Wireless
8662 Discussions
Does Intel AX210 support 5.9ghz?
Baum123
I am considering purchasing the Synology rt6600ax router for my home office. Since the router has a 5.9ghz UNII-4 band, I was wondering if the AX210 supports it?
If not, can you recommend a wireless adapter that does support the 5.9ghz band?
Jocelyn_Intel
Hello, @Baum123
Thank you for posting on the Intel® communities.
In order to answer your question, I will proceed to do some research about your wireless adapter.
As soon as I have any updates, I will post them here.
Best regards,
Jocelyn M.
Intel Customer Support Technician.
Jocelyn_Intel
Hello, @Baum123
Thank you for your time.
The Intel® Wi-Fi 6E AX210 supports dual stream Wi-Fi in the 2.4 GHz, 5 GHz, and 6 GHz bands only, any other band is out of the support spectrum.
Best regards,
Jocelyn M.
