Wireless
8606 Discussions
How to fix unstable and bad performing Bluetooth on AX201?
gzxmx94
I have upgraded from a AC-7260 (old PC) to AX201 (new PC).
On my old 7260 I could connect 8 Bluetooth devices flawlessly (8x DualShock 4 controller).
With this new WiFi + BT card I can only connect two devices. I'm lucky when 3 works. 4 seems impossible and when 3 or 4 connected, sometimes one controllers disconnect seemingly random.
I can't connect 5 or more devices at all. This was possible with the old WiFi.
I'm less than 1.5m from the antenna.
There is a direct line-of-sight path between the antenna and the devices.
Refitting the antenna does not improve nor worsen the situation.
I'm using 22.130.0.2 driver version for the Bluetooth.
Suggestions?
josmatic
Hi, are you sure that Bluetoothe device use correct driver even when you install it?! Please go at Device manager, right click then go on Properties, open Tab Driver and check Driver details, is it Microsoft or which you install?
gzxmx94
This is what properties say.
DeividA_Intel
Hello gzxmx94,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6 AX201 (Gig+).
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Do you have any Wi-Fi issues?
Deivid A.
gzxmx94
Hello DeividA_Intel,
I have sent you a private message with all the requested information.
I do not use Wi-Fi because my computer is connected through an ethernet cable to the network. So I don't know if I would have any Wi-Fi issues, but no devices in my home experience any problems if that's relevant.
When I needed to use the Wi-Fi to update the ethernet NIC drivers then the Wi-Fi worked perfectly at full speed.
I have performed a speedtest via Wi-Fi and the ping is 9, download 79 Mbps, and upload 57 Mbps.
Via ethernet cable the same (next) speedtest has 7 ping, download 201 Mbps, and upload 57 Mbps.
DeividA_Intel
Hello gzxmx94,
Thanks for the information provided. In order to help you, please try the following:
1. Try the latest Asus drivers (22.80.0.4).
2. Try to update your BIOS to the latest version (1403). You may need to check with Asus for advice.
3. Perform a clean installation of the Intel Wi-Fi ann Bluetooth drivers:
4. Check with Asus for compatibility and instruction for the integrated Intel® Wi-Fi 6 AX201 (Gig+).
Deivid A.
DeividA_Intel
Hello gzxmx94,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
gzxmx94
I have performed the requested steps:
- BIOS is now version 1403
WiFi driver from ASUS website
Bluetooth driver from ASUS website.
Unfortunately that did not solve the issue.
I can however still connect all the game pads to my old laptop with the 7260 chipset (when I re-pair them).
I have re-paired all the controllers to my desktop again, and I can only connect three simultaneously. Out of eight.
It seems to work even worse now - I can't connect a fourth controller at all. The controllers also disconnect randomly more often.
Can an engineer from Intel weigh in and address this?
I think this is a serious bug.
DeividA_Intel
Hello gzxmx94,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello gzxmx94,
Based on the research performed, the Intel® Wi-Fi 6 AX201 Bluetooth would support up to 7 devices. Since this is not the original wireless card for your motherboard and the Intel® Wi-Fi 6 AX201 is integrated into the motherboard I recommend checking with the Asus to check for proper BIOS settings and firmware for the device.
Also, bear in may that the performance will depend on if the devices are Bluetooth Low Energy (BLE) technology.
Deivid A.
gzxmx94
The motherboard came factory/pre-equipped with the Intel AX201 adapter (and came with a set of antenna's which I have connected to the correct, as specified in the manual, connectors).
The motherboard contains a special CNVIo2 connector which looks like an M.2 slot, which hosts the factory-provided-by-ASUS Intel AX201 adapter.
The devices are Bluetooth Classic 2.1.
DeividA_Intel
Hello gzxmx94,
In this case, if you have installed the latest drivers, Windows version, and BIOS I recommend you to check with Asus to confirm if there are any kind of limitations or restrictions on their part since they can change some specifications from the BIOS.
Deivid A.
