Wireless
8610 Discussions
IDSA says new drivers for Bluetooth and wifi and OEM says there are none
pdnRPH
The Dell OEM Support Assist says there are no new drivers for my XPS27 7760, and Intel IDSA has identified one for Bluetooth and one for Wifi card. What should I do?
pdnRPH
Thank you. Interestingly, I have always updated with the IDSA since these are both Intel. However, with your guidance, I will hold odd
AlHill
IDSA is not intended for your Dell.   Use Dell's driver support tool.
Also, if your BT and Wi-Fi are currently working, leave well enough alone.
pdnRPH
ClariceStarling
Valued Contributor II
"if your BT and Wi-Fi are currently working, leave well enough alone."
Best computer advice ever given!  Seems like a lot of people are causing problems just by screwing around with their computers when they don't need to!
n_scott_pearson
Dell has, on occasion, customized the firmware on the wireless cards, so it is best to stick with what the Dell tool is saying is available.
pdnRPH
Thank you, n_scott. I will ask them.
