I recently installed the latest Intel Killer Performance Suite
(Version: 40.25.509.1465 Release date: May 26, 2025),
but Intel® Driver & Support Assistant Webpage says that the update is still available. I rebooted the computer and then refreshed the page, but it still offers the update. I even tried completely removing the Intel Killer Performance Suite, rebooted, then reinstalled the latest version. Still, the Intel® Driver & Support Assistant Webpage says that the update is still available. Would you please look into this issue, and fix the Intel® Driver & Support Assistant Webpage?
Ed Ouellette
<email removed>
The memory leak persists and requires further debugging.
Hello 2Torr,
- What is the model of your wireless controller?
- Aside from the update prompt, are you also having issues with the wireless connection?
- Can you send a screenshot of the error?
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Hi Mike,
Thanks for your fast reply.
1.
A. Wi-Fi adapter: Intel Wi-Fi 6E AX411 160 MHz
B. Ethernet adapter: Killer E3100G 2.5 Gigabit Ethernet Controller
2. No other issues with wireless connection
3. There is no error, only unjustified update prompt.
Thanks!
Hello 2Torr,
Thank you for the update.
Can you try to manually download and install the version 40.25.509.1465. Kindly refer to the link below to manually download the driver:
https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html
Michael L.
Hi Mike,
Thanks for your reply.
I already tried installing the driver manually, and it didn't help.
Hello 2Torr,
I appreciate your effort for trying the recommendation. Could you please share a screenshot or photo of what you are seeing on your end? Have you also had the chance to reinstall the Intel Driver & Support Assistant?
Best regards
Jed G.
Hi Jed,
Thanks for your message.
I've attached a screenshot showing the status of Intel DSA after installing the latest update to Killer Performance Suite 40.25.509.145 and rebooting.
Notice that it shows that the update is still available (not installed) when it actually is already installed. See second Installed Apps screenshot.
Next, I uninstalled and reinstalled the latest version of Intel DSA.
The results were the same. Intel DSA stills shows that the Killer Performance Suite 40.25.509.145 update is still available (not installed) when it actually is already installed.
Hello 2Torr,
If that is the case, the issue now is with IDSA. Since this is web based, there are a lot of factors for it to have issues.
You may re-install the IDSA by following the steps in the link below:
Intel® Driver & Support Assistant (Intel® DSA) Results in “Sorry,...
Michael L.
Hi Mike,
Thanks for your message. I've tried uninstalling and reinstalling Intel DSA with no improvements.
DSA does detect when other driver updates are available. When I install them, the notices go away, as they should.
However, for some reason, this is not happening with the one driver: Killer Performance Suite.
I believe this driver is for my ethernet controller. Is it possible that the latest version of Killer Performance Suite no longer supports my hardware? What would happen in that case?
Thanks!
Hello 2Torr,
If you already have the latest driver, that means there should be no more issues.
The problem is just the detection of the IDSA and since this is web based, there are a lot of factors that can affect this app.
And also, Ethernet cards can be an OEM unit too, they are possibly modified by other makers.
Michael L.
Hello 2Torr,
Michael L.
<< The problem is just the detection of the IDSA and since this is web based, there are a lot of factors that can affect this app.
OK, thanks. What comes next? Any estimates on when this issue will be fixed?
As I mentioned earlier this issue only seems to be affecting the Intel Killer Performance Suite drivers.
Do I need to report this issue to another team that handles the IDSA web interface?
Hello 2Torr,
Let me further check this issue. To that, let me request for the SSU logs of your system form me to check and review the hardware and the installed drivers. Kindly refer to the link below on how to generate the logs:
Thanks for the assistance.
Michael L.
Hello 2Torr,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Hello 2Torr,
I sent an email in the email address associated with your profile, please check your inbox.
Michael L.
Hi Mike,
