Wireless
8782 Discussions
Intel 1000 BGN problem.
Hello, I have searched online for the past few hours for a solution to my problem but could not find anything that worked.
I have a Dell XPS L501x with the Intel 1000 BGN wireless card, and for some reason I cannot connect to the internet after a disconnection last night. I know the modem and router are working fine as other devices are connecting and working. However, whatever I try my laptop cannot connect back using WLAN. The only way it's connecting to the internet is through the Ethernet cable.
I have tried updating the driver for the wireless card, system restoring to a previous point (in safe mode), and running the Intel diagnostics but nothing seems to work. I have tried connecting to hotspots but they don't work either. There are no apparent errors coming up.
If anyone could help, I would greatly appreciate it, thanks.
Thank you for your post Safin,
The failure to be able to connect to the Internet can be caused by a large variety of issues see a description here:
http://compnetworking.about.com/od/internetaccessbestuses/tp/fixing-cant-connect-to-internet-problems.htm http://compnetworking.about.com/od/internetaccessbestuses/tp/fixing-cant-connect-to-internet-problems.htm
Some of the common troubleshooting steps are to restart the laptop; turn the Wireless radio off and on (may be a switch or a key combination like Fn+ F8). Also restart the router, (unplug it from the power and 30 seconds later plug it back in) this to clean the routing table. Also malware like a virus may cause a connectivity issue, try running a system restore to a previous date. See the instructions below: http://windows.microsoft.com/en-US/windows7/products/features/system-restore http://windows.microsoft.com/en-US/windows7/products/features/system-restore
Also if you can connect to your network and just not access the Internet then apart from the above also try using different browsers (i.e.: Internet Explorer and Mozilla Firefox or Chrome)
NOTE: The links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
I hope this helps.
