Wireless
8060 Discussions
Intel BE200 and Ideapad S340
andrewtung
I upgraded my network card on my ideapad s340. I noticed that when I leave the bluetooth component on the m.2 card enabled, when I restart my computer my WIFI and bluetooth will show error code 43.
Sometimes if I restart; both the wifi and bluetooth will work again. Sometimes I have to uninstall the device, reinstall the drivers and both Wifi and bluetooth will work. Sometimes I will restart and it will both work fine, but usually on the next restart both will show error code 43 again.
I was going crazy until I read a twitter/reddit post where someone suggested disabling the bluetooth device.
Once I disabled the bluetooth device, and restarted the WIFI works perfectly again. I can now restart it as much as I want and the WIFI works fine.
I have a separate USB bluetooth so this seems to be an acceptable solution in order to maintain Wifi 7. Well technically I am using it for WIFI 6E.
Is the laptop just underpowered when it comes to be BE200 ? Is it just not supplying enough reliable power to utilize the bluetooth and wifi at the same time?
Is this a driver issue that could be resolved ?
I hope this post helps anyone having issues with the BE200 and an older laptop.
