Wireless
8665 Discussions
Does AX200 support BT Isochronous Channel feature and BT LE Audio?
dandreye1
Hi All,
AX210 Product Brief states BT Isochronous Channel feature support in BT5.3 implemented in AX210. That feature has been around since 5.2 though. Is it also part of BT5.2 implementation in AX200 by chance? AX200 Product Brief doesn't mention it for some reason, and this page also suggests BT LE Audio (which uses this feature) isn't there below 5.3.
Many thanks in advance!
TheExpertGuy
New Contributor II
Correct, the AX210 Product Brief states support for the Bluetooth Isochronous Channel feature as part of Bluetooth 5.3. While this feature has indeed been around since Bluetooth 5.2, it is important to note that not all devices with Bluetooth 5.2 necessarily support every feature introduced in that version. Regarding the AX200, the Product Brief PDF does not mention support for the Bluetooth Isochronous Channel feature. This omission suggests that the AX200 does not support this specific feature, even though it implements Bluetooth 5.2. Additionally, the page you referenced indicates that Bluetooth LE Audio, which relies on the Isochronous Channel feature, is not supported below Bluetooth 5.3. In conclusion, the AX210 supports the Bluetooth Isochronous Channel feature as part of its Bluetooth 5.3 implementation, while the AX200 does not support this feature despite having Bluetooth 5.2.
I hope this clarifies your question
TheExpertGuy
New Contributor II
dandreye1
Hi @TheExpertGuy - thank you! Sorry just noticed an alert about your answer.
