Wireless
8718 Discussions
Dell Latitude 5440 13th gen not install wifi in Ubuntu
VanHungNguyen
When I install the Ubuntu22.04 on Dell Latitude 5440 13th gen machine then the Intel AX211 wireless card can't work on it. What should I do next? Thanks a lot!
AlfredoS_Intel
Hi VanHungNguyen,
It must be confounding to install a Linux Operating System and finding out that the wireless function is not working.
We would need the following information from you, so we can provide you viable suggestions:
- Do you know the kernel version that your Ubuntu 22.04 installation is using?
- Do you get an error message in dmesg regarding the wireless?
- What steps have you attempted so far? Knowing this will make us avoid repeat suggestions.
- It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page, https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html
You can view the instructions on how to run this application on the readme file included on the download.
The steps below are from the readme file:
How to run ssu.sh from the terminal
1. Open Applications -> Accessories -> Terminal
2. From the current director, navigate to the current folder where the ssu.sh file resides. For example if you saved the ssu.sh to a folder called "SSU File" the command would be: cd "SSU File"
3. Run the ssu.sh file using this command: ./ssu.sh <parameter=0|1>  where 0 = off and 1 = enabled
4. Use the parameter definitions included in the readme to determine which parameter to use.
5. If no parameter is specified and only ./ssu.sh is run, it will capture all system information with the exception of 3rd party logs which must be specified. If no output file is specified, the SSU will write the output to file <sytemname>.txt.
Alfred S
VanHungNguyen
1. uname -r
6.9.1-060901-generic
2.
sudo dmesg |grep iwlwifi
[sudo] password for vanhungnguyen:
[ 7.861065] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 8.064417] iwlwifi 0000:00:14.3: CSR_RESET = 0x11
[ 8.064430] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x0
[ 8.064481] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 8.064486] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 8.064560] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 8.064629] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 8.064701] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 8.064761] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 8.064814] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 8.064820] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 8.064824] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 8.064892] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 8.064958] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 8.065021] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 8.065027] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 8.065099] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 8.065165] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 8.065168] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x1
[ 8.065232] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 8.065285] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 8.065288] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 8.065291] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 8.065295] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 8.065355] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 8.065358] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 8.065361] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 8.065422] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 8.065425] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 8.065429] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 8.065488] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 8.065499] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 8.065556] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 8.065559] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 8.065561] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x6
[ 8.065565] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 8.065638] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 8.065707] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 8.065762] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 8.065766] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 8.065825] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 8.065834] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 8.065901] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 8.065904] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 8.065967] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 8.065972] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 8.066032] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 8.066038] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 8.066110] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 8.066165] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 8.066167] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[ 8.066173] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 8.066242] iwlwifi 0000:00:14.3: probe with driver iwlwifi failed with error -110
VanHungNguyen
sudo lshw -c network
*-network:0 UNCLAIMED
description: Network controller
product: Raptor Lake PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: iomemory:600-5ff memory:60531a4000-60531a7fff
*-network:1
description: Ethernet interface
product: Ethernet Connection (23) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 01
serial: ac:1a:3d:33:f7:c3
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.9.1-060901-generic firmware=0.2-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:157 memory:9df00000-9df1ffff
*-network
physical id: 12
bus info: usb@3:4
logical name: enx5a1a8742da50
serial: 5a:1a:87:42:da:50
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=6.9.1-060901-generic duplex=half firmware=RNDIS device ip=192.168.11.103 link=yes multicast=yes port=twisted pair
VanHungNguyen
lspci -nnk
00:00.0 Host bridge [0600]: Intel Corporation Raptor Lake-P/U 2p+8e cores Host Bridge/DRAM Controller [8086:a708] (rev 01)
Subsystem: Dell Device [1028:0c00]
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
00:02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-P [UHD Graphics] [8086:a721] (rev 04)
Kernel driver in use: i915
Kernel modules: i915, xe
00:04.0 Signal processing controller [1180]: Intel Corporation Raptor Lake Dynamic Platform and Thermal Framework Processor Participant [8086:a71d] (rev 01)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
00:06.0 PCI bridge [0604]: Intel Corporation Raptor Lake PCIe 4.0 Graphics Port [8086:a74d] (rev 01)
Kernel driver in use: pcieport
00:07.0 PCI bridge [0604]: Intel Corporation Raptor Lake-P Thunderbolt 4 PCI Express Root Port #0 [8086:a76e] (rev 01)
00:07.1 PCI bridge [0604]: Intel Corporation Device [8086:a73f] (rev 01)
00:08.0 System peripheral [0880]: Intel Corporation GNA Scoring Accelerator module [8086:a74f] (rev 01)
00:0a.0 Signal processing controller [1180]: Intel Corporation Raptor Lake Crashlog and Telemetry [8086:a77d] (rev 01)
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0d.0 USB controller [0c03]: Intel Corporation Raptor Lake-P Thunderbolt 4 USB Controller [8086:a71e] (rev 01)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:0d.2 USB controller [0c03]: Intel Corporation Raptor Lake-P Thunderbolt 4 NHI #0 [8086:a73e] (rev 01)
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
00:12.0 Serial controller [0700]: Intel Corporation Alder Lake-P Integrated Sensor Hub [8086:51fc] (rev 01)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
00:14.0 USB controller [0c03]: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller [8086:51ed] (rev 01)
00:14.2 RAM memory [0500]: Intel Corporation Alder Lake PCH Shared SRAM [8086:51ef] (rev 01)
00:14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz [8086:4090]
Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 [8086:51e8] (rev 01)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 [8086:51e9] (rev 01)
00:16.0 Communication controller [0780]: Intel Corporation Alder Lake PCH HECI Controller [8086:51e0] (rev 01)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:16.3 Serial controller [0700]: Intel Corporation Alder Lake AMT SOL Redirection [8086:51e3] (rev 01)
Kernel driver in use: serial
00:1f.0 ISA bridge [0601]: Intel Corporation Raptor Lake LPC/eSPI Controller [8086:519d] (rev 01)
00:1f.3 Audio device [0403]: Intel Corporation Raptor Lake-P/U/H cAVS [8086:51ca] (rev 01)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
00:1f.4 SMBus [0c05]: Intel Corporation Alder Lake PCH-P SMBus Host Controller [8086:51a3] (rev 01)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Alder Lake-P PCH SPI Controller [8086:51a4] (rev 01)
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (23) I219-LM [8086:0dc5] (rev 01)
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 Non-Volatile memory controller [0108]: KIOXIA Corporation NVMe SSD Controller BG5 (DRAM-less) [1e0f:000c]
Subsystem: KIOXIA Corporation Device [1e0f:0001]
Kernel driver in use: nvme
Kernel modules: nvme
AlfredoS_Intel
Hi Vanhungnguyen,
Thank you for your response.
After checking the information that you shared, it is odd that you are having problems with the WiFi adapter since your Kernel is 6.9, the card is supported on Kernel Version 6.8.  We need your cooperation to run the following commands to determine what are the next suggestions that we will provide you:
Type the following commands on terminal and paste the result:
1. # lspci​ (We need to verify if your wireless adapter is connected properly)
2. # modinfo iwlwifi​ (We need to determine if the proper firmware is installed)
3. # lsmod | grep iwlwifi​
4. # lshw -c
Alfred S
VanHungNguyen
2: modinfo iwlwifi
filename: /lib/modules/6.5.0-35-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-cc-a0-77.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-77.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-77.ucode
firmware: iwlwifi-Qu-b0-jf-b0-77.ucode
firmware: iwlwifi-Qu-c0-hr-b0-77.ucode
firmware: iwlwifi-Qu-b0-hr-b0-77.ucode
firmware: iwlwifi-ma-b0-mr-a0-83.ucode
firmware: iwlwifi-ma-b0-gf4-a0-83.ucode
firmware: iwlwifi-ma-b0-gf-a0-83.ucode
firmware: iwlwifi-ma-b0-hr-b0-83.ucode
firmware: iwlwifi-ma-a0-mr-a0-83.ucode
firmware: iwlwifi-ma-a0-gf4-a0-83.ucode
firmware: iwlwifi-ma-a0-gf-a0-83.ucode
firmware: iwlwifi-ma-a0-hr-b0-83.ucode
firmware: iwlwifi-ty-a0-gf-a0-83.ucode
firmware: iwlwifi-so-a0-gf-a0-83.ucode
firmware: iwlwifi-so-a0-hr-b0-83.ucode
firmware: iwlwifi-so-a0-jf-b0-83.ucode
firmware: iwlwifi-gl-c0-fm-c0-83.ucode
firmware: iwlwifi-gl-b0-fm-b0-83.ucode
firmware: iwlwifi-bz-a0-fm4-b0-83.ucode
firmware: iwlwifi-bz-a0-fm-c0-83.ucode
firmware: iwlwifi-bz-a0-fm-b0-83.ucode
firmware: iwlwifi-bz-a0-gf4-a0-83.ucode
firmware: iwlwifi-bz-a0-gf-a0-83.ucode
firmware: iwlwifi-bz-a0-hr-b0-83.ucode
firmware: iwlwifi-sc-a0-wh-a0-83.ucode
firmware: iwlwifi-sc-a0-gf4-a0-83.ucode
firmware: iwlwifi-sc-a0-gf-a0-83.ucode
firmware: iwlwifi-sc-a0-hr-b0-83.ucode
firmware: iwlwifi-sc-a0-fm-c0-83.ucode
firmware: iwlwifi-sc-a0-fm-b0-83.ucode
srcversion: 21D37308D0CF1B60B5190E1
alias: pci:v00008086d0000E440sv*sd*bc*sc*i*
alias: pci:v00008086d00007740sv*sd*bc*sc*i*
alias: pci:v00008086d0000A840sv*sd*bc*sc*i*
alias: pci:v00008086d0000272Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002727sv*sd*bc*sc*i*
alias: pci:v00008086d00007E40sv*sd*bc*sc*i*
alias: pci:v00008086d00002729sv*sd*bc*sc*i*
alias: pci:v00008086d00007F70sv*sd*bc*sc*i*
alias: pci:v00008086d000054F0sv*sd*bc*sc*i*
alias: pci:v00008086d000051F1sv*sd*bc*sc*i*
alias: pci:v00008086d000051F0sv*sd*bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias: pci:v00008086d00007A70sv*sd*bc*sc*i*
alias: pci:v00008086d00002725sv*sd*bc*sc*i*
alias: pci:v00008086d00002723sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias: pci:v00008086d000043F0sv*sd*bc*sc*i*
alias: pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000034F0sv*sd*bc*sc*i*
alias: pci:v00008086d000006F0sv*sd*bc*sc*i*
alias: pci:v00008086d000002F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000A370sv*sd*bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000031DCsv*sd*bc*sc*i*
alias: pci:v00008086d000030DCsv*sd*bc*sc*i*
alias: pci:v00008086d0000271Csv*sd*bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002526sv*sd*bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias: pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias: pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000526Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias: pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias: pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias: pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias: pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias: pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 6.5.0-35-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 62:0D:BC:92:0F:39:43:69:D0:2E:AB:3B:16:AD:C1:49:64:BF:9B:1E
sig_hashalgo: sha512
signature: B8:93:F2:0E:3D:D1:C7:85:63:0C:18:08:48:2B:2D:16:71:B7:37:0F:
BC:DB:C5:4B:9E:A0:5B:21:BE:46:E7:1B:E3:B0:AA:E7:70:19:98:FA:
59:7E:EB:AE:16:C0:94:63:4E:BB:81:59:16:B0:D3:10:6B:BE:14:E2:
04:01:82:51:CA:E9:A6:C5:91:84:5F:99:4D:C5:0C:EB:97:66:F1:F2:
F3:5D:8D:C4:AA:C8:17:68:81:F2:27:8E:56:49:7B:05:47:89:18:71:
68:31:02:89:E5:2D:E3:04:EB:2B:9C:0A:B3:E4:29:92:54:21:15:E2:
64:0F:6D:F3:EE:08:D8:B6:6A:BC:00:59:9C:AA:D3:74:EE:45:4C:93:
7D:C8:7A:00:58:33:52:44:D5:02:B1:8E:3F:92:59:7E:74:69:F9:97:
EA:C0:67:44:D0:F7:3B:DB:B7:D8:99:3E:4D:0A:F9:11:9E:BA:DF:00:
CF:7D:C3:78:4D:5E:5D:5B:53:64:01:54:4A:CB:BD:7A:9A:69:6D:89:
1E:39:DF:65:38:AB:0D:01:FE:80:4A:EE:AD:67:0F:C0:19:2F:A5:C9:
10:8D:38:6C:C6:C9:A3:FD:A1:DF:A5:4D:75:6B:59:BB:03:A0:C5:A7:
2E:63:AD:9B:D7:19:A0:D0:5E:56:C4:E9:2A:5D:34:34:CB:D8:DB:2A:
67:69:A7:62:7E:B3:78:70:5C:3E:58:13:D8:BC:B4:56:6F:F5:09:F5:
02:E5:29:C1:34:AA:F3:4B:2A:AA:11:7A:7C:C1:67:F8:66:45:56:06:
AD:B4:E5:A5:88:58:4B:0D:DF:8D:97:09:3B:57:F2:1E:23:06:88:E7:
BE:AE:2F:FD:AB:33:27:D8:F9:16:AD:03:8E:3A:6F:79:E4:34:31:A0:
77:89:B0:B4:77:85:18:80:B0:64:EE:DF:3A:B1:0B:62:4B:74:C7:D8:
1F:55:D3:E5:79:9C:4F:8E:19:CF:A8:D4:C3:A8:78:2E:B5:11:B9:63:
8A:6E:AB:8C:1E:A0:9E:DB:1C:E7:C4:C3:5C:E8:BC:9D:1C:1E:2F:8B:
E3:3C:3B:13:8E:CF:E2:CE:4F:EC:3E:41:1F:74:A3:9D:5F:6E:A1:2F:
CC:E8:E6:AD:2E:A0:F0:2A:9B:6D:D0:F0:78:05:39:69:4B:A6:45:78:
87:5B:4A:E7:10:FB:12:19:0E:8D:16:0E:CE:BB:6A:38:25:85:55:62:
D4:7D:B9:01:CB:BA:40:F0:63:7D:9E:5B:0A:EB:7B:65:27:7B:22:F9:
82:C7:C0:E4:F4:96:2F:55:6F:68:BD:56:0E:7E:40:19:35:9D:CF:B6:
F8:E9:B9:F1:3C:EC:50:F0:4B:A5:8B:E0
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16) (uint)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
VanHungNguyen
3: lsmod | grep iwlwifi
Nothing
4. ​lshw -C network
physical id: 14.3
version: 01
width: 64 bits
clock: 33MHz
*-network:1
physical id: 1f.6
version: 01
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.5.0-35-generic firmware=0.2-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:125 memory:9df00000-9df1ffff
*-network
physical id: 12
bus info: usb@3:3
logical name: enxd2a967934fa7
serial: d2:a9:67:93:4f:a7
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=6.5.0-35-generic duplex=half firmware=RNDIS device ip=192.168.72.107 link=yes multicast=yes port=twisted pair
AlfredoS_Intel
Hi Vanhungnguyen,
Alfred S
AlfredoS_Intel
Hi Vanhungnguyen,
Alfred S
AlfredoS_Intel
Hi Vanhungnguyen,
Much obliged for your cooperation and time to provide the logs requested.
After analyzing the logs, here are the errors that we found:
1.  [ 8.066242] iwlwifi 0000:00:14.3: probe with driver iwlwifi failed with error -110
2. sudo lshw -c network
3. The firmware on your machine is only 83 instead of 86 that should have come with Kernel 6.8 which means that there might have been a distribution issue with your Kernel 6.9. For this reason, please reinstall the latest firmware by downloading it from http://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git and use the following commands to install it
 # sudo cp iwlwifi-* /lib/firmware/'
# sudo modprobe iwlwifi
If you experience errors on loading the firmware, please reach out to Ubuntu forums or support for assistance on what commands to use to properly install the driver
4.  If the previous item did not resolve the issue, are you able to revert or fresh install to Kernel 6.8. Like the third item, if you need guidance on how to do this,  kindly contact Ubuntu support or their community page.
We hope for your understanding on the above suggestions.
Alfred S
VanHungNguyen
There a too many iwlwifi-*, which one should I choose to install?
AlfredoS_Intel
Hi Vanhungnguyen,
Thank you for quickly trying our suggestion.
Please look for iwlwifi-so-a0-gf-a0-86.
Let us know of the results.
Alfred S
VanHungNguyen
When I run sudo cp iwlwifi-* /lib/firmware/, all file startwith iwlwifi-* have been tranfered to /lib/firmware. But, when I run "sudo modprobe iwlwifi", nothing happened.
I run again "sudo dmesg |grep iwlwifi", last line still show:
VanHungNguyen
1. sudo lshw -c network
physical id: 14.3
version: 01
width: 64 bits
clock: 33MHz
*-network:1
physical id: 1f.6
version: 01
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.8.0-060800-generic duplex=full firmware=0.2-4 ip=192.168.1.128 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:133 memory:9df00000-9df1ffff
2. uname -r
3. modinfo iwlwifi
modinfo iwlwifi
filename: /lib/modules/6.8.0-060800-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst
license: GPL
firmware: iwlwifi-ma-b0-mr-a0-86.ucode
firmware: iwlwifi-ma-b0-gf4-a0-86.ucode
firmware: iwlwifi-ma-b0-gf-a0-86.ucode
firmware: iwlwifi-ma-b0-hr-b0-86.ucode
firmware: iwlwifi-ma-a0-mr-a0-86.ucode
firmware: iwlwifi-ma-a0-gf4-a0-86.ucode
firmware: iwlwifi-ma-a0-gf-a0-86.ucode
firmware: iwlwifi-ma-a0-hr-b0-86.ucode
firmware: iwlwifi-ty-a0-gf-a0-86.ucode
firmware: iwlwifi-so-a0-gf-a0-86.ucode
firmware: iwlwifi-so-a0-hr-b0-86.ucode
firmware: iwlwifi-so-a0-jf-b0-86.ucode
firmware: iwlwifi-gl-c0-fm-c0-86.ucode
firmware: iwlwifi-gl-b0-fm-b0-86.ucode
firmware: iwlwifi-bz-a0-fm4-b0-86.ucode
firmware: iwlwifi-bz-a0-fm-c0-86.ucode
firmware: iwlwifi-bz-a0-fm-b0-86.ucode
firmware: iwlwifi-bz-a0-gf4-a0-86.ucode
firmware: iwlwifi-bz-a0-gf-a0-86.ucode
firmware: iwlwifi-bz-a0-hr-b0-86.ucode
firmware: iwlwifi-sc-a0-wh-a0-86.ucode
firmware: iwlwifi-sc-a0-gf4-a0-86.ucode
firmware: iwlwifi-sc-a0-gf-a0-86.ucode
firmware: iwlwifi-sc-a0-hr-b0-86.ucode
firmware: iwlwifi-sc-a0-fm-c0-86.ucode
firmware: iwlwifi-sc-a0-fm-b0-86.ucode
srcversion: CFC882C1CB841A746DE1B63
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 6.8.0-060800-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
sig_key: 01:80:44:19:23:D7:9E:2A:99:D6:D4:0D:6C:8C:AB:BE:95:06:94:FB
signature: 07:C2:69:77:BD:A7:D9:A8:0A:C6:5B:2F:58:D5:CE:5C:28:1B:59:E8:
79:FB:F5:4D:4E:71:2F:03:E2:2D:B1:BE:99:86:36:2B:6E:80:B0:E2:
26:EE:90:0B:4A:2C:01:9D:F0:B3:95:9E:9E:7E:C8:AC:E7:31:10:D2:
26:7F:36:17:49:3E:CB:5A:C9:C3:32:B3:2D:02:2F:4A:59:18:A7:3D:
A4:42:A8:05:66:AD:C9:A4:4E:9D:3B:67:75:2D:D5:EC:49:29:4C:9E:
7F:4E:86:E1:05:EF:8F:28:4F:2A:69:33:D9:7D:8C:B3:99:05:B0:F5:
54:56:21:84:9C:FF:A2:62:C6:1D:80:89:D6:7A:74:05:3C:58:7E:96:
6E:08:26:8C:41:94:84:08:50:23:38:C4:E3:ED:87:53:68:F8:F7:0F:
D2:14:C9:C5:D7:ED:5F:E5:4E:DA:CF:EC:7E:36:A0:43:93:B2:09:C1:
82:65:49:96:AA:35:6D:06:6D:F1:22:A1:15:C6:5E:A2:D9:83:F0:95:
1F:9E:BF:FB:50:40:6E:FF:62:73:85:B9:B6:63:4C:91:D5:56:B3:EA:
8E:E5:25:6B:0F:15:1F:DB:D1:4D:68:2D:F1:A8:A9:6C:0F:33:0D:09:
18:D2:F1:0F:85:AF:9B:C2:68:22:BE:ED:91:35:28:8E:04:A8:5B:08:
89:E3:8C:D9:1B:CA:87:93:34:1F:30:65:84:B4:A1:CB:31:E1:54:5D:
E2:56:0F:8A:70:DC:C6:68:C5:46:87:9E:A2:D6:45:75:49:B3:E5:AA:
EF:A5:C8:45:FF:4E:6F:8E:05:F0:96:7C:E6:B4:10:45:EB:28:51:58:
10:BF:94:6F:E2:EB:48:76:AA:57:52:74:13:73:61:AD:91:EC:35:9C:
77:E3:D7:AE:07:DE:3F:42:CF:9A:7A:54:4C:BA:5E:00:4F:DD:D6:92:
DD:24:36:74:E1:EF:93:78:06:57:9A:AD:1A:C0:75:2F:DC:E0:43:D8:
BA:47:7E:76:84:E6:B7:A1:C3:E8:F1:4E:6B:4F:1C:8B:7A:72:89:2A:
D6:5A:BC:C1:19:9C:17:2F:ED:F2:EA:42:34:36:51:A5:1A:6D:67:20:
14:F1:1F:15:98:5E:4B:04:59:92:A7:0A:31:11:21:BF:37:3E:3B:D9:
BF:B1:EE:7C:F5:57:A0:8F:0A:CB:31:3F:F6:D7:0E:22:62:A8:38:25:
79:00:EE:97:9D:3A:B5:42:D7:77:E5:8C:EA:1D:A7:61:91:A0:3B:43:
55:32:9D:2E:4A:22:04:FF:11:4C:45:AA:4D:B4:39:DB:56:24:7C:7A:
E5:97:14:11:AF:17:97:FF:BA:2F:79:2E
4. sudo dmesg |grep iwlwifi
[ 5.672278] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 5.841526] iwlwifi 0000:00:14.3: CSR_RESET = 0x11
[ 5.841543] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x0
[ 5.841629] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.841692] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.841778] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.841835] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.841885] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.841941] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.841991] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.842041] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.842091] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.842148] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.842186] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.842236] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.842298] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.842354] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.842441] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.842445] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x1
[ 5.842505] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.842563] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.842621] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.842682] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.842734] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.842782] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.842828] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.842871] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.842875] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.842921] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.842927] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.842983] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.843024] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.843028] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.843118] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.843122] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x6
[ 5.843165] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.843204] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 5.843211] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 5.843262] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 5.843316] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 5.843354] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 5.843359] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 5.843364] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 5.843406] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 5.843410] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 5.843414] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 5.843470] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 5.843508] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 5.843513] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 5.843518] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 5.843521] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[ 5.843573] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 5.843679] iwlwifi: probe of 0000:00:14.3 failed with error -110
AlfredoS_Intel
Hi Vanhungnguyen,
We appreciate your prompt reply.
It is unfortunate that reinstalling the firmware resulted to the same issue. There is another fix for the issue that you can try, but it involves updating the Kernel. Please check with Ubuntu support if you have a Kernel update.
Please let us know if there isn’t one.
Alfred S
AlfredoS_Intel
Hi Vanhungnguyen,
We are just following up.
It looks like you need more time to assess the answers that we have provided.
Alfred S
AlfredoS_Intel
Hi Vanhungnguyen,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment.
We hope that our suggestion for you to coordinate with the manufacturer of your software directed you to a resolution for your concern.
We were waiting for your feedback since it is important for us to give you the right solution on your concern.
As much as we would like to continue assisting you, we need to close it to avoid overwhelming your inbox with notifications.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
