Le Nokia Purebook Fold 14 a été vendu en France il y a deux ans. Sur mise à jour, il perd de temps à autre l’initialisation de Intel® Wireless-AC 9461 .
Où rechercher pilote ou gestionnaire de périphérique ?
Comment réactiver le pilote ?
Hello ALANCHIC,
Veuillez noter que je ne peux vous aider qu’en anglais. J’ai utilisé un outil de traduction Web pour traduire cette réponse, il peut donc y avoir des traductions inexactes. Par la suite, je vous répondrai en anglais.
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information below:
1) Please confirm which of these models is your exact system device?
2) Please provide a screenshot of the status of your wireless adapter from the device manager. From the Windows start search, look for the device manager, then click the ">" beside network adapter and right-click Intel® Wireless-AC 9461 then select properties.
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save. *Attach the SSU log file as you reply.
I hope to hear from you soon.
JeanetteC.
Merci pour proposition pour votre aide proposée, mais le PBF141-009 ne boot plus, ou n’accroche plus la synchro de 60 hz. Problème de faiblesse générale. Je vais réaliser et tenter reset usine
Hello ALANCHIC,
I understand that your Nokia PureBook Fold 14 (PBF141-009) no longer boots and no longer connects wirelessly. Since you want to proceed with a factory reset, I strongly suggest reaching out to your system manufacturer support team to get further assistance.
I will go ahead and close this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
