Wireless
8523 Discussions
Intel AX201 trigger high frequent Event ID 7025
sea72
I have bought a brand-new lenovo laptop. And these days , I found that there are thousands of 7025 events in event viewer by accident.
The log shows that Event ID 7025 is  triggered by Netwtw10 (AX201) about every 20 seconds during sleep status.
I am not sure if such a hight frequent event is normal.
And if it's not normal, is it a hardware fault? Because I have installed different drivers from Intel and laptop manufacturer, the results are the same.
David_G_Intel
Hello sea72
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Are you having issues on Wifi or Bluetooth or both?
  • When did it start to happen?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • What OS version are you using?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
  • Have tried a roll back to a previous driver version for testing?
  • Provide the Intel® System Support Utility (Intel® SSU) results
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
