Wireless
8984 Discussions
Driver problems
EF59
Hello, I have an Acer A515-54-50N6 and the follwoing driver problems:
Device manager shows under "others" driver problems.jpgdriver problems
I have Windows home 11 Version 25H2 , Version 10.0.26200 Build 26200,  X64,
The first hardware problem you see on the picture, 2nd GAIA > hardware
BTHENUM\{a2129ff3-081b-4c45-8afe-469d9c4842ec}_LOCALMFG&0002
and 3rd Nearby sharing > hardware
BTHENUM\{a82efa21-ae5c-3dde-9bbc-f16da7b16c5a}_VID&00010075_PID&0100
BTHENUM\{a82efa21-ae5c-3dde-9bbc-f16da7b16c5a}_LOCALMFG&0002.
And then I have a permanent error:
Fehlerbucket.jpgFehlerbucket
So far my notebook is working well, but this 2 issues I like to clear. Can anybody help in German or English, thanks in advance.
Best regards Erich
AlHill
Have you installed the chipset software for your device (from acer)?
have you installed the bT driver for your device (from acer)?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is a keystroke logger]
EF59
Hi, my replies:
Have you installed the chipset software for your device (from acer)? Yes
have you installed the bT driver for your device (from acer)? Yes
Attached the report.
EF59
I was also running the Intel driver and & support assistanct 25.4.36.6 a week ago and another Bluetooth issue was solved.
PatrickV_Intel
Hi EF59
  • When did you first become aware of this problem?
  • Prior to this issue occurring, what recent changes were made to the system?
  • Could you provide the model of your wireless adapter?
  • What troubleshooting steps have you already attempted?
Patrick V.
EF59
Hi Patrick V, thanks for your reply, here my answers:
  • When did you first become aware of this problem? After update from 24H2 to 25H2.
  • Prior to this issue occurring, what recent changes were made to the system? update from 24H2 to 25H2.
  • Could you provide the model of your wireless adapter? Bluetooth is Broadcom with driver 6.4.0.710 dated 15.11.2010 and Intel(R) Wi-Fi 6 AX201 160MHz with driver 24.10.0.4 dated 11.11.2025.
  • What troubleshooting steps have you already attempted? I used Intel driver and & support assistanct 25.4.36.6 a week ago and another Bluetooth issue was solved.
At the moment all the wirless functions are working, I just have the issue that the Device manager shows under "others" 3 devices with question marks.
So if it's too difficult, maybe better to stop and accepting this 3 issues, what do you mean?
Best regards
Erich
PatrickV_Intel
Hi  EF59,
Thank you for your response.
I will now coordinate your query with our Internal team for further assistance.
Patrick V.
PatrickV_Intel
Hi  EF59,
Thank you for your patience as we continue investigating this issue.
Could you please confirm if there are any pending Windows updates on your system? If so, kindly download and install the latest updates. Additionally, please install the Wireless and Bluetooth drivers from your laptop’s Original Equipment Manufacturer (OEM).
You can download the driver directly using the link below:
Acer Aspire A515-54
If the issue persists after updating, please perform a clean installation of the wireless driver by following the steps outlined in the article linked below.
 Clean Installation of Wireless Drivers
Once you’ve completed these steps, kindly let me know the outcome.
Patrick V.
EF59
Hi Patrick, thanks for your reply. I know that driver homepage from acer and there are 4 to choose:
I choosed 2nd one > AX201, is that ok, or do I have to install all?? If so, which one first? Thanks in advance for your response.
Best regards Erich
PatrickV_Intel
Hi  EF59,
Yes, you are correct that you downloaded the second option (Bluetooth Driver – AX201 from Intel). Kindly proceed with the installation, and if the issue persists, please perform a clean installation of the downloaded driver.
You can complete the clean installation by following the steps outlined in the article linked below:
If you have any questions or need further assistance, please don’t hesitate to reach out.
Patrick V.
JedG_Intel
Hi EF59,
I'm checking to see if you were able to follow the recommendations shared by Patrick V.  Please let me know if you need further assistance so I can proceed accordingly.
Jed G.
EF59
Hi Patrick, I did what you recommended, the problem remains the same. I will stop now this issue since there is no solution, but I can work with my notebook without problems, just the 3 question marks for others.
Anyway thanks for your support and enjoy your day.
Best regards
Erich
JedG_Intel
Hello EF59,
Thank you for taking the time to try the recommendations provided, and I’m sorry to hear that the issue remains unresolved. I completely understand your decision not to continue at this time, especially since the notebook is functioning properly aside from the concern you reported.
With this in mind, I will proceed with closing this inquiry. Should you decide to continue troubleshooting or require further assistance in the future, please feel free to create a new support thread and include the System Support Utility (SSU) logs so we can assist you more effectively.
Have a good one.
Best regards
Jed G.
EF59
Hi Jed, thanks for your reply and thank you guys for your help, stay safe, good health!
Best regards
Erich
