- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
This bug happened when I was using my Galaxy Book 5 pro and S25+ phone, and S9 Ultra tablet. and when autoswitch happened(or manual) from phone -> laptop or tablet -> laptop BT connection did happen but sound never cameout.
Notification: This report is made by help of the ai because I am not that good at English.
Hello, I am reporting a critical compatibility bug and bandwidth throttling issue introduced in the latest Intel Wireless Bluetooth Driver (v24.20.0.3). When using multipoint Bluetooth connections (specifically Samsung Galaxy Buds2 Pro with 'Auto Switch' feature enabled across PC, Tablet, and Phone), the v24.20.0.3 driver causes a complete audio routing failure and A/V sync deadlock on Windows 11.
System Environment:
OS: Windows 11
Device: Samsung Galaxy Buds2 Pro
Trigger Condition: Samsung "Auto Switch" (Continuity Service) active across multiple devices (May related to Heavy Bluetooth LE background pinging).
Symptoms (with v24.20.0.3):
Audio Drop & Deadlock: Windows claims the Bluetooth device is connected, but no sound is outputted.
Browser Pipeline Destroyed: Chromium-based browsers (Chrome/Edge) suffer infinite buffering on YouTube. The browser's Media Internals show
State: Destroyedand missing audio decoders due to the driver failing to establish an audio channel (A2DP).No Windows Event Logs: Windows Event Viewer shows no crashes (
BTHUSBorAudiosrv), indicating a logical bandwidth/protocol denial rather than a service crash.
Resolution / Workaround:
Rolling back the Intel Bluetooth Driver to v23.140.0.5 completely resolves all issues.
It appears the newer 24.x driver handles LE bandwidth or multipoint polling too aggressively, choking the audio channel when the Samsung ecosystem sends background continuity pings.
Please investigate the Bluetooth LE bandwidth management in the 24.x driver series regarding high-frequency background polling from multipoint devices.
Link copiado
- « Anterior
- 1
- 2
- Próximo »
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Chawan_Intel,
Thank you for the detailed troubleshooting steps. I am writing to provide an interim update on my progress.
1. Results of Step 1 (Disable ISST): I completely disabled all ISST-related devices in the Device Manager, while keeping the latest Bluetooth and Wi-Fi drivers (24.30.1.1) installed. To ensure accurate results, I performed multiple tests, including putting the laptop into a deep sleep state for extended periods.
Result: Surprisingly, the issue did NOT occur. The system woke up perfectly every time, with no freezing and sound came out perfectly fine. This may indicates that the conflict lies in how the ISST module interacts with the system's sleep states on the 24.x driver branch.
But something even strange happened. I enabled the ISST again and the issue did NOT occur too. I did not think this to be happen. And I can assure that this same problem did happened in 24.30.1.1 Bluetooth drivers. Because I can remember when after a windows update I got the 24.30.1.1 driver and problem happened so I had to downgrade to the drivers i had before.
I can't think of any reasonable explanation of what I got from step1. So I am just gonna tell you the exact result, which is above, so you guys can possibly think of what happened. If you need some more information or new tests related to step1 result, please let me know, I am glad to help.
2. Roadblock with Step 2 (Rollback): I attempted to proceed with Step 2. While I could update the Wi-Fi driver, I am unable to install the older Bluetooth driver (version 24.10.0) you provided. The installer is blocked because a newer version is already installed on my system.
I prefer not to forcibly modify the deep Windows driver repository or use command-line uninstallation tools, as I want to avoid potential registry corruption or system instability. Therefore, I have paused the testing at this stage.
Could you please share this significant Step 1 result with your engineering team? Also, please let me know if this data is sufficient for now, or if you have a safe, official method to bypass the downgrade protection for the Bluetooth driver.
Lostinspace.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Lostinspace,
Thank you so much for your patience and for diligently following the recommendations we provided — we truly appreciate your efforts and cooperation.
We wanted to reach out and let you know that we have received your query and are currently looking into it. We kindly ask for a little more time to thoroughly review it and provide you with the most accurate and helpful response possible.
We understand how important this matter is to you, and we want to assure you that it has our full attention. We will get back to you as soon as possible with an update.
Thank you again for your understanding — we're here for you every step of the way.
Tharun
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Lostinspace,
Thank you for taking the time to share such a detailed and well-documented update. I truly appreciate the effort you’ve put into testing this thoroughly and providing clear observations.
We will share these findings with our higher engineering team for further analysis and review.
In the meantime, could you please confirm if the issue is currently resolved after your testing? Have you been able to monitor the system further, and does the issue still persist or occur intermittently?
If the issue is no longer occurring and the system is stable, kindly let us know so we can proceed with closing the case accordingly. However, if the issue persists, we will continue assisting you with further troubleshooting steps.
Looking forward to your update.
Chawan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Lostinspace,
Thank you for your patience.
As there has been no further update after multiple follow-ups, and based on the current information provided, we will proceed with closing this thread for now.
If the issue reoccurs or you need any further assistance in the future, please feel free to open a new support thread, and we will be happy to assist you further.
Chawan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Chawan,
Sorry for being late. First of all, I want to express my sincere gratitude to you and the engineering team. Thank you for your continued support, the detailed troubleshooting steps, and your genuine effort to resolve this issue with me.
Since our last communication, I noticed that a new driver version was released. I have updated my system to this latest version and have been carefully monitoring its behavior during deep sleep states.
Surprisingly, the issue has not reoccurred. While I cannot completely pinpoint the exact root cause of the sudden fix—whether it was the physical toggling of the ISST module that cleared a power-state bug, or a silent fix within the newest driver update—the system currently appears to be highly stable without any freezing or battery drain.
To be absolutely certain and ensure data integrity, I would like to monitor the system for one more week. If no further issues arise during this observation period, I believe we can safely conclude that the problem is resolved and officially close this case.
I will send you a final confirmation email next week. Thank you again for your outstanding support.
Lostinspace
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
- « Anterior
- 1
- 2
- Próximo »
