Wireless
8508 Discussions
Driver Error in Intel Killer Performance Suite version 40.25.509.1465
Chrys
Dell SupportAssist Report (see attached) for Intel Killer Performance Suite version 40.25.509.1465 release date May 26, 2025 shows driver error.
Killer Wifi PCI card AX1650x in Dell XPS 8930 desktop PC with Core i5-9400 CPU @ 2.90GHz
Previous versions of Killer Performance Suite has no issues.
The adapter is working. The only thing I notice is that Killer Intelligence Center is not working as previously.
Chrys
SitDownPro
Yes, My ax1690i isn't working in the killer app (no killer device found).
Intel Driver Assistant tool keeps asking me to install the package, but it only uninstalls the entire package. Afterwards, it isn't picking up to reinstall the package automatically anymore. I had to go to the intel page to install the software package manually. Afterwards, the same look of Assistant telling me I need an update, but it goes to try to uninstall the package again. This released is BUGGED
Mike_Intel
Hello Chrys,
  1. What was the last changed made in the system before the issue started?
  2. How did you update the Killer Performance Suite?
  3. What are the troubleshooting steps that you tried so far?
SitDownPro
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Chrys
Thanks Michael - here are the chronological steps of Windows 11 OS and Killer Performance Suite updates:
1. Cumulative Update Preview for Windows 11 version 24H2 - KB5058499 successfully installed on 5/31/25
2. Intel Drivers & Support Assistant identified update for Killer Performance Suite which was initially installed on 5/29/25 but failed. Subsequently attempted again on 5/31/25 and succeeded.
3. Ran Dell SupportAssist utility on 5/31/25 and found error that I mentioned:
Error code list
PCI Status Tests : DW-22
Wireless Network Card : Driver Error
Error code list
Mike_Intel
Hello Chrys,
Thank you for the update.
Can you try to take a screenshot of the device manager if your wireless controller has an error message?
Michael L.
Chrys
Mike_Intel
Hello Chrys,
Please try to Clean Installation of Intel® Killer™ Performance Suite. Kindly refer to the link below on how to perform clean installation:
https://www.intel.com/content/www/us/en/support/articles/000058906/wireless/wireless-software.html
Michael L.
Chrys
Bad news: Unfortunately Dell is still flagging the PCI error (see above).
I followed instructions
1. Downloaded a fresh copy of Killer Performance Suite but didn't install yet.
2. Uninstall existing app on PC of  Killer Performance Suite using Microsoft uninstall app
3. Delete all file ins Temp folder
4. Installed Killer Performance Suite
Also, I wasn't taken to Microsoft Store to download Performance Suite Intelligence Center.
Since I'm still able to access the internet with the Intel Killer wireless card I'll wait until the next version of Killer Performance Suite is released and hopefully my issue will be resolved by then.
Mike_Intel
Hello Chrys,
Let me also check, have you tried checking this issue with Dell if they have their own configuration for this app?
Michael L.
JedG_Intel
Hi Chrys,
I'm following up with regards to the question that we posted. Please share this information at your earliest convenience so we can further investigate.
Jed G.
Chrys
No change.
The only feature missing is the Intelligence Center app from Microsoft Store. The PCI card is working.
The Intelligence Center app can't launch....probably a missing component.
I ran the Dell Preboot Diagnostics and Hardware Tests and all is OK so I'm going to ignore Dell SupportAssist error report.
Thanks for your support and you may close this request now.
Chrys
Mike_Intel
Hello Chrys,
I understand however, let me also suggest that you can contact Dell for further checking of the error since it is being detected by their software since the Dell Preboot Diagnostics and Hardware Tests have confirmed that the hardware is functioning properly.
Let me also provide the link below for reference if you still wish to continue troubleshooting the Killer™ Performance Suite.
How to Perform a Clean Installation to Solve Most Intel® Killer™...
Since you mentioned we can close this request, I need to close this inquiry.
Michael L.
