Wireless
8513 Discussions
How to use be200 mlo
jack_wang
How to make the be200 mlo work properly on ubuntu operating system?
jack_wang
Hi everyone,
 I bought wifi7 network card of your company's intel be200, and now I want to use mlo on ubuntu operating system.
I tried to use the latest kernel 6.10, the latest version of wpa_supplicant, the latest version of firmware, and wpa3 encryption, but failed to test mlo all the time.
Can ubuntu support the Mlo function of be200?
If yes, what additional configuration is required?
If no, when will it be supported
ACarmona_Intel
Hello Jack_wang,
May I know the complete model of your system? Moreover, did you install the BE200 on your system yourself?
We look forward to your response!
Carmona A.
jack_wang
hello Carmona A:
lspci
           01:00.0 Network controller: Intel Corporation Device 272b (rev 1a)
kernel:
            Linux version 6.10.0-rc7
cpu :
      13th Intel i7
driver: iwlwifi
version: 6.10.0-rc7testv1-20240709+
firmware-version: 90.38c93dbc.0 gl-c0-fm-c0-90.uc
================================YES
The WIFI7 router in the test environment supports and enables the mlo function. In the same environment, I replaced the be200 wireless network card with the wifi7 network card of other manufacturers, and the mlo test was successful when I connected to the router, and I also tried to change to other routers that support mlo function. The practice proved that the mlo test failed for be200.
Thank you very much!!
      jack_wang
ACarmona_Intel
Hello Jack_wang,
Thank you so much for the quick response.
I will raise the case with our engineers for further guidance, and I will get back to you as soon as I have their response.
Thank you so much for your patience and understanding.
Carmona A.
ACarmona_Intel
Hello Jack_wang,
Thank you for patiently waiting on our response.
To provide you with the appropriate answer or recommendation, kindly describe to us how you validated the MLO feature.
And also, are you observing through dual-band/channel data traffic?
Furthermore, may we know what router model, wireless bands, and settings you are using?
We will wait for your response, and thank you so much for your understanding.
Carmona A.
ACarmona_Intel
Hello Jack_wang,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Jack_wang,
Again, we are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Carmona A.
ACarmona_Intel
Hello Jack_wang,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
