Wireless
8630 Discussions
Intel AX210 stop working with 3 or more displays
edoardocolella
Hello everyone.
I have a pcie wireless adapter in my computer.
It works very good, reaching 1Gbps with wifi connection.
When i tryed to connect a third display to my computer (i have a nvidia asus 3070ti) wifi stopped working with this adatper. I tried with a usb adatper and it works.
Can someone help me?
n_scott_pearson
Not sure if this is your issue, but it could be caused by a poor quality monitor cable.
Hope this helps,
edoardocolella
The video cable i used it's brand new and of course i tried with more cables.
I don't understand what could be the correlation monitors <-> wifi
Steven_Intel
Hello edoardocolella,
I am sorry you are having issues with your Intel® Wi-Fi 6E AX210, I will be glad to assist you.
In order to better assist you, please provide the following information:
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Are you able to use Bluetooth when the Wi-Fi is lost?
  • Is this a laptop or desktop system?
  • When the Wi-Fi is lost, are you able to see any error code in Device Manager > Network adapters > Intel® Wi-Fi 6E AX210? If there is any, you should also see a yellow sign along with the code.
  • Are you able to see the available networks when the Wi-Fi is lost?
Look forward to hearing back from you.
Steven G.
edoardocolella
Hi Steven
  • No, it is not original. It's a Ziyituod adapter PCIe
  • I can use Bluetooth when wifi is lost (I also transfered successfully some files from my pc and an other device)
  • It is a desktop system
  • I don't see any errors in Device Manager
  • I am able to see all the networks, it just stops working with message "Internet not available" (or something similiar, I use an Italian version of Windows)
Thank you for the help
Steven_Intel
Thank you for your detailed response.
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
edoardocolella
I am sorry, I forgot to answer.
I don't know how, but the problem resolved automatically.
Some days ago I connected HDMI and WiFi did not stop working.
Perfect
