Wireless
8543 Discussions
Help with Windows 8 Intel My WiFi Dashboard
Hello everyone,
I'm hoping this is a relatively easy fix, but I guess we'll see. I got Windows 8 Pro through my school, and now I can't seem to figure out how this new dashboard for windows 8 works. I downloaded the windows 8 dashboard from intel, but when I open it up, the only option that is available to me is the do not disturb option, and it isn't in the lite version, so I guess I'm not sure how to get my devices to pick this up again since I don't have wireless and hotspot switches on my dashboard anymore :/
Occurs the same with my notebook. With Win 7 works well, but with the upgrade .. Win 8 and the new MyWifiDashboard (version 15.5.0) only the not disturb option appears.
Samsung N700Z4 w/ Intel Advanced N 6230 Wifi Network
Hi.i am having the same problem after installing windows 8. Have a hp envy with a Intel Centrino(R) Advanced - N 6200 AGN network adapter.
I have the same issue. Windows 8 X64 the 6300 Intel adapter on an Alienware. Software version 15.1.1 showed the hotspot options, but said it wasn't a compatible version of the software. The most current software does not display the features.
Same problem with Win8 x64 @ Dell l502x with Intel® Centrino® Wireless-N 1030.
I have the same problem: Windows 8 pro x64, Intel Centrino Advanced-N 6205 on an Alienware M11x R3.
same problem.
alienware m15x, intel 6300, windows 8 pro 64-bit
wireless_15.5.6_e64.exe
Intel_My_WiFi_Dashboard_15.5.6_e64.msi
The same problem !!!
Intel Centrino Advanced-N 2200 for Desktop.
Hi Intel guys !
How are you? Any help about our problem?
Marcelo
Same here. Running Windows 8 Pro with a Centrino Advanced-N 6235. All I want to be a happy customer is hotspot functionality! Bring it full circle Intel! I stopped using a Killer Wireless-N card because of bad drivers and slow support. Granted, at least I have stable internet with the Intel card, but still... was looking forward to this perk I remember having last I owned an Intel Wifi card.
Same Here Still at this time on M645 s4070 Toshiba satellite, Windows 8 Pro Latest drivers and Mywifidashboard. When are we going to have a fix please!
I remember having the dashboard working with windows 8 consumer preview, but it must be a certain combination of driver and dashboard versions, has anyone tried another combination? please
Hi Have the same issue running Win8 Pro on Fujitsu T902 hybrid tablet/notebook with an Intel Centrino Advance-N 6205 Wi-Fi adapter!!!
Same problem here on an Intel Centrino Advanced-N 6250.
I did a driver update on windows 7 via the Hp support assistant and now my intel wifi dashboard is a lite version.
On windows 8 I only have the 'do not disturb' tab.
same issue (((
Reinstalling the PROSet/Wireless software will fix this. Mine got fixed. remember when installing, choose "custom" installation type and make sure you've checked all the items as "Run from local disk"
same problem with Intel 6300 and Win8 x64 pro
Where is that option(run from local disk)? I don't see that option when installing ProSet software even under custom installation. Am using v15.6.0.
it needs a registry tweak.here is how:
open
http://pastebin.com/WKeUcxgx http://pastebin.com/WKeUcxgx
then,
open a notepad, and paste the text from the above link. save it as a .reg file and run.. after adding the registry info, you'll get the "Run as Administrator" context menu for MSI installations.
inform me if anything goes wrong.
from which part should i copy that paste.
This
  1. @=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
  2. 00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
  3. 73,00,69,00,65,00,78,00,65,00,63,00,2e,00,65,00,78,00,65,00,22,00,20,00,2f,\
  4. 00,69,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
or this
  1. [HKEY_CLASSES_ROOT\Msi.Package\shell\runas\command]
  2. @=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
  3. 00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
  4. 73,00,69,00,65,00,78,00,65,00,63,00,2e,00,65,00,78,00,65,00,22,00,20,00,2f,\
  5. 00,69,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
Does it work for both windows 8 and 7?
the second one. and yes, it will work on both Win 7 & 8
sorry for the late reply.. was out of town..
