Wireless
7467 Discussions
INTEL(R) Wi-fi 6 Ax201 160 MHZ not starting
Charbel619
No matter what i do, the wifi driver is FAILED TO START
it says THIS DEVIDE CANNOT START (code 10)
{Operation Failed}
The requested operation was unseccssful.
i uninstalled it, reinstalled it, nothing. same same. windows is updated. WIFI adapter not working at all. no idea what to do. i even tried windows system restore (it is failing)
DeividA_Intel
Hello Charbel619,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is this a laptop or desktop computer?
4. Is this issue recent? If so, when did it start?
Deivid A.
DeividA_Intel
Hello Charbel619,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Charbel619,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
P_Sav
I have a similar problem, exact same error. This occurred in conjunction with running the Windows 11 Update. I have since restored back to Windows 10. Still an issue. Tried to submit the report referenced above via the tool and I get a "This site can't be reached" error.
P_Sav
Original adapter, laptop computer, started when I tried to log on this morning. Now on a wired connection temporarily.
