Wireless
8532 Discussions
Intel AX201 Wifi Disconnects from the router suddenly
MSK1
My Intel AX201 wifi Disconnects from the internet all of a sudden I have 2 internet connections and it just doesn't stay on on any of the networks, I am also using an older laptop which does not have any problem with the connection, my wifi routers are both n type btw, none of the other devices are having any issue with either of the routers only my DELL G15 5511 laptop is having this issue, I am using latest drivers as well, I have also attached the SSU file. I am desperate to find a solution for this, please help! Thank you!
Carlos_L_Intel
Hi @MSK1,
 Thank you for your help. Is there anything else we could help with, or should we close this thread?
Carlos L.
MSK1
Hi @Carlos_L_Intel
You can close this thread, I will have to keep searching for the solution to my problem, Thank you!
Carlos_L_Intel
Hi @MSK1,
 Thank you for all your help. I will proceed to close this case. Please keep in mind that this thread will no longer be monitored by Intel.
Carlos L.
