Wireless
8510 Discusiones
Frequent connection loss with AC 9560 160MHz
Tony322
Principiante
3.445 Vistas
I have a laptop with an Intel AC 9560 160MHz wireless card.  With almost every use I lose network connectivity, usually while playing games.  When I lose connections I get Netwtw08 system errors 5002, 5005, and 5007.  They all say the network adapter has encountered an error and stopped functioning.  The adapter will usually recover on its own or just require a disconnect/reconnect and it works again but as you can imagine, especially when I'm in the middle of an online game, this is extremely frustrating.
I've searched for days for a solution and have tried everything I could find.  I've installed the latest driver for both my network adapter and the related bluetooth adapter.  I've checked with my OEM for drivers and tried those as well (they are older and don't resolve the issue).  I've turned off the "disable this device to conserve power" option.  I've opened the back of my laptop and cleaned out all the dust to resolve any possible overheating issues.  The only thing I've found that I haven't tried long term is turning my adapter 5GHz band to 20MHz only because doing that cut my network speed to a 1/3 of what it is normally, crippling my network speeds is not an option.
This seems to be a pretty common problem based on my online searches that has plagued this particular wireless card for at least a year.  I really need a solution.
0 kudos
1 Solución
n_scott_pearson
Superusuario
3.425 Vistas
According to the report, you do not have the Intel Bluetooth driver package installed. This can cause issues with Wireless operation, since they share hardware.
There are also newer drivers available. I would recommend that you uninstall your existing driver and then install the latest from Intel. Here are links to the latest packages:
  1. Bluetooth (install first): https://downloadcenter.intel.com/download/29789/Intel-Wireless-Bluetooth-for-IT-Administrators?product=99446
  2. Wireless: https://downloadcenter.intel.com/download/29787/Intel-PROSet-Wireless-Software-and-Drivers-for-IT-Admins?product=99446.
Hope this helps,
Ver la solución en mensaje original publicado
4 Respuestas
AlHill
Superusuario
3.443 Vistas
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
Tony322
Principiante
3.439 Vistas
SSU results attached.
n_scott_pearson
Superusuario
3.426 Vistas
Hope this helps,
Tony322
Principiante
3.394 Vistas
Sorry it took me so long to respond, it took me a while to use the machine for an extended enough period of time after updating to check if the issue persisted.
It appears that following those steps exactly; uninstalling the driver completely then updating the bluetooth then most recent wireless drivers; has fixed the issue.
Thank you.
Responder
