I was wondering if anyone has any recommendations on Intel based solutions in the ISM Band or 802.15.4 space. It is for use in industrial automation. Other than Wibree or Zigbee?
Can you say more detail about what kind of solution you are looking for? Board level, module, industrial PC? Which Intel processor platform?
You might also check out the Intel® Embedded Alliance Solutions Directory where you can find off the shelf and custom embedded solutions from Intel's trusted ecosystem. You can search the directory here:
http://www.intelcommsalliance.com/kshowcase/view http://www.intelcommsalliance.com/kshowcase/view
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
Hi Felix,
Looking for plug-in modules to connect to new design which is based on the Intel Atom processor.
The requirements we have are WiFi, Cellular and Ethernet all as plug-in modules that are swappable based on the application.
Additional to that, keen on a Sensor Network (eg: ZigBee) solution as well that can sustain data logging applications, a module that connects to the board. Current solution connects to a secondary device that performs these functions. Looking for a more integrated solution.
Hope this helps, Thanks for the reply!
Best,
Richard
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
