You do realize that Thursday is a holiday in the US, correct? And, that many employees will also take Friday off as well.
So, rather than an unfounded assumption, just be patient and an intel support engineer will assist you.
Also, this was announced on the forum home page:
All I wanted was help for a problem I am encountering with a piece of Intel hardware, not to be spoken down upon by yourself.
If someone wanted to actually help me with my problem, I would be appreciative, I am sure you are aware that fixing such issues can in many cases like my own be time sensitive. Failing that i will simply no longer use Intel products, as simple as that really.
Hello @JoshWink1
Thank you for posting on the Intel® communities. It is worth mentioning that the information provided by @AlHill is correct. There is a public announcement on the Intel Community Home page saying that "Intel Support will be observing the holiday and will return on Monday, November 30th. Thank you!".
Nevertheless, as an exception, we will start the support process now and we would like to gather the following information in order to assist you better:
- There is no "Intel Wireless 9620" and based on the screenshot attached we understand you refer to the "Intel® Wireless-AC 9260". Is this correct? Also, is the Wireless adapter the original one that came pre-installed in your system from factory? Or did you install/integrate it on the computer?
- When did it start to happen? Did it work fine before? Were you able to have your wireless connection in a normal/expected performance before? Please provide details.
- If this worked fine before, do you know if this issue happened after a new Windows update, hardware/software change or update, or after a Wireless/Bluetooth driver update?
- Just to make sure, is the issue only happening when gaming? If yes, could you please provide more details? For instance, what are the games experiencing the issue? gaming platform used? etc.
- If your system has a LAN Ethernet port, have you tested if the behavior is the same when using Ethernet cable? (Wired connection).
- When the behavior occurs, do you see any "disconnection message" or any other error message? Perhaps in Windows® Notification Area?
- For reference purposes, please provide details/examples of the "other devices" that you have tested?
- Router/Access point brand and model:
Also, please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread to gather more details about your system.
- Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
Note: To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
All the staff here seem to find enjoyment telling people their mistakes and berating them for it, yes I made a typo but you can see from my image clearly what I am discussing, so why point it out and make a statement? That's just unprofessional. Whilst I understand that in the US this period is a holiday, I would like to imagine a company as large as Intel might have forum staff or troubleshooting services available from across the globe, as does any other multinational. Whilst my problem is resolved I will be staying away from any devices using Intel hardware, due to lack of support and due to their reliance on a cyber bully to run the forum, who does nothing but try to illicit tempered responses from people in distress. Intel should be doing better, not just on the forum but in the production of their hardware so that issues like the ones I see reported here are not so common.
Hello @JoshWink1
Thank you very much for your response. Your feedback is really appreciated.
We are glad to know that you were able to find a fix to solve this problem. Also, we would like to inform you that we have additional channels for assistance where we can provide live support and we can even offer you remote assistance.
Here is the contact us link: https://www.intel.com/content/www/us/en/support/contact-support.html#@11
Please click on "Intel® Wireless Networking", scroll down and you should see contact information for Live Chat and Phone support. We hope this helps for future (urgent) cases.
If you have additional inquiries, please do not hesitate to contact us back.
Note:
The Intel® Wireless-AC 9260 is part of the Intel® Wireless 9000 Series, there are similar models as the Intel® Wireless-AC 9260 and we have seen scenarios where customers may have several systems with different wireless of the Intel® Wireless 9000 Series, so we just wanted to make sure that we will provide you with support for the proper product.
For us, it is very important to have the proper information in order to provide the most accurate information. Our goal was to confirm the product model. We do apologize if this was taken misunderstood, it was just to clarify product information.
Andrew G.
Hello @JoshWink1
We will proceed to close this inquiry now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sincerely,
Andrew G.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
