Wireless
8532 Discussions
Changing AX200 settings in Device Manager destroys BCD
dfm0
I have an AX200 in a Dell laptop with Windows 10 Pro and twice I changed it's settings in Device Manager then attempted to restart and it ruined the BCD and wouldn't boot. The first time I just cloned disk to get it back up. The second time I checked the BCD and it was nowhere to be found so I put a drive letter to the boot partition then was able to let Bootice repair it.
I booted to Hiren's PE to do the repairs.
Is it normal that the BCD would be destroyed by changing settings?
Is there a fix for it?
Steven_Intel
Hello dfm0,
I am sorry you are having issues with your Intel® Wi-Fi 6 AX200 (Gig+), I will be glad to assist you.
Please provide the following information:
  • Is this the original wireless adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • When did the issue start to happen? Were you able to change the wireless settings in the past without any issues?
  • What are the wireless settings you are specifically modifying in Device Manager?
Steven G.
dfm0
The original pre-installed adapter was 802.11n.
I have had the AX200 for about a year and didn't change the settings until a few days ago.
I changed FatChannelIntolerant from disabled to enabled, RoamAggressiveness to lowest, RoamingPreferredBandType to 5GHz band, ThroughputBoosterEnabled to Enabled.
Steven_Intel
Many thanks for your detailed response.
Since you have installed the wireless adapter to your device, take a look at the Regulatory Information Regarding Wireless Hardware Installation or Upgrade (https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html)
As well, please update your wireless card driver (https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html), BIOS and operating system to the latest version and then download the Intel® SSU (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
dfm0
Attached is the SSU report.
Steven_Intel
Many thanks for your response.
I will work on this issue and as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello dfm0,
Thank you for your patience on this matter.
Since this issue is related to booting, and besides the wireless card was integrated in the system, our best recommendation is to contact the Original Equipment Manufacturer (OEM) for further assistance.
Steven G.
dfm0
