Wireless
8782 Discussions
Intel AX200 160mhz 5ghz non-functional
LukeJ
I've been trying to get this to work for a few hours now, trying to connect with 5ghz is completely nonfunctional. The device works fine using 2.4 ghz but not with 5g. I have already tried to do a clean reinstall of drivers with no help. Setting this to 20mhz does work but is not realistic as it lowers speeds to that of 2.4ghz.
Jean_Intel
Hello LukeJ,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with the Intel AX200.
  • Were you able to have your wireless connection in a normal/expected performance before?
  • Do you remember if this issue happened after a new Operating System update or Wireless driver update?
  • Is this a laptop or desktop system?
  • What Operating System version are you using?
  • Have you checked if this issue happens on different networks?
  • Have tried a rollback to a previous driver version for testing?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Jean O.
Jean_Intel
Hello LukeJ,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello LukeJ,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
