Hello!
Intel developers have been posting incorrect drivers (22.190.0, 22.200.0, 22.220.0, 22.230.0) to the Intel Download Center and the Microsoft Update Catalog for a long time.
If you look at the structure of the driver, you will see that the names of the reference device names have shifted from their proper place to the very bottom of the configuration file. Also, the string "Strings" is shifted from its correct location.
Look at the structure of the driver "Netwtw08.INF" carefully and look at my modified file "Netwtw08.INF.Fix.txt" and what is the correct driver structure there.
Please fix this bug. This bug is present only in the driver and it is not visible in the system, i.e. it is not critical.
22.190.0.4: Intel Download Center / Microsoft Update Catalog (* Identical files byte by byte)
22.200.0.3: Microsoft Update Catalog
22.200.0.4: Microsoft Update Catalog
22.200.0.6: Intel Download Center / Microsoft Update Catalog
22.200.1.1: Microsoft Update Catalog
22.200.2.1: Intel Download Center / Microsoft Update Catalog
22.220.0.4: Intel Download Center / Microsoft Update Catalog
22.230.0.8: Microsoft Update Catalog
Hello djkomic,
we appreciate your feedback. We would like to let you know that the INF file is for drivers, and Intel wireless drivers have been certified by Microsoft, indicating that the driver structure meets the requirements and standards.
Deivid A.
Hello!
As I see it, you consciously do not want to delve into the essence of the problem.
Look at the structure of the driver "Netwtw08.INF" carefully and look at my modified file "Netwtw08.INF.Fix.txt " and what is the correct driver structure there.
If you look at the structure of the "Netwtw6e.INF" driver, then it is perfect here.
