Wireless
8584 Discussions
INTEL BE200 Bluetooth is not working
Noomoto
I have installed  New Wifi card for my Laptop , Acer Predator PH3D15-17 ,  replacing ex Killer 6E- Ax1675i.
After i have installed new Driver . My Wifi is working good but there is no sign of my Bluetooth even  installed BT 23.30.0 driver . In Device manager don't show the Blutooth icon . I have run "msdt.exe -id DeviceDiagnostic" and it doesn't help . I can't even use or see  any Bluetooth device or pairing anything .
LeonWaksman
I'm assuming that the Killer AX1675 Adapter was removed from your laptop?
You may try the following procedure:
1. Disconnect the internet connection.
2. Follow the instructions in this video and/or this article.
Hope this will work.
Leon
Irwan_Intel
Greeting Noomoto,
I've forwarded your inquiry to our wireless forum for further assistance.
Irwan_Intel
Noomoto
Thanks for your Prompt response .
LeonWaksman
Hi @Noomoto
Although you have replaced the Killer Adapter by Intel BE200, it looks that the Killer Driver is still installed in your system. You can find it on the Device Manager image and in the SSU report as well.
Perform Clean Installation of the new driver.
After Killer Driver is uninstalled,  the latest Intel BT driver.
Leon
Noomoto
Thanks for your suggestion . Will try this
Noomoto
Hi Leon ,
After repeatly many times  of Clean uninstallation  , It failed  to completely remove My-Ex AX1675i wifi card  from Device manager . It keeps to re-appear eveytime after system restart .  I have tried to Clean uninstall any related with intel wireless driver , Killer or anything that i can think of.
Any suggestion are open how to fix this problem .
LeonWaksman
Leon
Noomoto
No It Didn't . Killer AX1675 keeps appear everytime after i restart my system . Don't know how to permanent delete that .
I have tried procedure as your recoomend and it didn't work as well T_T
Noomoto
Could this be Acer Bios topic or else ? Anyone from Intel can describe this T_T.
Noomoto
Hi Leon , Thanks for your help . After i have done with your recommendation . Unfortunately Its Worked!!!
Today i saw my Bluetooth icon came back .
Appreciated and Thanks again for your help.
