- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, we are currently working with different Intel AX200 boards in Linux, both as stations and AP. Unfortunately, we are not able to make IntelAX200 run in AP_mode, IEEE 802.11ax.
Configuration:
Linux Kernel 5.8
2. Iwlwifi-backport core56 (and have also tested other)
3. Hostapd-master (2.9 and 2.10 developer version)
4. Ubuntu 20.04.1
Configuration on STA:
1. Linux Kernel 5.8
2. Iwlwifi-backport core56 (and have also tested other as suggested by Intel)
3. Ubuntu 20.04.1
The support by Intel has lead to several tries, which still do not allow for Intel AX200 to run in AP_mode.
In attach goes a zip with the following docs:
- 1. Details : Explanation regarding the crash issues; the types of configuration tested and result.
- 2. dmesg_AP : dmesg output of the AP where crash can be observed
- 3. dmesg_STA : dmesg of the STA trying to connect to AP
- 4. Wireshark-AP-STA : Wireshark capture of the frames exchanged when crash occurs
- 5. hostapd : hostapd logs in debug mode.
- 6. hostapd_cli : This files contains the output of the stations connected to or trying to connect to AP.
- 7. Gmail - Configuring WiFi6 in hostapd : This pdf contains the mails exchanged in hostapd mailing list.
- 7. sample: This folder contains a wireshark capture of a successfull connection between AP and a STA in 802.11n mode.
Note this is a follow-up from @Shm posts between Sep and December 2020.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
RS19104, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry, please try the following troubleshooting steps in order to determine if there might be a problem with the Wireless configuration:
WiFi troubleshooting steps
Step 1: Check whether the kernel version supports this device:
The reference table of Wireless adapters and corresponding kernel versions is available in the following link:
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
The latest FWs are available by the following link:
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/
If the kernel version corresponds to the Wireless adapter, proceed with step 2.
Step 2: Check whether the Wireless adapter is connected correctly:
Type the following command to the terminal: # lspci
Verify that the Intel network controller is identified, as on a picture below. If not, then the system doesn't identify the Intel networidentifyk adapter and you will need to make sure it's properly integrated. You may need to request help from the system manufacturer. If the wireless adapter is properly identified - proceed with the step 3.
Step 3: Check whether this is an iwlwifi issue:
Type the following command to the terminal: # modinfo iwlwifi (example of the command output is on the picture below). If there is no output, then the module isn’t installed this is the distribution installation issue.
Please type: # lsmod | grep iwlwifi
If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
To verify, please type: # dmesg | grep iwlwifi
If the result is empty, the driver wasn’t initialized and this is a distribution issue. If the result is populated as on the above picture, proceeed with the step 4.
Step 4: Check whether the suitable firmware is installed:
Please type: # dmesg | grep “no suitable firmware found!”
If the result is not empty, it means you don’t have a suitable FW (api mentioned in the dmesg).
Please visit here https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
If these steps didn't reveal the issue or didn't solve the problem, proceed with the Step 5:
Step 5: Collect the debug data:
Please type: # dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect from the wiki FW dump too.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Step1: We are using Kernel 5.9 so the kernel supports the device. ..................
$ uname -a
Linux for1793 5.9.0-050900-generic #202010112230 SMP Sun Oct 11 22:34:01 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Step 2: The NIC can be seen with lspci ............................
wifitsn@for1793:~$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
00:01.2 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x4) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (closed) (rev 31)
00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (closed) (rev f1)
00:1c.4 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (closed) (rev f1)
00:1f.0 ISA bridge: Intel Corporation QM170 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-LM (rev 31)
02:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2)
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
Step 3: the module is adequately loaded.
wifitsn@for1793:~$ modinfo iwlwifi
filename: /lib/modules/5.9.0-050900-generic/updates/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
version: iwlwifi-stack-public:release/core56:8758:f9a85a73
license: GPL
author: Intel Corporation linuxwifi@intel.com
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-ma-a0-mr-a0-59.ucode
firmware: iwlwifi-ma-a0-gf-a0-59.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-59.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-59.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-59.ucode
firmware: iwlwifi-ty-a0-gf-a0-59.ucode
firmware: iwlwifi-so-a0-gf-a0-59.ucode
firmware: iwlwifi-so-a0-hr-b0-59.ucode
firmware: iwlwifi-so-a0-jf-b0-59.ucode
firmware: iwlwifi-cc-a0-59.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-59.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-59.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-59.ucode
firmware: iwlwifi-Qu-b0-jf-b0-59.ucode
firmware: iwlwifi-Qu-c0-hr-b0-59.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-59.ucode
firmware: iwlwifi-Qu-b0-hr-b0-59.ucode
srcversion: EF18F85B887E2FE0D687ACC
alias: pci:v00008086d00007E80svsdbcsci*
alias: pci:v00008086d00002729svsdbcsci*
alias: pci:v00008086d00007AF0svsd00000A10bcsci
alias: pci:v00008086d00007AF0svsd00000510bcsci
alias: pci:v00008086d00007AF0svsd00000310bcsci
alias: pci:v00008086d00007AF0svsd000000B0bcsci
alias: pci:v00008086d00007AF0svsd00000098bcsci
alias: pci:v00008086d00007AF0svsd00000090bcsci
alias: pci:v00008086d00007A70svsd00000A10bcsci
alias: pci:v00008086d00007A70svsd00000510bcsci
alias: pci:v00008086d00007A70svsd00000310bcsci
alias: pci:v00008086d00007A70svsd000000B0bcsci
alias: pci:v00008086d00007A70svsd00000098bcsci
alias: pci:v00008086d00007A70svsd00000090bcsci
alias: pci:v00008086d00002726svsd00004070bcsci
alias: pci:v00008086d00002726svsd00002074bcsci
alias: pci:v00008086d00002726svsd00000510bcsci
alias: pci:v00008086d00002726svsd000000B0bcsci
alias: pci:v00008086d00002726svsd00000098bcsci
alias: pci:v00008086d00002726svsd00000090bcsci
alias: pci:v00008086d00002726svsd0000007Cbcsci
alias: pci:v00008086d00002726svsd00000078bcsci
alias: pci:v00008086d00002726svsd00000074bcsci
alias: pci:v00008086d00002726svsd00000070bcsci
alias: pci:v00008086d00002725svsd000000B0bcsci
alias: pci:v00008086d00002725svsd00000A10bcsci
alias: pci:v00008086d00002725svsd00000510bcsci
alias: pci:v00008086d00002725svsd00000310bcsci
alias: pci:v00008086d00002725svsd00000020bcsci
alias: pci:v00008086d00002725svsd00000090bcsci
alias: pci:v00008086d00002725svsd00000000bcsci
alias: pci:v00008086d00002723svsdbcsci*
alias: pci:v00008086d00002720svsdbcsci*
alias: pci:v00008086d0000A0F0svsdbcsci*
alias: pci:v00008086d000043F0svsdbcsci*
alias: pci:v00008086d00004DF0svsdbcsci*
alias: pci:v00008086d00003DF0svsdbcsci*
alias: pci:v00008086d000034F0svsdbcsci*
alias: pci:v00008086d000006F0svsdbcsci*
alias: pci:v00008086d000002F0svsdbcsci*
alias: pci:v00008086d0000A370svsdbcsci*
alias: pci:v00008086d00009DF0svsdbcsci*
alias: pci:v00008086d000031DCsvsdbcsci*
alias: pci:v00008086d000030DCsvsdbcsci*
alias: pci:v00008086d0000271Csvsdbcsci*
alias: pci:v00008086d0000271Bsvsdbcsci*
alias: pci:v00008086d00002526svsdbcsci*
alias: pci:v00008086d000024FDsvsd00009074bcsci
alias: pci:v00008086d000024FDsvsd00000014bcsci
alias: pci:v00008086d000024FDsvsd00000012bcsci
alias: pci:v00008086d000024FDsvsd00001012bcsci
alias: pci:v00008086d000024FDsvsd00003E01bcsci
alias: pci:v00008086d000024FDsvsd00003E02bcsci
alias: pci:v00008086d000024FDsvsd00001014bcsci
alias: pci:v00008086d000024FDsvsd00000850bcsci
alias: pci:v00008086d000024FDsvsd00000950bcsci
alias: pci:v00008086d000024FDsvsd00000930bcsci
alias: pci:v00008086d000024FDsvsd00000910bcsci
alias: pci:v00008086d000024FDsvsd00008130bcsci
alias: pci:v00008086d000024FDsvsd00009110bcsci
alias: pci:v00008086d000024FDsvsd00000810bcsci
alias: pci:v00008086d000024FDsvsd00008010bcsci
alias: pci:v00008086d000024FDsvsd00008050bcsci
alias: pci:v00008086d000024FDsvsd00008110bcsci
alias: pci:v00008086d000024FDsvsd00009010bcsci
alias: pci:v00008086d000024FDsvsd00000150bcsci
alias: pci:v00008086d000024FDsvsd00000050bcsci
alias: pci:v00008086d000024FDsvsd000010D0bcsci
alias: pci:v00008086d000024FDsvsd00001010bcsci
alias: pci:v00008086d000024FDsvsd00000130bcsci
alias: pci:v00008086d000024FDsvsd00001130bcsci
alias: pci:v00008086d000024FDsvsd00001110bcsci
alias: pci:v00008086d000024FDsvsd00000110bcsci
alias: pci:v00008086d000024FDsvsd00000010bcsci
alias: pci:v00008086d000024F3svsd00004010bcsci
alias: pci:v00008086d000024F3svsd00000000bcsci
alias: pci:v00008086d000024F3svsd00000930bcsci
alias: pci:v00008086d000024F3svsd00000950bcsci
alias: pci:v00008086d000024F3svsd00000850bcsci
alias: pci:v00008086d000024F3svsd00000910bcsci
alias: pci:v00008086d000024F3svsd00000810bcsci
alias: pci:v00008086d000024F6svsd00000030bcsci
alias: pci:v00008086d000024F5svsd00000010bcsci
alias: pci:v00008086d000024F3svsd00000044bcsci
alias: pci:v00008086d000024F3svsd00000004bcsci
alias: pci:v00008086d000024F3svsd00009150bcsci
alias: pci:v00008086d000024F3svsd00009050bcsci
alias: pci:v00008086d000024F3svsd00008150bcsci
alias: pci:v00008086d000024F3svsd00008050bcsci
alias: pci:v00008086d000024F3svsd00009132bcsci
alias: pci:v00008086d000024F3svsd00008132bcsci
alias: pci:v00008086d000024F3svsd00009130bcsci
alias: pci:v00008086d000024F3svsd00008130bcsci
alias: pci:v00008086d000024F4svsd0000D030bcsci
alias: pci:v00008086d000024F4svsd0000C030bcsci
alias: pci:v00008086d000024F4svsd00009030bcsci
alias: pci:v00008086d000024F4svsd00008030bcsci
alias: pci:v00008086d000024F3svsd00009110bcsci
alias: pci:v00008086d000024F3svsd00009010bcsci
alias: pci:v00008086d000024F3svsd00008110bcsci
alias: pci:v00008086d000024F3svsd00008010bcsci
alias: pci:v00008086d000024F3svsd0000B0B0bcsci
alias: pci:v00008086d000024F3svsd0000D0B0bcsci
alias: pci:v00008086d000024F3svsd0000D050bcsci
alias: pci:v00008086d000024F3svsd0000C050bcsci
alias: pci:v00008086d000024F3svsd0000D010bcsci
alias: pci:v00008086d000024F3svsd0000C110bcsci
alias: pci:v00008086d000024F3svsd0000C010bcsci
alias: pci:v00008086d000024F4svsd00001030bcsci
alias: pci:v00008086d000024F4svsd00000030bcsci
alias: pci:v00008086d000024F3svsd00001150bcsci
alias: pci:v00008086d000024F3svsd00000150bcsci
alias: pci:v00008086d000024F3svsd00001050bcsci
alias: pci:v00008086d000024F3svsd00000250bcsci
alias: pci:v00008086d000024F3svsd00000050bcsci
alias: pci:v00008086d000024F3svsd00001110bcsci
alias: pci:v00008086d000024F3svsd00001012bcsci
alias: pci:v00008086d000024F3svsd00000012bcsci
alias: pci:v00008086d000024F3svsd000001F0bcsci
alias: pci:v00008086d000024F3svsd00000110bcsci
alias: pci:v00008086d000024F3svsd00001132bcsci
alias: pci:v00008086d000024F3svsd00000132bcsci
alias: pci:v00008086d000024F3svsd00001130bcsci
alias: pci:v00008086d000024F3svsd00000130bcsci
alias: pci:v00008086d000024F3svsd000010B0bcsci
alias: pci:v00008086d000024F3svsd00001010bcsci
alias: pci:v00008086d000024F3svsd00000010bcsci
alias: pci:v00008086d0000095Asvsd00009E10bcsci
alias: pci:v00008086d0000095Asvsd00009400bcsci
alias: pci:v00008086d0000095Asvsd00009000bcsci
alias: pci:v00008086d0000095Bsvsd0000520Abcsci
alias: pci:v00008086d0000095Bsvsd00005212bcsci
alias: pci:v00008086d0000095Asvsd00005F10bcsci
alias: pci:v00008086d0000095Asvsd00005490bcsci
alias: pci:v00008086d0000095Bsvsd00005290bcsci
alias: pci:v00008086d0000095Asvsd00005590bcsci
alias: pci:v00008086d0000095Asvsd00005190bcsci
alias: pci:v00008086d0000095Asvsd00005090bcsci
alias: pci:v00008086d0000095Asvsd00005420bcsci
alias: pci:v00008086d0000095Asvsd0000502Abcsci
alias: pci:v00008086d0000095Asvsd00005020bcsci
alias: pci:v00008086d0000095Asvsd00009410bcsci
alias: pci:v00008086d0000095Bsvsd00009310bcsci
alias: pci:v00008086d0000095Asvsd00009510bcsci
alias: pci:v00008086d0000095Bsvsd00009200bcsci
alias: pci:v00008086d0000095Bsvsd00009210bcsci
alias: pci:v00008086d0000095Asvsd00009112bcsci
alias: pci:v00008086d0000095Asvsd00009110bcsci
alias: pci:v00008086d0000095Asvsd0000900Abcsci
alias: pci:v00008086d0000095Asvsd00009012bcsci
alias: pci:v00008086d0000095Asvsd00009010bcsci
alias: pci:v00008086d0000095Bsvsd00005202bcsci
alias: pci:v00008086d0000095Asvsd00005102bcsci
alias: pci:v00008086d0000095Asvsd00005002bcsci
alias: pci:v00008086d0000095Bsvsd00005200bcsci
alias: pci:v00008086d0000095Asvsd0000500Abcsci
alias: pci:v00008086d0000095Asvsd00005000bcsci
alias: pci:v00008086d0000095Asvsd00001010bcsci
alias: pci:v00008086d0000095Asvsd00005400bcsci
alias: pci:v00008086d0000095Asvsd00005510bcsci
alias: pci:v00008086d0000095Asvsd00005410bcsci
alias: pci:v00008086d0000095Asvsd00005412bcsci
alias: pci:v00008086d0000095Asvsd00005012bcsci
alias: pci:v00008086d0000095Asvsd00005C10bcsci
alias: pci:v00008086d0000095Bsvsd00005210bcsci
alias: pci:v00008086d0000095Bsvsd00005302bcsci
alias: pci:v00008086d0000095Bsvsd00005310bcsci
alias: pci:v00008086d0000095Asvsd00005100bcsci
alias: pci:v00008086d0000095Asvsd00005110bcsci
alias: pci:v00008086d0000095Asvsd00005010bcsci
alias: pci:v00008086d000024FBsvsd00000000bcsci
alias: pci:v00008086d000024FBsvsd00002150bcsci
alias: pci:v00008086d000024FBsvsd00002050bcsci
alias: pci:v00008086d000024FBsvsd00002110bcsci
alias: pci:v00008086d000024FBsvsd00002010bcsci
alias: pci:v00008086d00003165svsd00008110bcsci
alias: pci:v00008086d00003165svsd00008010bcsci
alias: pci:v00008086d00003166svsd00004210bcsci
alias: pci:v00008086d00003166svsd00004310bcsci
alias: pci:v00008086d00003165svsd00004110bcsci
alias: pci:v00008086d00003165svsd00004510bcsci
alias: pci:v00008086d00003165svsd00004410bcsci
alias: pci:v00008086d00003166svsd00004212bcsci
alias: pci:v00008086d00003165svsd00004012bcsci
alias: pci:v00008086d00003165svsd00004010bcsci
alias: pci:v00008086d000008B3svsd00001170bcsci
alias: pci:v00008086d000008B3svsd00001070bcsci
alias: pci:v00008086d000008B3svsd00008570bcsci
alias: pci:v00008086d000008B3svsd00008470bcsci
alias: pci:v00008086d000008B4svsd00008272bcsci
alias: pci:v00008086d000008B4svsd00008370bcsci
alias: pci:v00008086d000008B4svsd00008270bcsci
alias: pci:v00008086d000008B3svsd00008062bcsci
alias: pci:v00008086d000008B3svsd00008060bcsci
alias: pci:v00008086d000008B3svsd00008172bcsci
alias: pci:v00008086d000008B3svsd00008170bcsci
alias: pci:v00008086d000008B3svsd00008072bcsci
alias: pci:v00008086d000008B3svsd00008070bcsci
alias: pci:v00008086d000008B4svsd00000370bcsci
alias: pci:v00008086d000008B3svsd00000472bcsci
alias: pci:v00008086d000008B3svsd00000470bcsci
alias: pci:v00008086d000008B4svsd00000272bcsci
alias: pci:v00008086d000008B4svsd00000270bcsci
alias: pci:v00008086d000008B3svsd00000062bcsci
alias: pci:v00008086d000008B3svsd00000060bcsci
alias: pci:v00008086d000008B3svsd00000172bcsci
alias: pci:v00008086d000008B3svsd00000170bcsci
alias: pci:v00008086d000008B3svsd00000072bcsci
alias: pci:v00008086d000008B3svsd00000070bcsci
alias: pci:v00008086d000008B1svsd0000C420bcsci
alias: pci:v00008086d000008B2svsd0000C220bcsci
alias: pci:v00008086d000008B1svsd0000C02Abcsci
alias: pci:v00008086d000008B1svsd0000C020bcsci
alias: pci:v00008086d000008B1svsd0000C360bcsci
alias: pci:v00008086d000008B2svsd0000C370bcsci
alias: pci:v00008086d000008B1svsd0000C560bcsci
alias: pci:v00008086d000008B1svsd0000C570bcsci
alias: pci:v00008086d000008B1svsd0000C462bcsci
alias: pci:v00008086d000008B1svsd0000C460bcsci
alias: pci:v00008086d000008B1svsd0000C472bcsci
alias: pci:v00008086d000008B1svsd0000C470bcsci
alias: pci:v00008086d000008B2svsd0000C262bcsci
alias: pci:v00008086d000008B2svsd0000C26Abcsci
alias: pci:v00008086d000008B2svsd0000C260bcsci
alias: pci:v00008086d000008B2svsd0000C272bcsci
alias: pci:v00008086d000008B1svsd0000CC60bcsci
alias: pci:v00008086d000008B1svsd0000CC70bcsci
alias: pci:v00008086d000008B2svsd0000C270bcsci
alias: pci:v00008086d000008B1svsd0000C760bcsci
alias: pci:v00008086d000008B1svsd0000C770bcsci
alias: pci:v00008086d000008B1svsd0000C162bcsci
alias: pci:v00008086d000008B1svsd0000C062bcsci
alias: pci:v00008086d000008B1svsd0000C160bcsci
alias: pci:v00008086d000008B1svsd0000C06Abcsci
alias: pci:v00008086d000008B1svsd0000C060bcsci
alias: pci:v00008086d000008B1svsd0000C170bcsci
alias: pci:v00008086d000008B1svsd0000C072bcsci
alias: pci:v00008086d000008B1svsd0000C070bcsci
alias: pci:v00008086d000008B1svsd00004420bcsci
alias: pci:v00008086d000008B2svsd00004220bcsci
alias: pci:v00008086d000008B1svsd0000402Abcsci
alias: pci:v00008086d000008B1svsd00004020bcsci
alias: pci:v00008086d000008B1svsd00005770bcsci
alias: pci:v00008086d000008B1svsd00005170bcsci
alias: pci:v00008086d000008B1svsd00005072bcsci
alias: pci:v00008086d000008B1svsd00005070bcsci
alias: pci:v00008086d000008B2svsd00004360bcsci
alias: pci:v00008086d000008B2svsd00004370bcsci
alias: pci:v00008086d000008B1svsd00004560bcsci
alias: pci:v00008086d000008B1svsd00004570bcsci
alias: pci:v00008086d000008B1svsd00004A6Cbcsci
alias: pci:v00008086d000008B1svsd00004A6Ebcsci
alias: pci:v00008086d000008B1svsd00004A70bcsci
alias: pci:v00008086d000008B1svsd0000486Ebcsci
alias: pci:v00008086d000008B1svsd00004870bcsci
alias: pci:v00008086d000008B1svsd00004462bcsci
alias: pci:v00008086d000008B1svsd0000446Abcsci
alias: pci:v00008086d000008B1svsd00004460bcsci
alias: pci:v00008086d000008B1svsd00004472bcsci
alias: pci:v00008086d000008B1svsd00004470bcsci
alias: pci:v00008086d000008B2svsd00004262bcsci
alias: pci:v00008086d000008B2svsd0000426Abcsci
alias: pci:v00008086d000008B2svsd00004260bcsci
alias: pci:v00008086d000008B2svsd00004272bcsci
alias: pci:v00008086d000008B2svsd00004270bcsci
alias: pci:v00008086d000008B1svsd00004162bcsci
alias: pci:v00008086d000008B1svsd00004062bcsci
alias: pci:v00008086d000008B1svsd00004160bcsci
alias: pci:v00008086d000008B1svsd0000406Abcsci
alias: pci:v00008086d000008B1svsd00004060bcsci
alias: pci:v00008086d000008B1svsd00004C70bcsci
alias: pci:v00008086d000008B1svsd00004C60bcsci
alias: pci:v00008086d000008B1svsd00004170bcsci
alias: pci:v00008086d000008B1svsd00004072bcsci
alias: pci:v00008086d000008B1svsd00004070bcsci
depends: compat,cfg80211
retpoline: Y
vermagic: 5.9.0-050900-generic SMP mod_unload
parm: debug:debug output mask (uint)
parm: xvt_default_mode:xVT is the default operation mode (default: false) (bool)
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_msix:Disable MSI-X and use MSI instead (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
wifitsn@for1793:~$ lsmod | grep iwlwifi
iwlwifi 393216 1 iwlmvm
cfg80211 753664 3 iwlmvm,iwlwifi,mac80211
compat 16384 4 iwlmvm,iwlwifi,mac80211,cfg80211
Step 4: ...................................................................
wifitsn@for1793:~$ sudo dmesg | grep "no suitable firmware found!"
wifitsn@for1793:~$
No Output. So suitable firmware is being used
5.wifitsn@for1793:~$ sudo dmesg | grep ASSERT
wifitsn@for1793:~$
No output. So attached a trace-cmd output (Step5)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello RS19104, Thank you very much for providing that information and the reports.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello RS19104, I just received an update on this matter.
I sent you an email, please verify your inbox.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello RS19104, I just wanted to check if you received the email that I sent you and if you need further assistance on this matter?
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Dear Alberto,
I confirm that the problem has been solved. The board now works well. We have upgraded the kernels to 5.11.6 and the microcode to .59.
Best Regards and thank you,
Rute Sofia
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi RS19104, Thank you very much for sharing those updates.
Perfect, excellent, it is great to hear that the problem got fixed after upgrading the kernels to 5.11.6 and the microcode to .59. Thank you also for sharing the solution on this forum, we are sure it will be very helpful for all the peers viewing this thread.
Any other inquires, do not hesitate to contact us again.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
What was the fix for this? I am trying to get an AX201 to work on a system where AX200 and AX210 failed also. Thanks.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello
upgrade to kernel 5.11.6
upgrade the used microcode to .59 (iwlwifi-mvm)
We see some problems with the rates sometimes (not clear if it is a problem with the boards or hostapd as the documentation does not help), but it works.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I might have found the problem but I don't know how to test it. Ubuntu is trying to load the iwlwifi-QuZ- microcode instead of iwlwifi-Qu-. I attempted to delete all of the iwlwifi-QuZ but then the AX201 isn't recognized at all and no firmware is loaded until I restore the iwlwifi-QuZ. Dmesg shows that it's failing to load QuZ but then loads it anyways, apparently never bothering with the Qu.
[ 260.680868] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-39.ucode failed with error -2
[ 260.680871] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-QuZ-a0-hr-b0-39
[ 260.680872] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-QuZ-a0-hr-b0-59
[ 431.980657] iwlwifi 0000:00:14.3: loaded firmware version 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode op_mode iwlmvm
[ 628.057550] iwlwifi 0000:00:14.3: Queue 4 is stuck 2 4
[ 628.057584] iwlwifi 0000:00:14.3: Queue 5 is stuck 1 153
[ 628.057836] iwlwifi 0000:00:14.3: Loaded firmware version: 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode
Btw, dmesg shows that it is being detected as an AX201:
[ 432.012713] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi, in my case using that kernel and even that firmware does not work. Reg domain can't be changed and then, AP mode for 5Ghz will not work.
There must be a way to disable DRS/LAR in Linux with newer kernels...
Anyway in Intel can reply to this please? @Alberto_Sykes
