so wished to share the obvious solution to this much simpler problem, and I cannot delete the already written answer... ;-(
