hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Wireless
8243 Discussions
Bluetooth Headphones no longer connect
Thomas64
Débutant
212 Visites
Hallo,
i have some bluetooth-headphones and they have worked fine on my Windows 10 System. Since an update in late august or early september i was not longer able to connect the headphones with the PC.
It was not sure whether a Windows update or a driver update was the reason for the changes. After a longer session with the Microsoft-support and some "repair"-processes, it seems, that the BT-driver is the reason.
Unfortunately, Windows doesn't allow me to go back to a state before the update.
Problem description:
If I bring the headphones in pairing mode the PC recognizes the headphones an starts to connect them (Message left). After some minutes the message changes to "... not able to connect" (Message right).
Message1.pngMessage2Message2
When I look in Computer Management under "Windows System Logs," I see an error message: "Mutual authentication between the local Bluetooth adapter and a device with Bluetooth adapter address (18:4e:16:e1:01:d6) failed.":
I think that is exactly the cause of the connection failures.
Despite many attempts of uninstalling and reinstalling drivers and deleting and including devices, I have not been able to resolve this error.
There are also no abnormalities in the device manager:Devices.png
Does anyone know what this error is and how to resolve it? I'm grateful for any help.
Thomas
0 Compliments
5 Réponses
Mike_Intel
Modérateur
158 Visites
Hello Thomas64,
  1. What is the complete model of your wireless controller?
  2. What is the complete brand and model of your system?
  3. Can your other Bluetooth Device still connect to your system?
  4. Have you also tried to connect your Headphone on a different system?
Michael L.
0 Compliments
Thomas64
Débutant
79 Visites
Hello Mike,
I hope I can answer your questions.
    I am not sure, which information you need. I have found "Intel Wifi 6E Ax210":
    A windows 10 Pro-System: Model.png
    Yes. I have a robotic lawnmower and a smart tv which i can control via bluetooth without any problem.
    Yes, I can connect both headphones I tested to my phone without any problems.
Until last august/september the connection to my headhones works fine.
Thanks for your help and best wishes,
Thomas
0 Compliments
Mike_Intel
Modérateur
113 Visites
Hello Thomas64,
Michael L.
0 Compliments
Mike_Intel
Modérateur
42 Visites
Hello Thomas64,
Thank you for the update.
If the other Bluetooth device can connect to your system, that means it is working properly.
However, let me gather more details for me to provide some recommendations.
  1. What is the brand and model of your laptop?
  2. Please help generate the SSU logs of your system. Kindly refer to the link below for the steps on how to generate the logs:
Michael L.
0 Compliments
Thomas64
Débutant
10 Visites
Hallo Michael,
it is not a Laptop, it is a workstation with a main board from Asus. I think you will find the informations you need in the Log-file.
I agree that the blutooth hardware works fine. The problem seems to be a "protocol" issue. With the update in august/september security-relevant things may have been changed that now require a different pairing procedure (how I interpret the error message).
Attached is the log file from the SSU tool. I hope it provides some clues to the problem.
Best regards and thanks a lot for your help.
Thomas
0 Compliments
Répondre
