- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I have installed AX210 on ubuntu 21.04 with kernel 5.11.0-41-generic, i can capture all control and mgmt packets but not Downlink Data packets (from AP to client)on 6Ghz band (11AX).
Note: I can capture Uplink data frames (from Client to AP).Iam using 20Mhz channel width.
On 5Ghz band with 11ax, i can capture everything (all control, mgmt packets and data packets).
I have tried setting "amsdu_size=3" option in "/etc/modprobe.d/iwlwifi.conf" file, but still couldn't capture the Downlink data packets on 6Ghz band.
Any pointers will be helpful.
pkts snippet:
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra,
Thank you for posting on the Intel
- Was it working before?
- Is this a desktop or a laptop?
- Is this the original wireless adapter of the system?
- Have you checked the issue with the Linux community?
Also, please download and install the Intel
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel
Click on "Next", save the report and attach it to your response.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Josue,
thanks for your help and support.
- Was it working before? Ans: No
- Is this a desktop or a laptop? Ans: Micro Desktop
- Is this the original wireless adapter of the system? Ans: No. Original config with AX200, I replaced with AX210.
- Have you checked the issue with the Linux community? Ans: No
Attached SSU summary.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Thank you for the information provided. In this case we would like to know if with the original adapter it was working without issues.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Josue,
Original adapter ax200 doesn't support 6E, so I changed to ax210 to capture 6E data packets.
-Satyendra.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
In this case, please share with us the following information:
1. Did you capture packets on a protected network (e.g. WPA3-SAE) and use the correct method to decrypt the 802.11 data?
e.g. For Wireshark: https://wiki.wireshark.org/HowToDecrypt802.11
2. You mentioned that your AX210 can capture everything on 5Ghz, do you use the same security (e.g. WPA3-SAE) on bott 5Ghz and 6Ghz?
Also, please try using the latest and stable kernel and check if the issue still occurs on newer wireless firmware (e.g. wireless firmware 66 in kernel 5.15).
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Were you able to check our previous message?
Please let us know if you are able to get the information requested.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Josue,
Ans: Yes, i used WPA3 SAE, OWE and 192bit. I see the same issue with all three security methods.
Ans: Yes
Regarding updating to the latest kernel, my ubuntu unit failed to update due to some dependency mismatch issues. Will give a try again and update you.
-Satyendra.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Thank you for the information provided, we will wait for you to try again updating the kernel. Let us know the results.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Were you able to test the system with the latest kernel?
Let us know if you still need our assistance.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Josue,
My ubuntu unit gone bad after kernel update failure. Trying to recover unit.
thanks
-Satyendra.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra,
Thank you for the information provided, we will wait for you to recover the unit.
In the meantime, please share with us the following information:
- May we know if you are working on some project for the company 'zebra.com' and found this issue? If so, what is the project and how many systems are impacted by this issue?
- What sniffer tool are you using? Please provide sniff commands and their output while enabling the monitor mode and performing the packet sniffing. And provide both passing (5GHz) and failing (6GHz) sniffer logs.
- What protocol or tool are you using for sniffing? e.g. If it's iPerf, please provide iPerf commands and output of both iPerf client and server. And is the monitor mode/packet sniffer on the 3rd system? i.e. Not on iPerf client or server system.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
Were you able to get the information requested in the previous post?
Let us know if you still require our assistance.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello satyendra
We have not heard back from you, so we will close this thread. Remember to contact the Ubuntu Community to get support with the errors you have on the OS, verify the steps to make the system work again.
Josue O.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
with ubuntu-21.10, issue is not seen.
Thanks for your support.
-Satyendra.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
