Wireless
8787 Discussions
Intel AX210 does not report RX bitrate for 'ax' standard
Tonny_
I'm facing an issue on Ubuntu 22.04 linux where there is no information reported about RX bitrate when iw dev [interface] link command is invoked during operating in 'ax' standard - HE mode.
Instead of phy rate, MCS, NSS etc. only bandwidth is reported preceded by "(unknown)" comment.
For 'ac' standard - VHT - every single parameter is reported as expected for both TX / RX.
It was checked on couple of AP's with the same result.
logs:
iw link command result for 'ax' standard:
Connected to dc:0b:1a:bf:13:03 (on wlp3s0)
SSID: xxx
freq: 5220
RX: 5943 bytes (35 packets)
TX: 5900 bytes (39 packets)
signal: -46 dBm
rx bitrate: (unknown) 160MHz
tx bitrate: 490.0 MBit/s 160MHz HE-MCS 3 HE-NSS 2 HE-GI 2 HE-DCM 0
bss flags: short-slot-time
dtim period: 1
beacon int: 100
'ac' standard:
Connected to e2:55:6d:20:39:51 (on wlp3s0)
SSID: xxx
freq: 5220
RX: 667181 bytes (3134 packets)
TX: 88128 bytes (1171 packets)
signal: -78 dBm
rx bitrate: 60.0 MBit/s VHT-MCS 1 40MHz short GI VHT-NSS 2
tx bitrate: 26.0 MBit/s VHT-MCS 3 VHT-NSS 1
dtim period: 1
beacon int: 100
my config:
dmesg | grep iwlwifi
[ 3.884790] Loading modules backported from iwlwifi
[ 3.884793] iwlwifi-stack-public:master:9858:4c7cba27
[ 3.962393] iwlwifi 0000:03:00.0: enabling device (0100 -> 0102)
[ 3.984767] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 3.984784] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 3.985088] iwlwifi 0000:03:00.0: loaded firmware version 73.35c0a2c6.0 ty-a0-gf-a0-73.ucode op_mode iwlmvm:
[ 4.028099] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.203425] iwlwifi 0000:03:00.0: loaded PNVM version 881c99e1
[ 4.214798] iwlwifi 0000:03:00.0: Detected RF GF, rfid=0x10d000
[ 4.284759] iwlwifi 0000:03:00.0: base HW address: a0:e7:0b:3c:f9:d3
[ 4.304443] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
modinfo iwlwifi
modinfo:
filename: /lib/modules/5.15.0-52-generic/ubuntu/iwlwifi/iwlwifi.ko
version: iwlwifi-stack-public:master:9858:4c7cba27
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-BzBnj-a0-fm-b0-73.ucode
firmware: iwlwifi-gl-b0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-hr-b0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm-a0-73.ucode
firmware: iwlwifi-gl-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-mr-a0-73.ucode
firmware: iwlwifi-bz-a0-gf4-a0-73.ucode
firmware: iwlwifi-bz-a0-gf-a0-73.ucode
firmware: iwlwifi-bz-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-fm-a0-73.ucode
firmware: iwlwifi-ma-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-gf4-a0-73.ucode
firmware: iwlwifi-ma-a0-gf-a0-73.ucode
firmware: iwlwifi-ma-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-jf-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-ty-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-hr-b0-73.ucode
firmware: iwlwifi-so-a0-jf-b0-73.ucode
firmware: iwlwifi-cc-a0-73.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-jf-b0-73.ucode
firmware: iwlwifi-Qu-c0-hr-b0-73.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-hr-b0-73.ucode
srcversion: C8C035BF98B2B803370CFB9
depends: compat,cfg80211
retpoline: Y
vermagic: 5.15.0-52-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 49:B2:3F:66:E1:3B:8B:67:11:CE:17:63:41:27:D0:B1:28:DF:09:8C
sig_hashalgo: sha512
signature: A9:8C:84:22:75:B5:86:10:42:06:52:43:A4:CA:03:C1:9B:45:09:FC:
3F:65:EC:79:BA:17:C6:B6:21:D0:91:34:98:45:0E:0E:57:FD:D0:17:
56:5F:69:88:D1:A3:75:14:6C:B1:B3:EE:39:E0:74:31:47:DF:0D:3D:
D1:94:4D:A3:85:73:6F:26:A5:4E:9A:B9:7A:2B:8E:78:13:41:EF:F6:
F4:D8:A9:5A:1F:80:2F:C5:3B:E2:16:B7:26:0D:8E:0C:03:DA:F4:60:
8D:95:E2:99:C9:49:0F:BC:EB:83:43:0F:CD:EC:24:A1:49:67:5B:D7:
DE:9C:72:82:87:A9:FB:D3:AF:4D:53:29:4F:48:2B:B3:E1:AC:8E:6C:
BF:4E:36:5E:0D:05:8E:F1:C9:1F:63:79:0E:3D:B2:E8:20:2E:36:8B:
B9:68:64:51:D7:09:7D:CF:4F:74:73:0B:DF:C3:E5:F7:0D:79:33:75:
8C:F7:42:4D:32:0A:4C:5B:F6:78:13:10:9A:DE:B3:48:83:92:35:69:
80:70:EB:5A:CB:7B:D1:E7:94:C4:3B:66:42:FA:E1:73:82:BA:41:BA:
0E:CA:21:0F:7E:36:49:FB:18:77:C8:DC:D2:19:2C:88:A4:7D:B4:2C:
0E:20:8E:56:3E:2B:C3:B2:F6:86:7E:D0:54:FE:21:92:7C:EA:A6:65:
59:5F:B6:07:A6:FF:76:3F:D1:02:76:5B:58:19:15:AD:F7:3E:4B:20:
17:C6:6E:54:9C:9D:52:94:C9:CB:D3:6A:3F:9C:ED:E8:52:B0:F6:FC:
A7:51:CE:09:23:1E:97:C5:EC:0D:A7:A3:8D:27:29:8A:84:B9:A5:10:
EA:42:50:7F:C8:56:22:80:D0:38:4C:24:B1:F0:27:58:99:25:DB:98:
DA:B0:48:AB:1F:9B:B0:EE:80:1E:88:BB:9C:8B:02:36:AD:C3:2A:F7:
CA:2E:70:EE:A0:0D:78:96:13:91:C8:51:DD:A0:B3:5D:CE:AB:11:CB:
08:76:C5:87:55:2A:33:7C:87:A9:53:45:28:DC:AF:C4:21:18:B5:1E:
1E:5C:B8:05:4C:12:28:BD:25:4E:3C:45:B7:C9:F4:3C:E3:22:12:43:
FA:57:36:63:DB:8B:06:B6:7E:55:50:9F:F2:09:2D:80:A3:93:C7:B6:
66:91:AD:7B:54:BC:70:B9:4A:92:AD:93:F4:7D:FC:70:07:CE:89:79:
D7:DF:09:C0:63:D2:1E:1B:E8:E5:DB:24:64:FE:A0:68:35:C3:0E:4A:
28:DB:9E:01:AE:16:5A:01:87:42:72:80:07:95:CF:24:01:FD:A3:55:
AC:C4:5A:A2:27:BF:1B:AB:DF:D5:3A:73
parm: debug:debug output mask (uint)
parm: xvt_default_mode:xVT is the default operation mode (default: false) (bool)
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_msix:Disable MSI-X and use MSI instead (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
Jean_Intel
Hello Tonny_,
Thank you for posting on the Intel️® communities. I understand you are having issues with the Intel AX210.
  • Provide me with the kernel version you are using. You can use the $ hostnamectl to confirm this information.
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • You mentioned that the report RX bitrate is not correct for the 'AX' standard, and Instead of PHY rate, MCS, NSS, etc. only bandwidth is reported preceded by a "(unknown)" comment. Is this the only issue/error message you face?
  • Is your connectivity performance being affected?
Jean O.
Tonny_
regarding to your questions:
1. hostnamectl response:
Icon name: computer-desktop
Chassis: desktop
Machine ID: 3440ddcd7c2f4f068a5ca9d0a00ef3e3
Boot ID: e7dbe250279a4da1920c1bcfc9af6e3d
Operating System: Ubuntu 22.04.1 LTS
Kernel: Linux 5.15.0-52-generic
Architecture: x86-64
Hardware Vendor: Dell Inc.
Hardware Model: OptiPlex 7080
It was also checked on some other PC equipped with different piece of AX210 M.2 module with the same Ubuntu distro but kernel version 5.15.0-48, RX reporting issue were also visible there.
2. This is not originally installed adapter on this machine.
3. Till now this is the only issue I'm facing.
4. Regarding tput performance it seems to be not affected.
regards
Jean_Intel
Hello Tonny_,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues
Jean O.
Jean_Intel
Hello Tonny_,
Thanks for waiting for a response.
After taking a look at the information, I noticed that you are using an older kernel 5.15. My suggestion is to update the latest (and stable) kernel 6.0 to check the RX bitrate.
Jean O.
Tonny_
Hi Jean O,
is your suggestion based on some checking approach with such kernel version where you didn't notice issue or is some general advice that might help?
I'm asking about because I would rather avoid the situation when I change a kernel on affected PC that is a part of some test bench taking then a risk that it may impact other system properties / interfaces on this machine.
regards
Jean_Intel
Hello Tonny_,
I understand your concern about updating the kernel. However, it is important to keep your system up to date; so you can have the latest features and solutions, as it may solve your issue. Also, it would be ideal to do so, as it is necessary to further investigate this matter.
Jean O.
Jean_Intel
Hello Tonny_,
I hope you are doing fine.
Jean O.
Tonny_
Hi Jean O.,
no, not yet, as I mentioned, PC with this module is a part of some test bench which neverthless is still in use, I would have to play with this on some another machine with similar setup, I will let you know when it happens.
In the meantime another question araised so I ask it here:
could you advise what parameter is responsible for 40MHz intolerance (fat channel) setting in iwlwifi module ( on linux Ubuntu) in order to change what is sent in probe request?  Wireshark annotation for this parameter is 'HT Forty MHz Intolerant:'.
I've tried with 'cfg80211_disable_40mhz_24ghz' found here:
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
but iwlwifi log says that this is unknown parameter so it is skipped.
regards
Jean_Intel
Hello Tonny_,
Thanks for your response.
I will do further research on this matter and post the response to your question once available.
Jean O.
Jean_Intel
Hello Tonny_,
On newer Intel wireless products driven by iwlmvm, the 40MHz intolerance (fat channel) setting/configuration is not supported in the iwlwifi module.
On the other hand, have you tried updating to kernel 6.0 and checked the RX bitrate?
Jean O.
Tonny_
Hi Jean O.,
finally I was able to prepare and apply interested configuration to some other machine and it seems that kernel upgrade with of course iwlwifi driver appropriate for that kernel helps, now RX statistics are properly reported.
At first glance performance is also ok with no side effects but no to much time spent for testing currently.
Regarding fat channel is this option depreciated and not available since now or such support might be added in the future when requested?
My current configuration which works is:
kernel:
root@hardware-Lenovo-S510:/home/hardware# uname -mrs
Linux 6.0.0-060000-generic x86_64
dmesg | grep iwlwifi:
[ 3.354711] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.374560] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-72.ucode failed with error -2
[ 3.383369] iwlwifi 0000:01:00.0: api flags index 2 larger than supported by driver
[ 3.383974] iwlwifi 0000:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 3.386107] iwlwifi 0000:01:00.0: loaded firmware version 71.058653f6.0 ty-a0-gf-a0-71.ucode op_mode iwlmvm
[ 3.679810] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 3.858176] iwlwifi 0000:01:00.0: loaded PNVM version 05a8dfca
[ 3.873399] iwlwifi 0000:01:00.0: Detected RF GF, rfid=0x10d000
[ 3.943801] iwlwifi 0000:01:00.0: base HW address: f4:7b:09:f0:88:8b
[ 3.965325] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan1
modinfo iwlwifi:
root@hardware-Lenovo-S510:/home/hardware# modinfo iwlwifi
filename: /lib/modules/6.0.0-060000-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-BzBnj-a0-hr-b0-72.ucode
firmware: iwlwifi-BzBnj-a0-gf4-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-gf-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-fm4-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-fm-a0-72.ucode
firmware: iwlwifi-gl-a0-fm-a0-72.ucode
firmware: iwlwifi-bz-a0-fm-a0-72.ucode
firmware: iwlwifi-bz-a0-mr-a0-72.ucode
firmware: iwlwifi-bz-a0-gf4-a0-72.ucode
firmware: iwlwifi-bz-a0-gf-a0-72.ucode
firmware: iwlwifi-bz-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-72.ucode
firmware: iwlwifi-ma-a0-fm-a0-72.ucode
firmware: iwlwifi-ma-a0-mr-a0-72.ucode
firmware: iwlwifi-ma-a0-gf4-a0-72.ucode
firmware: iwlwifi-ma-a0-gf-a0-72.ucode
firmware: iwlwifi-ma-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-jf-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-72.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-72.ucode
firmware: iwlwifi-ty-a0-gf-a0-72.ucode
firmware: iwlwifi-so-a0-gf-a0-72.ucode
firmware: iwlwifi-so-a0-hr-b0-72.ucode
firmware: iwlwifi-so-a0-jf-b0-72.ucode
firmware: iwlwifi-cc-a0-72.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-72.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-72.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-72.ucode
firmware: iwlwifi-Qu-b0-jf-b0-72.ucode
firmware: iwlwifi-Qu-c0-hr-b0-72.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-72.ucode
firmware: iwlwifi-Qu-b0-hr-b0-72.ucode
srcversion: 9CD80B126242D88084FF72D
alias: pci:v00008086d00007740sv*sd*bc*sc*i*
alias: pci:v00008086d0000A840sv*sd*bc*sc*i*
alias: pci:v00008086d00002727sv*sd*bc*sc*i*
alias: pci:v00008086d00007E40sv*sd*bc*sc*i*
alias: pci:v00008086d00002729sv*sd*bc*sc*i*
alias: pci:v00008086d00007F70sv*sd*bc*sc*i*
alias: pci:v00008086d000054F0sv*sd*bc*sc*i*
alias: pci:v00008086d000051F1sv*sd*bc*sc*i*
alias: pci:v00008086d000051F0sv*sd*bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias: pci:v00008086d00007A70sv*sd*bc*sc*i*
alias: pci:v00008086d00002726sv*sd*bc*sc*i*
alias: pci:v00008086d00002725sv*sd*bc*sc*i*
alias: pci:v00008086d00002723sv*sd*bc*sc*i*
alias: pci:v00008086d00002720sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias: pci:v00008086d000043F0sv*sd*bc*sc*i*
alias: pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000034F0sv*sd*bc*sc*i*
alias: pci:v00008086d000006F0sv*sd*bc*sc*i*
alias: pci:v00008086d000002F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000A370sv*sd*bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000031DCsv*sd*bc*sc*i*
alias: pci:v00008086d000030DCsv*sd*bc*sc*i*
alias: pci:v00008086d0000271Csv*sd*bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002526sv*sd*bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias: pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias: pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias: pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias: pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias: pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias: pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias: pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 6.0.0-060000-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
sig_key: 67:B8:98:F0:2E:AA:6D:ED:6C:DD:66:0E:C5:39:48:B2:10:48:AD:65
signature: 65:FF:21:75:50:E7:7A:62:A3:4E:AE:8C:D6:C6:64:13:B6:C9:48:90:
82:8E:3F:F9:88:B0:D9:20:B0:BD:8A:F2:0D:00:F9:FF:8F:FC:B6:BD:
E1:40:60:BE:7C:7A:69:D1:71:71:97:99:1F:D6:95:FC:9E:3D:7C:74:
78:5A:8F:A8:FC:46:6B:61:D2:B2:3D:D3:4B:19:96:FE:C0:3F:83:01:
37:44:2B:FB:6D:B3:A1:D5:83:FF:0C:DF:BE:86:93:3C:59:E8:C0:F1:
93:DB:9C:C6:76:75:95:94:FE:9B:75:5D:D2:C8:9C:34:3E:37:25:53:
C8:B7:25:7A:E9:B7:BE:4F:71:A6:D1:35:B7:B2:36:50:18:55:DA:41:
B6:96:FE:1B:C1:C8:05:7C:70:68:0A:1E:DC:4C:24:2D:66:C2:D1:C5:
26:C5:D4:79:97:E6:DD:0D:F5:CE:31:FC:1C:69:F8:A6:E1:20:BF:54:
ED:6E:9E:40:AD:15:1B:35:E2:E0:E7:D8:13:CB:9A:56:F1:56:FC:08:
44:2C:58:EA:69:8F:DC:B9:13:DC:01:4F:71:30:FE:74:E9:B0:3A:EC:
11:D6:43:36:8C:F2:C8:9C:87:60:B5:F3:6D:91:EB:72:85:DA:7D:DE:
BD:80:2A:DE:3E:9B:D1:D7:A6:77:90:A2:16:46:B7:11:79:7D:F0:84:
03:50:8D:07:5E:AB:B6:09:16:89:78:F7:B5:6A:17:90:16:6E:80:06:
1C:68:AB:A6:D9:D3:92:B5:FF:B5:23:19:A5:DE:05:32:B7:57:4B:95:
CC:BC:D5:AE:1B:EB:28:FF:2C:71:19:45:5A:9F:7E:7E:B5:4D:A6:0D:
99:36:58:48:6D:E0:47:54:9A:E7:9C:4C:F3:7D:96:35:5D:4D:65:40:
6E:C5:63:CC:75:9E:17:8C:8B:52:40:25:63:67:46:98:5A:13:CD:56:
C3:7D:70:38:98:53:F9:C9:93:E7:1F:A1:CF:EB:6C:DB:C7:09:54:0C:
5E:47:E8:2E:88:F6:E0:15:26:1E:18:AC:41:1C:A7:DB:E9:A5:72:C2:
74:E0:7C:16:4F:50:3B:A9:64:5A:17:96:FC:EF:61:52:CC:B1:58:9F:
10:0E:70:27:A2:83:8B:36:95:E8:6F:AC:F3:F2:4B:E4:30:55:BE:47:
31:67:EB:79:58:B8:0F:0E:FA:A5:3F:5B:11:2F:34:B2:14:71:08:77:
92:1F:38:69:72:57:20:F0:0A:FE:6F:30:89:AC:3E:57:58:AA:2C:07:
AD:84:4C:BB:BF:6C:68:FE:2B:D8:A9:A2:48:11:4F:A4:8B:19:D8:E7:
FC:25:5F:2B:A1:4C:AC:AD:22:98:39:56
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
regards
Jean_Intel
Hello Tonny_,
Jean O.
Tonny_
Hi Jean O.
Regarding fat channel is this option depreciated and won't be available since now or support for it might be added in the future when requested?
Configuration which works now is as follows:
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
regards
Tonny_
Hi Jean O.
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
regards
Tonny_
Hi Jean O.
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
regards
Tonny_
Hi Jean O.
kernel:
modinfo iwlwifi:
license: GPL
depends: cfg80211
retpoline: Y
intree: Y
sig_id: PKCS#7
regards
Jean_Intel
Hello Tonny_,
Let us look into this and we will get back to you at our earliest convenience with a response to your question.
Jean O.
Tonny_
Hi Jean O.
sorry for mess in the ticket but I had a problems with adding my comments here. I have tried many times but they were not visible, now they all show up. I can't edit or remove them so it looks totally mess.
regards
Jean_Intel
Hello Tonny_,
This option is not considered to be supported. We will pass the information on and submit this request to the corresponding team in charge. Let us know if you have any questions. It is important to mention that we can't guarantee it will be approved.
Jean O.
Tonny_
Hi Jean O.
ok, I understand it.
Can such of request be somewhere tracked to check its state?
regards
