Wireless
8906 Discussions
FCC ID/RED RF Testing for AX210 module
EdisonLi
Hi Support,
        We have some products with AX210 that are in the process of applying for FCC ID/RED certification, however, the module AX210 couldn't be set into continuous tx mode for testing. The module have to be tested in different channels, bandwidth and modulation.
Would you please help to provide me  "DRTU_Web_install.exe" installer, so that we can try to arrange the test, Thank you.
DeividA_Intel
Hello EdisonLi,
Thank you for posting on the Intel® communities. I understand you need some tests for your Intel® Wi-Fi 6E AX210 (Gig+).
I would like to let you know that Intel does not provide support on how to run tests for the wireless modules. However, you can contact Dekra and they will help you with this request since they are the only ones that can process it.
I will send you an e-mail to the e-mail address associated with your community profile with the contact information.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Tepozar
I wonder if you managed to find a solution here?
Kind Regards,
Laszlo
nataliakessy
I have the same issue. Do we have a solution for that?
