Wireless
8554 Discussions
Intel AX210 does not report RX bitrate for 'ax' standard
Tonny_
I'm facing an issue on Ubuntu 22.04 linux where there is no information reported about RX bitrate when iw dev [interface] link command is invoked during operating in 'ax' standard - HE mode.
Instead of phy rate, MCS, NSS etc. only bandwidth is reported preceded by "(unknown)" comment.
For 'ac' standard - VHT - every single parameter is reported as expected for both TX / RX.
It was checked on couple of AP's with the same result.
logs:
iw link command result for 'ax' standard:
Connected to dc:0b:1a:bf:13:03 (on wlp3s0)
SSID: xxx
freq: 5220
RX: 5943 bytes (35 packets)
TX: 5900 bytes (39 packets)
signal: -46 dBm
rx bitrate: (unknown) 160MHz
tx bitrate: 490.0 MBit/s 160MHz HE-MCS 3 HE-NSS 2 HE-GI 2 HE-DCM 0
bss flags: short-slot-time
dtim period: 1
beacon int: 100
'ac' standard:
Connected to e2:55:6d:20:39:51 (on wlp3s0)
SSID: xxx
freq: 5220
RX: 667181 bytes (3134 packets)
TX: 88128 bytes (1171 packets)
signal: -78 dBm
rx bitrate: 60.0 MBit/s VHT-MCS 1 40MHz short GI VHT-NSS 2
tx bitrate: 26.0 MBit/s VHT-MCS 3 VHT-NSS 1
dtim period: 1
beacon int: 100
my config:
dmesg | grep iwlwifi
[ 3.884790] Loading modules backported from iwlwifi
[ 3.884793] iwlwifi-stack-public:master:9858:4c7cba27
[ 3.962393] iwlwifi 0000:03:00.0: enabling device (0100 -> 0102)
[ 3.984767] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 3.984784] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 3.985088] iwlwifi 0000:03:00.0: loaded firmware version 73.35c0a2c6.0 ty-a0-gf-a0-73.ucode op_mode iwlmvm:
[ 4.028099] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.203425] iwlwifi 0000:03:00.0: loaded PNVM version 881c99e1
[ 4.214798] iwlwifi 0000:03:00.0: Detected RF GF, rfid=0x10d000
[ 4.284759] iwlwifi 0000:03:00.0: base HW address: a0:e7:0b:3c:f9:d3
[ 4.304443] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
modinfo iwlwifi
modinfo:
filename: /lib/modules/5.15.0-52-generic/ubuntu/iwlwifi/iwlwifi.ko
version: iwlwifi-stack-public:master:9858:4c7cba27
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-BzBnj-a0-fm-b0-73.ucode
firmware: iwlwifi-gl-b0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-hr-b0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm-a0-73.ucode
firmware: iwlwifi-gl-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-mr-a0-73.ucode
firmware: iwlwifi-bz-a0-gf4-a0-73.ucode
firmware: iwlwifi-bz-a0-gf-a0-73.ucode
firmware: iwlwifi-bz-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-fm-a0-73.ucode
firmware: iwlwifi-ma-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-gf4-a0-73.ucode
firmware: iwlwifi-ma-a0-gf-a0-73.ucode
firmware: iwlwifi-ma-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-jf-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-ty-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-hr-b0-73.ucode
firmware: iwlwifi-so-a0-jf-b0-73.ucode
firmware: iwlwifi-cc-a0-73.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-jf-b0-73.ucode
firmware: iwlwifi-Qu-c0-hr-b0-73.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-hr-b0-73.ucode
srcversion: C8C035BF98B2B803370CFB9
depends: compat,cfg80211
retpoline: Y
vermagic: 5.15.0-52-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 49:B2:3F:66:E1:3B:8B:67:11:CE:17:63:41:27:D0:B1:28:DF:09:8C
sig_hashalgo: sha512
signature: A9:8C:84:22:75:B5:86:10:42:06:52:43:A4:CA:03:C1:9B:45:09:FC:
3F:65:EC:79:BA:17:C6:B6:21:D0:91:34:98:45:0E:0E:57:FD:D0:17:
56:5F:69:88:D1:A3:75:14:6C:B1:B3:EE:39:E0:74:31:47:DF:0D:3D:
D1:94:4D:A3:85:73:6F:26:A5:4E:9A:B9:7A:2B:8E:78:13:41:EF:F6:
F4:D8:A9:5A:1F:80:2F:C5:3B:E2:16:B7:26:0D:8E:0C:03:DA:F4:60:
8D:95:E2:99:C9:49:0F:BC:EB:83:43:0F:CD:EC:24:A1:49:67:5B:D7:
DE:9C:72:82:87:A9:FB:D3:AF:4D:53:29:4F:48:2B:B3:E1:AC:8E:6C:
BF:4E:36:5E:0D:05:8E:F1:C9:1F:63:79:0E:3D:B2:E8:20:2E:36:8B:
B9:68:64:51:D7:09:7D:CF:4F:74:73:0B:DF:C3:E5:F7:0D:79:33:75:
8C:F7:42:4D:32:0A:4C:5B:F6:78:13:10:9A:DE:B3:48:83:92:35:69:
80:70:EB:5A:CB:7B:D1:E7:94:C4:3B:66:42:FA:E1:73:82:BA:41:BA:
0E:CA:21:0F:7E:36:49:FB:18:77:C8:DC:D2:19:2C:88:A4:7D:B4:2C:
0E:20:8E:56:3E:2B:C3:B2:F6:86:7E:D0:54:FE:21:92:7C:EA:A6:65:
59:5F:B6:07:A6:FF:76:3F:D1:02:76:5B:58:19:15:AD:F7:3E:4B:20:
17:C6:6E:54:9C:9D:52:94:C9:CB:D3:6A:3F:9C:ED:E8:52:B0:F6:FC:
A7:51:CE:09:23:1E:97:C5:EC:0D:A7:A3:8D:27:29:8A:84:B9:A5:10:
EA:42:50:7F:C8:56:22:80:D0:38:4C:24:B1:F0:27:58:99:25:DB:98:
DA:B0:48:AB:1F:9B:B0:EE:80:1E:88:BB:9C:8B:02:36:AD:C3:2A:F7:
CA:2E:70:EE:A0:0D:78:96:13:91:C8:51:DD:A0:B3:5D:CE:AB:11:CB:
08:76:C5:87:55:2A:33:7C:87:A9:53:45:28:DC:AF:C4:21:18:B5:1E:
1E:5C:B8:05:4C:12:28:BD:25:4E:3C:45:B7:C9:F4:3C:E3:22:12:43:
FA:57:36:63:DB:8B:06:B6:7E:55:50:9F:F2:09:2D:80:A3:93:C7:B6:
66:91:AD:7B:54:BC:70:B9:4A:92:AD:93:F4:7D:FC:70:07:CE:89:79:
D7:DF:09:C0:63:D2:1E:1B:E8:E5:DB:24:64:FE:A0:68:35:C3:0E:4A:
28:DB:9E:01:AE:16:5A:01:87:42:72:80:07:95:CF:24:01:FD:A3:55:
AC:C4:5A:A2:27:BF:1B:AB:DF:D5:3A:73
parm: debug:debug output mask (uint)
parm: xvt_default_mode:xVT is the default operation mode (default: false) (bool)
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_msix:Disable MSI-X and use MSI instead (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
Jean_Intel
Hello Tonny_,
Thanks for your response.
This is an internal process worked by the corresponding team, and unfortunately, there is no way for you to track the request.
Jean O.
Jean_Intel
Hello Tonny_,
I hope you are doing fine.
Jean O.
Tonny_
Hi Jean O.
Yes, I read it, the only question left is how can I be informed about possibility of introducing ht40 intolerance support?
regards
Jean_Intel
Hello Tonny_,
Let us look into this and we will get back to you at our earliest convenience.
Jean O.
Jean_Intel
Hello Tonny_,
We have confirmed that this feature won't be supported.
Jean O.
Jean_Intel
Hello Graw,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
