Wireless
8515 Discussions
Bluetooth Driver 22.220.1.1 Makes Logitech MX Keys and MX Anywhere Non-Functional
echriste
After installing Intel® Wireless Bluetooth® for Windows® 10 and Windows 11 version 22.220.1.1, both my Logitech Bluetooth devices (MX Keys and MX Anywhere) stopped functioning. I rolled back the driver to version 22.170.0.2 and both devices were functioning. Just to make sure, I repeated these installing and rolling back procedures and the same results occurred.
Carlos_L_Intel
Hi @echriste
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
  • To get more information from your system, please install the Intel® System Support Utility (Intel® SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
Carlos L.
echriste
Carlos L,
Attached here is the result from the procedures you described.
Eric
Carlos_L_Intel
Hi @echriste
Thank you for the information in this case since this is a laptop we recommend using the manufacture's drivers to ensure compatibility, you can find them here (https://dl.dell.com/FOLDER08979300M/6/Killer-1690-1675-1650-Wi-Fi-Controller-Driver_XWCCG_WIN_3.1222.7103_A32_02.EXE) the ones you were installing are what we call generic drivers, we offer these drivers to all computer manufacturer, and they usually modify them to ensure compatibility with your system.
Let me know if these drivers work for you.
Carlos L.
echriste
When trying to install the Dell Killer driver that you suggested, I got an error that says I have a more recent driver and this installation failed.
However, I don't see why this driver has anything to do my Bluetooth problems. Since I have rolled back the Intel Bluetooth driver to version 22.170.0.2 and both my MX Keys and MX Anywhere work, this apparently is my solution.
Eric
Carlos_L_Intel
Hi @echriste
 Thank you for the update. It is very likely that Windows updates already provided the latest recommended driver for your pc that is why you got the error, so I would be a good idea to only use the drivers provided by the manufacturer in your case. Are there any other questions that I can help with?
Carlos L.
Carlos_L_Intel
Hi @echriste
Were you able to check the previous post? Let us know if you still need assistance.
Carlos L.
Jean_Intel
Hello echriste,
We hope you are doing fine.
Best regards.
Jean O.
