Wireless
8509 Diskussionen
Driver problem AX210 160MHz
cytaf
Einsteiger
1.026Aufrufe
Hello, just buy a new PCIe Adapter, and it's not working. No connections by wifi displayed, but in the network connection menu, the wifi connection is displayed.  When using the windows troubleshooting, I got the message : "there might be a problem with the driver for the wifi 2 adapter."
Tried to update the driver from the manufacturer (on internet and with the cd that was with the PCIe adapter) as from Intel ones, it didn't worked.
I've done a scan from my computer if it can help.
2 Antworten
n_scott_pearson
Superuser
1.016Aufrufe
Ok, dumb questions first...
Did you plug antennas into the connectors on the back of the card?
Did you connect the cable from the card to an internal USB 2.0 header?
It would help if you sent us a picture of the card. We can tell that it has AX210 silicon, but not much else.
cytaf
Einsteiger
933Aufrufe
Just had to plug it on the PCIe connector, the card was already built.
it has one cable for the bluetooth, and I connected it to a USB port.
Thanks for the help !
Antworten
