Wireless
8508 Discussions
De-authentication sent from client - Unspecified failure - Intel AC5960
dc24
I am working in an enterprise WLAN environment (Aruba AP-635, ArubaOS10, Aruba Central).
We are regularly seeing event logs in Aruba Central with the error 'De-authentication sent from client - unspecified failure'. When this is experienced the client is disconnected from the network, and in some cases, unable to join back for a period of time.
The client is a Windows 10 laptop using the Intel AC5960, driver release 23.90.0.2. On another machine, Windows 10 using the Intel AX201, driver release 23.90.0.2 we do not see this error.
The WLAN that the clients are connecting to are 5/6Ghz, running with 40Mhz wide channels. They are supporting 802.11a/b/g/n/ac/ax.
There is no pattern or event that occurs before this happens, it is simply random.
I have seen older posts from several years back, suggesting running 20Mhz wide channels, but this cannot be the fix for an 802.11ac adapter.
Are there any logs on the client I can check within the Event Viewer or elsewhere in the operating system?
We do not see the problem with Apple, Android or other Windows devices running different WLAN NICs.
Appreciate any support / advice that can be offered.
NormanS_Intel
Hello dc24,
Thank you for posting in the community!
To assist us in further investigating the issue, could you please provide answers to the following questions:
  1. Is the issue occurring only when connecting to Aruba?
  2. Have you tried using a different access point (AP)?
  3. How many units are affected by this issue?
For troubleshooting steps, you may refer to our article "Intel® Wireless Adapter Keeps Disconnecting from the Network." Additionally, you can download the latest wireless driver version 23.100.0 from this link: https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Norman S.
NormanS_Intel
Hello dc24,
Could you please confirm if you have reviewed the information I posted? Your feedback at your earliest convenience would be greatly appreciated so we can decide on the best way to proceed with resolving this matter.
Norman S.
NormanS_Intel
Hello dc24,
I have not received a response from you, so I will close this inquiry. If you require further assistance, please submit a new question, as this thread will no longer be monitored.
Norman S.
