Wireless
8255 Discussions
Intel AC-7260 - driver v.17.12.04
hhans6
I have a Lenovo Carbon X1 with Intel AC 7260 wifi driver. I have read a lot but not yet found a solution.
I tried to update to driver v.17.12.04
the strange thing is, if I go and remove the wifi card in hardware and afterwards install the driver. I restart and then it works - the pc can go to standby and startup again, and wifi card is still enabled
If I then restart the computer again, and try to do the same with starting up from standby the wifi nic is not enabled and a "code 43" in hardware.r
Is there any workarround or another driver that should be used to solve that issue.
hhans6
Hmm - it seems when I go to the wifi network card and mark "Allow the computer to turn off this device to save power" than it actually works.
If I remove the mark, then the problem appear again ?!?
John_S_Intel
The "Allow the computer to turn off this device to save power" setting doesn't work like it sounds like it does (opposite of the way you think it would). I think you probably want this setting checked (enabled) rather than unchecked. Please see the following link for more details about what this setting actually does: http://support.microsoft.com/kb/2740020 http://support.microsoft.com/kb/2740020.
SBres
I also have an X1 with the same identical issue and have been attempting for over a month to resolve the issue.
I now automatically go into device manager and disable and enable the AC260 in order to use Wi-Fi.
There has to be a software fix out there.
BB4
New Contributor II
If it is the same identical issue, as you say, then enabling that power setting should fix your problem.
SBres
Amazing - Issue resolved - THANKS!
BB4
New Contributor II
<<There has to be a software fix out there.>>
And right there in Windows, too. Fancy that.
