Hi All,
I am thinking about the use of the WIFI-module BE202 for a new application.
Some questions about this:
* Is it correct that BE200D2W (BE200 m.2 1216) and BE200D2W M (BE202 m.2 1216) have the same FCC/IC-Code with FCC ID: PD9BE200D2 and IC: 1000M-BE200D2
* When I do an product certification with BE202D2W is that certification also valid for the BE200D2W and i can swop during production between these two RF-modules. Should be, if the FCC-ID/IC-ID is identical.
* in the WTCC Regulatory WebFlyer i have seen that some countries like Japan, China, Taiwan have different model Codes for the 2 modules. Any idea how this can be handled, that I can swop between the 2 RF-Modules during production? (in case of delivery issues)
Thanks in advance for your response
Dieter
Hello Dieter_Mathis,
I will check this matter internally and I'll get back in touch as soon as possible.
Best regards
Jed G.
I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Best regards
Jed G.
Hi Dieter_Mathis,
I wanted to check if you were able to review my email. Please let me know if you have further questions or concerns so we can proceed accordingly.
Jed G.
