We use the AX210NGW Wi-Fi module into our product under Ubuntu OS.
Because We need to pass the FCC RF test item, but we don't know how to set this AX210NGW Wi-Fi as WIFI AP mode.
We want to use Window PC WIFI as client to connect to AX210NGW Wi-Fi module and do the RSSI test.
Could you please share us the application note for how to set up Wi-Fi AP mode on Ubuntu?
Hello Mei1,
I'll check on this and will post an update once it's available.
JeanetteC.
Hello Mei1,
I wanted to let you know that all current Intel® Wireless Adapters are designed as client-only devices. This means they don't support master or AP (Access Point) mode.
Here's the link for reference: Do Intel® Wireless Adapters Support Master or AP Mode?
I will be closing the thread and will no longer be monitoring this inquiry.
Dean R.
