Wireless
8532 Discussions
Intel BE200 802.11mc FTM support
rafixon
For my Master's Thesis I'm researching FTM enabled wireless network cards. As in the datasheet: Intel® Wi-Fi 7 BE200 (Gale Peak 2) Product Brief ID 761674 Date 2024-01-11 FTM support is listed. However after installing the following drivers on my machine: OS: Ubuntu 25.04 x86_64 with 6.14.0-23-generic kernel
root@ubuntu:~$ sudo dmesg | grep iwlwifi
[sudo] password for root:
[    2.261699] Loading modules backported from iwlwifi
[    2.261701] iwlwifi-stack-public:release/core96:13623:32dda3cc
[    3.916286] iwlwifi 0000:71:00.0: enabling device (0000 -> 0002)
[    3.984566] iwlwifi 0000:71:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[    3.984739] iwlwifi 0000:71:00.0: PCI dev 272b/00f0, rev=0x472, rfid=0x112200
[    3.984743] iwlwifi 0000:71:00.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
[    3.987300] iwlwifi 0000:71:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-99.ucode failed with error -2
[    3.991257] iwlwifi 0000:71:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-98.ucode failed with error -22
[    4.002331] iwlwifi 0000:71:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.196
[    4.004021] iwlwifi 0000:71:00.0: loaded firmware version 97.8049d69b.0 gl-c0-fm-c0-97.ucode op_mode iwlmld
[    4.926070] iwlwifi 0000:71:00.0: Detected RF FM, rfid=0x112200
[    4.928101] iwlwifi 0000:71:00.0: loaded PNVM version 8af7618d
[    4.956195] iwlwifi 0000:71:00.0: Sending Phy CFG command: 0x330018
[    5.053435] iwlwifi 0000:71:00.0: base HW address: 5c:b4:7e:35:24:4c
[    5.127950] iwlwifi 0000:71:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[    5.130976] iwlwifi 0000:71:00.0 wlp113s0f0: renamed from wlan0
[    6.437578] iwlwifi 0000:71:00.0: Sending Phy CFG command: 0x330018
Using "iw" command I printed the supported capabilities (see included .txt output), however there is no mention of FTM. I tried initiating FTM request from Intel AX210 that supports FTM, however without any luck.
How to enable FTM support on Intel BE200 card?
Thank you.
Mike_Intel
Hello rafixon,
  1. What is the brand and model of your system?
  2. Did you install the BE200 in your system manually as an upgrade or is it embedded in your system?
  3. Can you also provide the link of the Product Brief that you mentioned?
  4. Can you share more details about your research and why do you need to enable this feature?
Michael L.
rafixon
Hi Mike,
Thank you for the reply, please see the answers to the questions:
1. I'm using OS: Ubuntu 25.04 x86_64; Kernel: Linux 6.14.0-23-generic
2. I installed it manually as an upgrade in my Dell 14" laptop series,
3. Please find the attached datasheet, see section Technical Specification > IEEE WLAN Standard
4. I'd like to enable this feature to measure the performance of 802.11mc and 802.11az FTM ranging features for my masters thesis, as I'm doing research about wireless localisation techniques
Thank you
Mike_Intel
Hello rafixon,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello rafixon,
I sent an email regarding the update on this issue on the email address indicated in your profile. Please check your inbox.
Thank you and have a great day
Michael L.
