Wireless
8871 Discussions
Centrino Advanced N6235 bluetooth receive fail
EAdam3
I ve installed 6235 to my notebook, everything is fine, but only my bluetooth cannot receive file from my phone, how can i do it? one more thing, it CAN send files to my phone though bluetooth.
Jose_H_Intel1
This is by-design behavior. You may try sending multiple files at once.
Muthu_K_Intel
Do you see "Receive a File' option if you click on the BT icon on the sys tray? It must be open before the remote device is sending the file to your system.
EAdam3
yes, but after click-in, the "bluetooth file transfer" comes out, and showing "waiting for a connection" but i can't click "next", and meanwhile the PC setting show i m connected my phone!
Jose_H_Intel1
I did not see such option but I was able to transfer a couple of audio files from my phone. After sending the request from the phone I have got a "Receiving files" pop up window with the folder and device (phone) information; at the bottom I had "Accept" and "Reject" buttons.
Genie@@, please indicate what operating system, Intel® WiFi and Bluetooth* driver versions you have.
EAdam3
Windows 8 before, and now 8.1 also got the same, wifi ver.:15.10.3.2, BT: 3.0.24.40063
EAdam3
aha, the problem is solved, I had clicked on bluetooth button and press receive file, then, it started to receive my file from my phone. Thanks for your reply Joe
EAdam3
but the thing is that i need to press "receive file" in the bluetooth every time before i start to send file from phone, it's so stupid.
EAdam3
and now i have another problem, the wifi signal sometimes dropdown to only 2 or no signal, do i need to return it to your office for replacement?
Jose_H_Intel1
That is a different issue and we would like to maintain the discussion within the original subject.
Wireless signal could be affected by distance and objects like walls and other radio emitters between the computer and the access point. If that is not the case please contact your system manufacturer for assistance.
EAdam3
ok back to the main topic, I need to press in the bluetooth button and choose "receive file" every times, that i can send my medias from my phone, Is it too stupid?
Jose_H_Intel1
EAdam3
Aha, it's work, and the latest upload is more friendly, Thz
