Wireless
8899 討論
Intel AX210 Upload speed extremely low
Chris20
初學者
6,516 檢視
Recently I upgraded my notebook PCs (Lenovo ThinkPad E580 and Lenovo Legion Y530, both running Windows 11 Pro build 22000.832 with the latest updates installed) with Intel AX210NGW Wi-Fi cards.
Naturally, I downloaded the latest drivers from Intel’s website.
The main problem is… Upload speed of these cards is extremely low, approximately 5 Mbps on a 5 GHz ax network. Just for comparison, my Samsung Galaxy S22 Ultra can achieve almost 1000 Mbps on the same network and physical location.
Any ideas what could cause this issue? I tried swapping the cards, even performed a clean Windows install on one of the PCs. Needless to say, it didn’t help.
These are the settings in Windows Device Manager for the cards.
802.11a/b/g Wireless Mode
  1. Dual Band 802.11a/b/g
802.11n/ac/ax Wireless Mode
  1. 802.11ax
ARP offload for WoWLAN
Enabled
Channel Width for 2.4GHz
Auto
Channel Width for 5GHz
Auto
Channel Width for 6GHz
Auto
Fat channel intolerant
Disabled
GTK rekeying for WoWLAN
Enabled
MIMO power save mode
No SMPS
Mixed mode protection
CTS-to-self Enabled
NS offload for WoWLAN
Enabled
Packet Coalescing
Disabled
Preferred band
No Preference
Roaming aggressiveness
  1. Lowest
Sleep on WoWLAN disconnect
Disabled
Throughput Booster
Enabled
Transmit power
  1. Highest
U-APSD support
Disabled
Ultra High Band (6GHz)
Enabled
Wake on magic packet
Enabled
Wake on pattern match
Enabled
0 積分
3 回應
Jean_Intel
員工
6,467 檢視
Hello Chris20,
As you mentioned that you upgraded your wireless adapters, you should understand that it may not work due to hardware or software compatibility issues or dependencies. Your system manufacturer may have altered the features, incorporated customizations, or made other changes to the software or hardware packaging they provide. Also, each country may have different regulatory requirements; before you install/change the Intel® Wireless Adapter in a system, you must contact the system manufacturer to determine if the Intel® Wireless Adapters you plan to install are approved for use in your system and country.
Jean O.
adamerso
初學者
5,645 檢視
I've got similar issues with stock wireless properties. Strangely, download works flawlessly, ookla shows 300mbit/s as my fiber connection to internet, but upload is terrible... 2mbit (!). Access points are one with ax delivered by ISP (and works great with everything), 2nd is apple airport extreme 6th gen (ac). Card is chinese mini-pci card retrofitted into precision m4800.
UP/DW speed difference is absolutely insane...
I'm on current 22.250.1.2 driver, windows 2022 server.
EDIT: After replacing back to 7260 AC download drops to about 150, but upload shows my max upload from ISP, which is 50mbps. So antennas aren't damaged during installation. It must be faulty batch of cards....
adamerso
初學者
5,600 檢視
I've tried the same card on another, even older laptop - lattitude E6220. Strangely - card works flawless. Upload same as my ISP - 50mbps. Very strange, since I'm quite sure, that precision m4800 has got better antennas... I'm very surprised that 5ghz works such good in such old notebook, which has 6205 from factory I'm using win10 with same 22.250.1.2 driver... May be that issue of windows 2022 server, which is installed on precision?
回覆
