Wireless
8617 Discussions
How can I fix large lag spikes that started when I got an Intel Dual Band Wireless-AC 8265
RBrew1
Hi I recently got an Intel Dual Band Wireless-AC 8265 and ever since I have used it my ping randomly spikes to 300-800 every now and then. eg
Reply from 216.58.203.100: bytes=32 time=10ms TTL=51
Reply from 216.58.203.100: bytes=32 time=6ms TTL=51
Reply from 216.58.203.100: bytes=32 time=7ms TTL=51
Reply from 216.58.203.100: bytes=32 time=11ms TTL=51
Reply from 216.58.203.100: bytes=32 time=12ms TTL=51
Reply from 216.58.203.100: bytes=32 time=8ms TTL=51
Reply from 216.58.203.100: bytes=32 time=84ms TTL=51
Reply from 216.58.203.100: bytes=32 time=894ms TTL=51
Reply from 216.58.203.100: bytes=32 time=5ms TTL=51
Reply from 216.58.203.100: bytes=32 time=9ms TTL=51
Reply from 216.58.203.100: bytes=32 time=748ms TTL=51
Reply from 216.58.203.100: bytes=32 time=46ms TTL=51
Reply from 216.58.203.100: bytes=32 time=351ms TTL=51
Reply from 216.58.203.100: bytes=32 time=337ms TTL=51
Reply from 216.58.203.100: bytes=32 time=14ms TTL=51
Reply from 216.58.203.100: bytes=32 time=501ms TTL=51
Reply from 216.58.203.100: bytes=32 time=13ms TTL=51
Reply from 216.58.203.100: bytes=32 time=802ms TTL=51
Reply from 216.58.203.100: bytes=32 time=329ms TTL=51
Reply...
Hello RyanB,
Thanks for posting in our communities.
In order to better assist you, please provide us with the following files:
- Intel® System Support Utility report.
1. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 Download the latest Intel® SSU.
2. While connected to your WiFi network, run the scan. Select to include "everything."
3. Name and save the report.
- Your WLAN Auto-Config log.
1. In the search box on the taskbar, type Command prompt, press and hold (or right-click) Command prompt, and then select Run as administrator > Yes.
2. Enter: netsh wlan show wlanreport
3. Go to: C:\ProgramData\Microsoft\WlanReport\ locate wlan-report-latest.html
The attach button is located at the lower right corner of the reply box.
Eugenio F.
RBrew1
Thanks for replying, the files have been attached.
Hello RyanB,
Thanks for providing the requested files.
On the adapter advanced settings, please test changing "Channel Width for 5GHz" to "Auto".
What is your router brand and model? Do you have the chance to connect to other wireless networks for testing? If so, please let us know the results.
Eugenio F.
RBrew1
Changing the channel width didn't change anything I'm afraid, and I can't find out the router brand and model or connect to another wireless network as I'm living in university accommodation on their internet.
Hello RyanB,
Thanks for your reply.
Please notice that occasional ping spikes are expected on wireless connectivity. Even though 300-800ms is a high number, it's still under normal values considering you're connected to a network shared with several clients.
As a general recommendation, please https://www.asrock.com/MB/AMD/AB350M-HDV/index.asp# BIOS update your system BIOS to the latest version. If your wireless adapter comes with a branded PCIe adapter, please check the manufacturer site for drivers and perform a https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html clean installation.
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Please let us know if there's anything else we can do for you.
Eugenio F.
Hello RyanB,
We were reviewing this post. For documentation purposes, can you confirm if the instructions provided by Trilby in the previous post were useful for you?
Eugenio F.
NAspi
Try following the ScanWhenAssociated registry instructions but in the same place you would have set "ScanWhenAssociated" to 0, instead set "ScanDisableOnLowTraffic" to 1 (and restart Windows afterwards).
MItal
Thank goodness for you Trillby! Just registered to say, "Get em Trillby!" These "official" Intel techs don't know what they are doing. I trust you more than anything they have to say. (I also saw your posts from that year or more old thread that is now locked... Talk about bashing your head against the wall. Haha.)
