Wireless
8622 Discussions
Hardware restart was requested
vusdo
우분투 18.04
AX201
무한 루프
[ 92.213051] iwlwifi 0000:00:14.3: 마이크로코드 SW 오류가 감지되었습니다. 0x0을 다시 시작합니다.
[ 92.213125] iwlwifi 0000:00:14.3: IWL 오류 로그 덤프 시작:
[ 92.213127] iwlwifi 0000:00:14.3: 상태: 0x00000040, 카운트: 0x00000040, 카운트: 6
[ 98]21312
[ 92.213129] iwlwifi 0000:00:14.3: 0x00004424 | ADVANCED_SYSASSERT
[ 92.213130] iwlwifi 0000:00:14.3: 0x008026F4 | trm_hw_status0
[ 92.213131] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 92.213132] iwlwifi 0000:00:14.3: 0x004CA218 | branchlink2
[ 92.213132] iwlwifi 0000:00:14.3: 0x00000E26 | 인터럽트 링크1
[ 92.213133] iwlwifi 0000:00:14.3: 0x00000E26 | Interruptlink2
[ 92.213134] iwlwifi 0000:00:14.3: 0x00060002 | 데이터1
[ 92.213135] iwlwifi 0000:00:14.3: 0x0000007F | data2
[ 92.213136] iwlwifi 0000:00:14.3: 0x00000FFE | data3
[ 92.213137] iwlwifi 0000:00:14.3: 0x0A006EE2 | 비콘 시간
[ 92.213137] iwlwifi 0000:00:14.3: 0xE42F2FD0 | tsf 낮음
[ 92.213138] iwlwifi 0000:00:14.3: 0x00000000 | tsf 안녕하세요
[ 92.213139] iwlwifi 0000:00:14.3: 0x00000000 | 시간 gp1
[ 92.213140] iwlwifi 0000:00:14.3: 0x0185D999 | 시간 gp2
[ 92.213141] iwlwifi 0000:00:14.3: 0x00000001 | uCode 개정 유형
[ 92.213142] iwlwifi 0000:00:14.3: 0x00000030 | uCode 버전 메이저
[ 92.213142] iwlwifi 0000:00:14.3: 0x13675109 | uCode 버전 마이너
[ 92.213143] iwlwifi 0000:00:14.3: 0x00000351 | 헉 버전
[ 92.213144] iwlwifi 0000:00:14.3: 0x00C89004 | 보드 버전
[ 92.213145] iwlwifi 0000:00:14.3: 0x0C00001C | hcmd
[ 92.213146] iwlwifi 0000:00:14.3: 0x80120000 | isr0
[ 92.213147] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 92.213147] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 92.213148] iwlwifi 0000:00:14.3: 0x04C1DACC | isr3
[ 92.213149] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 92.213150] iwlwifi 0000:00:14.3: 0x00B30502 | 마지막 cmd ID
[ 92.213150] iwlwifi 0000:00:14.3: 0x00008B70 | wait_event
[ 92.213151] iwlwifi 0000:00:14.3: 0x00009D7E | l2p_control
[ 92.213152] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 92.213153] iwlwifi 0000:00:14.3: 0x00000003 | l2p_mh유효
[ 92.213154] iwlwifi 0000:00:14.3: 0x00001010 | l2p_addr_match
[ 92.213155] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 92.213155] iwlwifi 0000:00:14.3: 0x00000000 | 타임스탬프
[ 92.213156] iwlwifi 0000:00:14.3: 0x0000F06C | |flow_handler
[ 92.213190] iwlwifi 0000:00:14.3: IWL 오류 로그 덤프 시작: [ 92.213191] iwlwifi 0000:00:14.3: 0x0000:00:14.3: 0x0000
:00:14.3: 상태: 0x00000040, 개수: 7
[ 92.0] NMI_INTERRUPT_LMAC_FATAL
[ 92.213193] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 92.213194] iwlwifi 0000:00:14.3: 0xC008D49C | umac branchlink2
[ 92.213195] iwlwifi 0000:00:14.3: 0xC0087824 | umac 인터럽트 링크1
[ 92.213196] iwlwifi 0000:00:14.3: 0x010152F4 | umac 인터럽트 링크2
[ 92.213198] iwlwifi 0000:00:14.3: 0x00000400 | umac 데이터1
[ 92.213199] iwlwifi 0000:00:14.3: 0x010152F4 | umac 데이터2
[ 92.213200] iwlwifi 0000:00:14.3: 0x00000000 | umac 데이터3
[ 92.213201] iwlwifi 0000:00:14.3: 0x00000030 | umac 메이저
[ 92.213201] iwlwifi 0000:00:14.3: 0x13675109 | umac 마이너
[ 92.213202] iwlwifi 0000:00:14.3: 0x0185D9B0 | 프레임 포인터
[ 92.213203] iwlwifi 0000:00:14.3: 0xC088752C | 스택 포인터
[ 92.213204] iwlwifi 0000:00:14.3: 0x00B40118 | 마지막 호스트 cmd
[ 92.213205] iwlwifi 0000:00:14.3: 0x00000000 | isr 상태 등록
[ 92.213221] iwlwifi 0000:00:14.3: Fseq 레지스터:
[ 92.213223] iwlwifi 0000:00:14.3: 0xE0000101 | FSEQ_ERROR_CODE
[ 92.213225] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 92.213228] iwlwifi 0000:00:14.3: 0x80070043 | FSEQ_CNVIO_INIT_VERSION
[ 92.213230] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 92.213233] iwlwifi 0000:00:14.3: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 92.213235] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 92.213237] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 92.213240] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 92.213242] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 92.213247] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 92.213251] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 92.213256] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 92.213345] iwlwifi 0000:00:14.3: 데이터 수집 중: 트리거 2가 실행되었습니다.
[ 92.213348] ieee80211 phy0: 하드웨어 재시작이 요청되었습니다.
[ 92.588862] iwlwifi 0000:00:14.3: 디버그 대상 적용 중 EXTERNAL_DRAM
[ 92.733378] iwlwifi.5 reconfig 0000:30
:14 00:14.3: BIOS에 WGDS가 있지만 WRDS는 없습니다.
David_G_Intel
Hello vusdo
Thank you for posting on the Intel️® communities. Please share with us more information on the specific problem, the troubleshooting steps you tested and theIntel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
