Wireless
7459 Discussions
Compatible ??? - Wifi card Intel AX201 compatible with mainboard Gigabyte B360M Aorus Gaming 3 & CPU chipset core i5 8400 ???
DTa001
My PC have motherboard Gigabyte B360M Aorus Gaming 3 with chipset CPU Intel Core i5 8400, BIOS version F13, so is it compatible with Wifi card Intel AX201 ? ( Mainboard have port M.2 type E + CNVi )
Is this card works with my PC ?
Link Motherboard: https://www.gigabyte.com/us/Motherboard/B360M-AORUS-GAMING-3-rev-10#kf
DTa001
Hi guys,
Gigabyte technical confirmed it's not support.
For people that confuse as me about AX201.
Thanks. Close case.
AlHill
You should ask gigabyte what cards are compatible with their board. They would have (should have) done the testing.
Doc
LeonWaksman
Though you can insert AX201 into a standard M.2 Key E socket, contact Gigabyte to verify compatibility.
Leon
DTa001
Hi guys,
Thanks. Close case.
LeonWaksman
  1. Thank you for your update.
  2. And I would add that information provided on this page is not correct: https://www.intel.com/content/www/us/en/support/articles/000026155/network-and-i-o/wireless-networking.html. The AX201 has System Interface TypeM.2: CNVio2 wich is not backwards compatible to System Interface TypeM.2: CNVio? I would like to see answer fro this.
Leon
DTa001
Hi LWAKSMAN,
As my searching in few last days, That link which is meaning Intel called CNVi in general ( inclued CNVio & CNVio2 )
  1. About CNVio:
CNVio support 8th 9th CPUs & early + Mainboard 300 series ----> AC9560
CNVio2 support only for 10th CPUs & later + Mainboard 400 series ----> AX201
2. About System interface type:
M.2: AC9560 & AX201 use same port but depending on CPU & mainboard as upper.
PCIe: AC9260 & AX200 ( PC need PCIe1x adapter )
Hope I correct ^.^ LOL
LeonWaksman
I would like to see Intel document specifying the requirement relating cnvio2 and cnvio compatibility with CPU and Chipset (i.e your statement in 1 above). Did you see one?
Leon
AdrianM_Intel
Hello all,
Thank you for your input.
We are glad to know that the OEM (Original Equipment Manufacturer) was able to advise you on the Intel® Wi-Fi 6 AX201 compatibility with the motherboard Gigabyte B360M Aorus Gaming 3.
LWAKSMAN
Since the original question was already resolved, we recommend that you create a new question. We will be glad to help you.
Adrian M.
A Contingent Worker at Intel
