Wireless
8846 Discussions
Intel BE200 FTM 802.11mc/az support
rafixon
Dear Intel Support team,
I'm doing independent research for my Masters Thesis, conducting experiments on Fine Timing Measurement (FTM) protocol. According to the Intel® Wi‑Fi 7 BE200 Product Brief (ID: 761674 Date: 2024-01-11) , the adapter supports Fine Timing Measurement (FTM) based on IEEE 802.11mc and is hardware‑ready for IEEE 802.11az (Wi‑Fi Location R2). However during testing I was unable to start the FTM responder/initiator capabilities. I'm using Ubuntu 25.04 x86_64 with 6.14.0-23-generic kernel. Here is dmesg output with loaded firmware:
root@ubuntu:~$ sudo dmesg | grep iwl
[sudo] password for root:
[ 2.281403] Loading modules backported from iwlwifi
[ 2.281407] iwlwifi-stack-public:release/core96:13623:32dda3cc
[ 3.052019] iwlwifi 0000:71:00.0: enabling device (0000 -> 0002)
[ 3.140082] iwlwifi 0000:71:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[ 3.140430] iwlwifi 0000:71:00.0: PCI dev 272b/00f0, rev=0x472, rfid=0x112200
[ 3.140435] iwlwifi 0000:71:00.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
[ 3.142732] iwlwifi 0000:71:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-99.ucode failed with error -2
[ 3.144233] iwlwifi 0000:71:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-98.ucode failed with error -22
[ 3.152996] iwlwifi 0000:71:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.196
[ 3.153761] iwlwifi 0000:71:00.0: loaded firmware version 97.8049d69b.0 gl-c0-fm-c0-97.ucode op_mode iwlmld
[ 3.942191] iwlwifi 0000:71:00.0: Detected RF FM, rfid=0x112200
[ 3.943380] iwlwifi 0000:71:00.0: loaded PNVM version 8af7618d
[ 3.964249] iwlwifi 0000:71:00.0: Sending Phy CFG command: 0x330018
[ 4.062866] iwlwifi 0000:71:00.0: base HW address: 5c:b4:7e:35:24:4c
[ 4.142824] iwlwifi 0000:71:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[ 4.149301] iwlwifi 0000:71:00.0 wlp113s0f0: renamed from wlan0
[ 5.733865] iwlwifi 0000:71:00.0: Sending Phy CFG command: 0x330018
Could you please support me on how to enable FTM on Intel BE200 network card? What firmware/software combination I should try?
Thank you in advance,
BR,
Rafal M
Mike_Intel
Hello rafixon,
Upon checking, this thread is a duplicate of this thread: Intel BE200 802.11mc FTM support - Intel Community
To avoid confusion and duplicate request. I will close this thread to focus on the original thread that you created.
Michael L.
