Wireless
8528 Discusiones
Intel Bluetooth: Isochronous channels and other mandatory features
drujd
Nuevo Colaborador I
8.649 Vistas
I have recently bought two Intel Bluetooth/Wi-Fi M.2 type (A+)E cards: AX200NGW and BE200NGW. AX200 is supposed to support BT5.2 ( https://www.intel.com/content/www/us/en/products/sku/189347/intel-wifi-6-ax200-gig/specifications.html ) and BE200 is supposed to support BT5.4 ( https://www.intel.com/content/www/us/en/products/sku/230078/intel-wifi-7-be200/specifications.html ).
And yet: Neither of the cards seems to support (m)any MANDATORY features that have been introduced as part of the Bluetooth Core Specification Version 5.2 ( https://www.bluetooth.com/wp-content/uploads/2020/01/Bluetooth_5.2_Feature_Overview.pdf ) or any 5.3/5.4 features in case of BE200. The most notable feature missing is LE Isochronous Channels (primarily introduced as a basis for LE Audio, but with other potential uses as well).
On Linux, I am running the latest 20240312 firmware, bluez 5.73 and the very recent 6.8 kernel. This is my btmgmt info output for BE200:
hci0:   Primary controller
        addr REDACTED version 13 manufacturer 2 class 0x000000
        supported settings: powered connectable fast-connectable discoverable bondable link-security ssp br/edr le advertising secure-conn debug-keys privacy configuration static-addr phy-configuration wide-band-speech
        current settings: bondable ssp br/edr le secure-conn
And this is for AX200 (kernel 6.7.9, other versions identical to above):
        addr REDACTED version 11 manufacturer 2 class 0x000104
        current settings: powered ssp br/edr le secure-conn
In both cases, 'cis-central', 'cis-peripheral' (which, again, are mandatory if you claim BT5.2+ support) and other features are missing. For comparison, this is M1 Mac Mini (BT 5.0 only) running Asahi Linux - as you can see, the supported settings section is identical except for wide-band-speech (which is an optional feature):
        addr REDACTED version 9 manufacturer 15 class 0x000000
        current settings: ssp br/edr le secure-conn
What gives? This is especially jarring in case of BE200, which officially claims LE Audio / LC3 support in promotional materials: https://cdrdv2-public.intel.com/761674/761674_Intel_Wi-Fi_7_BE200_GalePeak2_Product_Brief_Rev1p1.pdf
I am not very familiar with BT stack on Windows and how to probe for individual BT features there, but neither AX200 nor BE200 seem to support LE Audio on Windows 11 either (tried both latest public update build AND the latest canary / Insider Preview). And BE200 really, REALLY should, given the advertising. In AX200's case, I understand there might be some licensing issues regarding the LC3 codec usage in Windows (while Linux shouldn't care as long as the controller has the required mandatory hw features), but it still HAS to support LE Isochronous Channels (and other features introduced in 5.2) to conform to BT 5.2 spec...
0 kudos
20 Respuestas
drujd
Nuevo Colaborador I
8.558 Vistas
I would really appreciate some kind of response. I need to know whether to return the BE200NGW card or not. Weirdly enough, its predecessor AX210 (and AX211, maybe?) seems to support isochronous channels and therefore LE Audio in Linux. It is its older (AX200) and younger (BE200) siblings that should also support that according to specs, but in terms of supported things just appear as regular 5.0 controllers (except the version numbers, which are correctly 11/13)...
H_Mlysgeek
Nuevo Colaborador I
8.529 Vistas
@drujd, Hi there....
,The situation you're describing with the Intel AX200NGW and BE200NGW cards not supporting certain Bluetooth 5.2 and 5.4 features, such as LE Isochronous Channels, is indeed perplexing, especially considering the specifications listed by Intel. These features are essential for enabling the latest Bluetooth capabilities like LE Audio.
The absence of 'cis-central' and 'cis-peripheral' settings in your btmgmt output is unusual since these are mandatory for Bluetooth 5.2+ support. It's possible that this could be due to a variety of factors, including firmware issues, driver support, or even hardware limitations.
For the AX200NGW, while it is advertised to support Bluetooth 5.2, the specific features available can depend on the implementation and support provided by the operating system and drivers. Similarly, the BE200NGW is supposed to support Bluetooth 5.4, and by extension, the features introduced in Bluetooth 5.2 and beyond, including LE Isochronous Channels.
Given that you've already updated to the latest firmware and are using recent versions of bluez and the Linux kernel, the next steps could involve:
1. Make sure all software and firmware are up to date, including the Linux kernel, bluez, and the firmware for the Bluetooth cards.2. Intel Support: Reach out to Intel support or check the Intel community forums for any known issues or updates regarding these features
2. Verify that the drivers in use are the correct versions intended to support these features. Sometimes, beta or specific OEM drivers may offer different levels of support.
3. Confirm that the hardware itself is not defective and is capable of supporting the advertised features.
On Windows, the support for Bluetooth features can also vary based on the drivers and the Bluetooth stack implementation by Microsoft. It might be worth checking for any available driver updates or support documents from Intel that address these features on Windows 11.
hope this helps
drujd
Nuevo Colaborador I
8.516 Vistas
That does not help at all. As a matter of fact, this looks almost exactly like a reply generated by (or sourced from) a ChatGPT or similar LLM. Please stop posting useless, possibly AI generated, responses.
I am running the latest versions of everything (Linux kernel, linux-firmware and bluez), there is nothing more I can do other than to wait for an update that has not even been announced. I would like someone from Intel to tell me what the hell is happening and how is this not false advertising...
RamyerM_Intel
Moderador
8.411 Vistas
Hello drujd,
We sincerely apologize that it took us sometime to respond. We want to help you with this concern. I just want to be more familiar with the system that you are using. Did you integrate the AX200 and BE200on a laptop or a custom build desktop? Please share with us the model or better yet, the SSU logs. Since you are using linux, you may download it at this link: https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html. Once you share this with us, I will proceed in coordinating this with our team so we can investigate this properly. I will be waiting for your reply.
Ramyer M.
drujd
Nuevo Colaborador I
8.400 Vistas
I have two desktop motherboards with an M.2 E slot for Wi-Fi/Bluetooth addin cards. I have, however, tested this also with a borrowed laptop. Unsurprisingly, the card behaves exactly the same in all devices, which makes sense: The Bluetooth part of the cards is just a USB device, after all...
The utility seems to correctly work only on Fedora/Red Hat, Ubuntu or SUSE Linux, not on Arch, but I managed to get some output out of the script. However, that output is probably completely useless for this specific problem since the utility does not at all list USB devices, let alone Bluetooth devices. It also seems quite outdated (for instance, it expects storage devices to be /dev/sd* or /dev/hd*, but it does not consider NVMe drives at all, hence the empty storage part in the log). Also note that you don't see the Wi-Fi part of the card as I have disabled it in BIOS (I do not care about Wi-Fi at all, only Bluetooth).
I have e-mailed the Linux Intel developer Luiz Von Dentz and apparently, the AX200 card is too old and will never support isochronous channels. That is a bummer as I thought all Bluetooth controllers claiming conformance to v5.2 spec have to support this, but I guess I was wrong... The Bluetooth Core Specification is a mess regarding what is mandatory and what is not. However, BE200 should absolutely support that, so the point still stands.
Anyway, here is the log for one of the motherboards, although I doubt its usefulness:
# SSU Scan Information
Scan Info:
     Version:"1.0.0.0"
     Scan Date:"2024/03/26"
     Scan Time:"16:53:34"
## Scanned Hardware
Computer:
          BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
          Bios Mode:"UEFI"
          Bios Version/Date:"5003,10/07/2023"
          CD or DVD:"Not Available"
          Platform Role:"Linux box 6.8.1-arch1-1-00004-g75f8697a2824-dirty #1 SMP PREEMPT_DYNAMIC Sun, 17 Mar 2024 07:57:50 +0000 x86_64 GNU/Linux"
          Processor:"AMD Ryzen 9 5950X 16-Core Processor"
          Serial Number:"System Serial Number"
          SMBIOS Version:"3.3.0"
          Sound Cards:"HDA-Intel - HDA ATI HDMI"
          Sound Cards:"HDA ATI HDMI at 0xfca24000 irq 134"
          Sound Cards:"HDA-Intel - HD-Audio Generic"
          Sound Cards:"HD-Audio Generic at 0xfce00000 irq 135"
          Sound Cards:"USB-Audio - DA"
          Sound Cards:"0d"
          System Manufacturer:"System manufacturer"
          System Model:"System Product Name"
          System Type:"x64-based PC"
          - Display
               - "Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] (rev c1) (prog-if 00 [VGA controller])"
                    Adapter RAM:"size=16G"
                    Adapter RAM:"size=256M"
                    Capabilities:"[48] Vendor Specific Information: Len=08 <?>"
                    Capabilities:"[50] Power Management version 3"
                    Capabilities:"[64] Express Legacy Endpoint, IntMsgNum 0"
                    Capabilities:"[a0] MSI: Enable+ Count=1/1 Maskable- 64bit+"
                    Capabilities:"[100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>"
                    Capabilities:"[150] Advanced Error Reporting"
                    Capabilities:"[200] Physical Resizable BAR"
                    Capabilities:"[240] Power Budgeting <?>"
                    Capabilities:"[270] Secondary PCI Express"
                    Capabilities:"[2a0] Access Control Services"
                    Capabilities:"[2d0] Process Address Space ID (PASID)"
                    Capabilities:"[320] Latency Tolerance Reporting"
                    Capabilities:"[410] Physical Layer 16.0 GT/s <?>"
                    Capabilities:"[440] Lane Margining at the Receiver"
                    Caption:"Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] (rev c1) (prog-if 00 [VGA controller])"
                    Device ID:"AMD/ATI" Radeon RX 6900 XT
                    Driver:"amdgpu"
                    Driver Path:"/lib/modules/6.8.1-arch1-1-00004-g75f8697a2824-dirty/kernel/drivers/gpu/drm/amd/amdgpu/amdgpu.ko.zst"
                    Driver Provider:"AMD linux driver team"
                    Driver Version:""
                    Flags:"bus master, fast devsel, latency 0, IRQ 136, IOMMU group 25"
                    I/O Ports:"I/O ports at f000 [size=256]"
                    Manufacturer:"Advanced Micro Devices, Inc. [AMD/ATI] [1002]"
                    Power Management Capabilities:"Power Management version 3"
                    Refresh Rate - Current:"Not Available"
                    Resolution:"Not Available"
          - Memory
               Physical Memory (Available):"26738 MB"
               Physical Memory (Installed):"32067 MB"
               Physical Memory (Total):"97347 MB"
               - "DIMM_A2"
                    Capacity:"16 GB"
                    Configured Clock Speed:"Not Available"
                    Configured Voltage:"1.2 V"
                    Data Width:"64 bits"
                    Form Factor:"DIMM"
                    Interleave Position:"First Position"
                    Locator:"DIMM_A2"
                    Manufacturer:"G Skill Intl"
                    Maximum Voltage:"1.2 V"
                    Minimum Voltage:"1.2 V"
                    Part Number:"4-3200C14-16GVK"
                    Serial Number:"00000000"
                    Type:"Synchronous Unbuffered (Unregistered)"
               - "DIMM_B2"
                    Capacity:"16 GB"
                    Form Factor:"DIMM"
                    Locator:"DIMM_B2"
          - Motherboard
               Product:"ROG STRIX X570-E GAMING"
               Serial Number:REDACTED
               Version:"Rev X.0x"
          - Networking
               - "Intel Corporation I211 Gigabit Network Connection (rev 03)"
                    Supports auto-negotiation:"Yes"
                    Advertised auto-negotiation:"Yes"
                    Auto-negotiation:"on"
                    Availability:"lan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500"
                    Capabilities:"[40] Power Management version 3"
                    Capabilities:"[50] MSI: Enable- Count=1/1 Maskable+ 64bit+"
                    Capabilities:"[70] MSI-X: Enable+ Count=5 Masked-"
                    Capabilities:"[a0] Express Endpoint, IntMsgNum 0"
                    Capabilities:"[100] Advanced Error Reporting"
                    Capabilities:"[140] Device Serial Number REDACTED
                    Capabilities:"[1a0] Transaction Processing Hints"
                    Caption:"Not Available"
                    Default IP Gateway:REDACTED
                    DHCP Enabled:"Yes"
                    DHCP Lease Expires:"Not Available"
                    DHCP Lease Obtained:"Not Available"
                    DHCP Server:"Not Available"
                    Driver:"igb"
                    Driver Path:"/lib/modules/6.8.1-arch1-1-00004-g75f8697a2824-dirty/kernel/drivers/net/ethernet/intel/igb/igb.ko.zst"
                    Driver Provider:"Intel Corporation, <e1000-devel@lists.sourceforge.net>"
                    Driver Version:""
                    Duplex:"Full"
                    Firmware Version:"0. 6-1"
                    Interface:"lan0"
                    I/O Ports:"Not Available"
                    IP Address:REDACTED
                    IP Subnet:REDACTED
                    MAC Address:REDACTED
                    Manufacturer:"Intel Corporation"
                    Net Connection ID:"Not Available"
                    Port:"Twisted Pair"
                    Power Management:"Supports Wake-on: pumbg"
                    Power Management:"Wake-on: g"
                    Speed:"1000Mb/s"
                    Supported link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
                    Advertised link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
                    Partner advertised link modes:"Not Available"
               - "Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller"
                    Availability:"lan1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500"
                    Capabilities:"[70] Express Endpoint, IntMsgNum 1"
                    Capabilities:"[b0] MSI-X: Enable+ Count=4 Masked-"
                    Capabilities:"[d0] Vital Product Data"
                    Capabilities:"[148] Virtual Channel"
                    Capabilities:"[168] Device Serial Number REDACTED"
                    Capabilities:"[178] Alternative Routing-ID Interpretation (ARI)"
                    Capabilities:"[188] Single Root I/O Virtualization (SR-IOV)"
                    Capabilities:"[1c8] Transaction Processing Hints"
                    Capabilities:"[254] Latency Tolerance Reporting"
                    Capabilities:"[25c] L1 PM Substates"
                    Capabilities:"[26c] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>"
                    Default IP Gateway:"Not Available"
                    DHCP Enabled:"Yes"
                    Driver:"r8169"
                    Driver Path:"/lib/modules/6.8.1-arch1-1-00004-g75f8697a2824-dirty/kernel/drivers/net/ethernet/realtek/r8169.ko.zst"
                    Driver Provider:"Realtek and the Linux r8169 crew <netdev@vger.kernel.org>"
                    Driver Version:""
                    Duplex:"Unknown! (255)"
                    Firmware Version:"rtl8125a-3_0.0.1 08/24/19"
                    Interface:"lan1"
                    IP Address:"Not Available"
                    IP Subnet:"Not Available"
                    Manufacturer:"Realtek Semiconductor Co., Ltd."
                    Port:"Twisted Pair"
                    Power Management:"Wake-on: d"
                    Speed:"Unknown!"
          - Operating System
               Boot Device:"/dev/mapper/box-root"
               Last Reset:"up  3:30,  1 user,  load average: 0,33, 0,34, 0,47"
               Locale:"cs_CZ"
               OS Manufacturer:"Arch Linux \r (\l)"
               OS Name:"Arch Linux \r (\l)"
               Page File:"/dev/nvme0n1p2"
               Page File Space (Available):"66846716"
               Page File Space (Used):"0"
               Physical Memory (Available):"26746 MB"
               Version:"6.8.1-arch1-1-00004-g75f8697a2824-dirty GNU/Linux"
               Virtual Memory (Available):"66846716"
               Virtual Memory (Total):"32836924"
          - Processor
               - "AMD Ryzen 9 5950X 16-Core Processor"
                    Architecture:"x86_64"
                    Available:"Offline"
                    Byte Order:"Little Endian"
                    Cache Size:"512 KB"
                    Caption:"AMD Ryzen 9 5950X 16-Core Processor"
                    - Characteristics
                         Enhanced Virtualization
                         Execute Protection
                         Hardware Thread
                         Multi-Core
                         Power/Performance Control
                         64-bit capable
                    CPU Speed (Minimum):"3635.608"
                    CPU Speed (Maximum):"5050 MHz"
                    Current Voltage:"1.1 V"
                    External Clock:"100 MHz"
                    Family:"Zen"
                    - Flags
                         "APIC (On-chip APIC hardware supported)"
                         "CLFSH (CLFLUSH instruction supported)"
                         "CMOV (Conditional move instruction supported)"
                         "CX8 (CMPXCHG8 instruction supported)"
                         "DE (Debugging extension)"
                         "FPU (Floating-point unit on-chip)"
                         "FXSR (FXSAVE and FXSTOR instructions supported)"
                         "HTT (Multi-threading)"
                         "MCA (Machine check architecture)"
                         "MCE (Machine check exception)"
                         "MMX (MMX technology supported)"
                         "MSR (Model specific registers)"
                         "MTRR (Memory type range registers)"
                         "PAE (Physical address extension)"
                         "PAT (Page attribute table)"
                         "PGE (Page global enable)"
                         "PSE (Page size extension)"
                         "PSE-36 (36-bit page size extension)"
                         "SEP (Fast system call)"
                         "SSE (Streaming SIMD extensions)"
                         "SSE2 (Streaming SIMD extensions 2)"
                         "TSC (Time stamp counter)"
                         "VME (Virtual mode extension)"
                    ID:"10 0F A2 00 FF FB 8B 17"
                    Level 1 Cache:"512 KiB (16 instances)"
                    Level 2 Cache:"8 MiB (16 instances)"
                    Level 3 Cache:"fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local user_shstk clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip pku ospke vaes vpclmulqdq rdpid overflow_recov succor smca fsrm debug_swap
64 MiB (2 instances)"
                    Load:"load average: 0,33, 0,34, 0,47"
                    Manufacturer:"Advanced Micro Devices, Inc."
                    Model:"33"
                    Name:"AMD Ryzen 9 5950X 16-Core Processor            "
                    Number of Cores:"16"
                    Number of Cores - Enabled:"16"
                    Part Number:"Not Available"
                    Socket Designation:"AM4"
                    Status:"Populated, Enabled"
                    Version:"AMD Ryzen 9 5950X 16-Core Processor            "
                    Voltage:"1.1 V"
                    Virtualization:"Not Available"
          - Storage
drujd
Nuevo Colaborador I
8.392 Vistas
So this new firmware (currently only in linux-firmware main/master) finally adds support for isochronous channels on BE200: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/commit/?id=d3cc8b9b304af1671d47726f77177c28067d5c04
Should be part of the next linux-firmware release.. Hurray!
RamyerM_Intel
Moderador
8.310 Vistas
Hello drujd
I've encountered an issue accessing the link provided, resulting in a 403 Forbidden error. Could you please share the specific details contained within the link? This information would be invaluable for our records. We greatly appreciate your cooperation and the information you have provided thus far.
Ramyer M.
drujd
Nuevo Colaborador I
8.306 Vistas
Which link do you mean? I posted several and all of them still seem to work for me (just one has an expired certificate problem, but still works past the warning).
Also note that LE Audio is STILL not working on any platform, either the new firmware or linux drivers are still broken:
https://github.com/bluez/bluez/issues/793
Same for Windows: https://community.intel.com/t5/Wireless/Intel-BE200-Status-of-LE-Audio-support-on-Windows-11/m-p/1583964
An advertised feature just doesn't work, regardless of OS.
RamyerM_Intel
Moderador
8.212 Vistas
Hello drujd,
Thank you for responding back to my post. The link that I was referring to about the 403 forbidden error is this link: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/commit/?id=d3cc8b9b304af1671d47726f77177c28067d5c04. Since you mention that you are still encountering the issue with the LE Audio. I will proceed in coordinating this back with our team and keep this thread posted for updates.
Ramyer M.
drujd
Nuevo Colaborador I
8.196 Vistas
That link leads to Linux kernel web page (specifically to the web interface for its linux-firmware git repository). If that doesn't work due to 403, that's certainly weird, either blocked by your firewall or your IP (range) is blocked on the other side for some reason - this is public.
Anyway, the link leads to a linux-firmware git commit containing the firmware update for the bluetooth part of BE200:
Intel Bluetooth: Update firmware file for Intel Bluetooth BE200
This patch updates the firmware file for Intel Bluetooth BE200
Also it is known as Intel Gale Peak2 (GaP2).
FW Build: REL53617
Release Version: 23.40.0.2
FSEQ: 0.0.4.157
Signed-off-by: Kiran K <kiran.k@intel.com>
Unfortunately, as already stated above, it still does not seem to work correctly - neither in Linux ( https://github.com/bluez/bluez/issues/793 ), nor on Windows ( https://community.intel.com/t5/Wireless/Intel-BE200-Status-of-LE-Audio-support-on-Windows-11/m-p/1583964 )
RamyerM_Intel
Moderador
8.035 Vistas
Hello drujd,
Thank you for patiently waiting and for sharing this information. Upon coordinating with my team, we have additional questions so we can further investigate this for you.
Could you please provide a complete 'dmesg' log? Additionally, it would be helpful to know if this issue is occurring exclusively with Bluetooth Low Energy (LE) devices. We would also like to inquire whether a standard Bluetooth mouse was able to successfully connect to the ROG STRIX X570-E GAMING motherboard equipped with an AX200NGW before it was replaced with the BE200NGW. This information will aid in diagnosing the connectivity issues more accurately. I will be waiting for your reply.
Ramyer M.
drujd
Nuevo Colaborador I
8.014 Vistas
Just to reiterate: On the Linux side of things, I am trying to work it out on GitHub bluez repository with your very own Linux Bluetooth stack developer Luiz Augusto von Dentz: https://github.com/bluez/bluez/issues/793
Here, on these forums, I am much more interested in actually resolving this issue for Windows as there does not seem to be any better channel for that. Could we maybe move to the Windows-specific thread? https://community.intel.com/t5/Wireless/Intel-BE200-Status-of-LE-Audio-support-on-Windows-11/m-p/1587602
So far, on that thread I've only got a response from what appears to be an Intel bot... COME ON, you are supposed to be better than this (I guess the keyword "Samsung laptop" caused that automated reply)!!! So maybe we can focus on Windows from now on? With all due respect, I have more confidence in an actual Linux kernel Bluetooth stack developer to help me eventually resolve this problem on Linux.
"Additionally, it would be helpful to know if this issue is occurring exclusively with Bluetooth Low Energy (LE) devices."
What kind of question is that? I am sorry, but this is a completely nonsensical question given the context. The issue is LE Audio support! So of course it occurs only in LE devices - LE Audio does not work on classic BT stack (the old A2DP standard does).
"We would also like to inquire whether a standard Bluetooth mouse was able to successfully connect to the ROG STRIX X570-E GAMING motherboard equipped with an AX200NGW before it was replaced with the BE200NGW."
Yes, of course, BT mice/keyboards/controllers worked with the original card and still work with the new one. Both BR/EDR/classic stack and LE devices work (before & after upgrade) perfectly fine. It's LE Audio functionality that is missing.
RamyerM_Intel
Moderador
7.828 Vistas
Hello drujd,
I can assure you that I am not a bot and I am tailoring my messages based on your concern as we want to help you with the missing LE Audio functionality.
I would like to thank you for answering our question and I can assure you that we are working diligently to figuring out a solution for this missing feature in your system. For now, I will be coordinating this back with our team. I promise to get back to you as soon as possible.
Thank you for your patience and cooperation.
Ramyer M.
RamyerM_Intel
Moderador
7.140 Vistas
Hello drujd,
Thank you for patiently waiting. Upon coordinating with our team , we want to let you know that the feature “LE isochronous channels” is optional in Bluetooth 5.2 and beyond. While the Intel Wi-Fi 7 BE200 product has enabled certain LE Audio capabilities in the latest kernel (6.9+) and firmware, the implementation of the LE audio and Isochronous channels feature depend on the readiness and compatibility of several components, such as integration into the Linux OS, BlueZ and PipeWire and Codec support. As such, we highly recommend consulting with the Linux Distros and other relevant resources for further information.
Ramyer M.
drujd
Nuevo Colaborador I
7.132 Vistas
What about Windows?!
I have already stated that (here on these forums) I care about Windows support as I am trying to resolve Linux-specific issues on GitHub with people that actually understand Linux BT stack. How can a product specifically claiming to support LE Audio in Intel marketing materials still have no working LE Audio in Windows 11 almost 9 months after release?
When will Intel Bluetooth controllers (that support isochronous channels - and especially those that specifically claim LE Audio support, such as BE200) support LE Audio on Windows?
Just to be clear, I will repeat myself once again:
BE200 claims to support LE Audio and LE Audio functionality is already supported on Windows 11 (in very specific configurations, like some Samsung laptops). When will Intel either stop falsely advertising BE200 as supporting LE Audio or actually get LE Audio working on Windows 11?
NormanS_Intel
Moderador
6.991 Vistas
Hello drujd,
Thank you for your response and please be aware that while our support for self-integrated wireless cards is somewhat limited, we are committed to providing you with the best assistance possible. Your collaboration with the GitHub community is noted, and we are actively looking into the Windows-related concerns you've raised. Rest assured, any developments will be promptly communicated in this discussion thread.
Norman S.
drujd
Nuevo Colaborador I
6.966 Vistas
As far as I can tell it makes no difference whether the AX210/211 or BE200/202 cards are self-integrated or not. LE Audio in Windows does not work regardless - even in laptops or motherboards that came with these Intel cards integrated.
RamyerM_Intel
Moderador
6.879 Vistas
Hello drujd,
Upon coordinating with our team we want to set your expectation that we have limited support of self-integrating wireless card into PC hardware. Bluetooth LE Audio features depend on the readiness and compatibility of several components to be supported by Windows* OS before they can be used at a system level.
For this reason, we highly suggest to consult with Microsoft for information on Windows 11* support and to check with your OEM/POP for the latest BIOS and chipset update to ensure the system is upgradable and compatible with the Intel Wi-Fi 7 module. There may be a compatibility issue after self-integrating the Intel wireless Wi-Fi 7 card on this AMD system, and the compatibility and limitation depend on the computer manufacturer's design.
Ramyer M.
drujd
Nuevo Colaborador I
6.873 Vistas
On WHICH components does it depend, then? It IS starting to work in Linux (although with many problems and bugs), so clearly all that is needed (except fully working firmware/drivers/bluez stack, I guess) is there.
Give me an example of an Intel-powered system (desktop or laptop) other than Galaxy Book 4 (which is AX200/210-based, AFAIK) that actually supports LE Audio, please. I do not care about the Wi-Fi 7 part at all and have it disabled, I only care about the (internally USB-connected) Bluetooth part. There are forums/Reddit threads with people on the internet that never self-integrated their cards, have a supporting Intel chipset and still no LE Audio...
RamyerM_Intel
Moderador
6.813 Vistas
Hello drujd,
The support for LE Audio in Intel-powered systems depends on a combination of hardware and software components. The hardware component is the Bluetooth chipset. On the software side, the operating system needs to have the appropriate drivers and support for the Bluetooth 5.2 standard, including its LE Audio features. This includes the firmware, drivers, and the Bluetooth protocol stack, such as BlueZ for Linux.
As an example of an Intel-powered system that supports LE Audio, this document mentions that select Intel Evo laptops with Intel Wi-Fi 6E (Gig+) and Bluetooth® 5.3 offer support for Bluetooth LE Audio. It's important to note that even if the hardware supports LE Audio, the software stack must also be compatible and fully functional, which can be a challenge in Linux due to the variety of distributions and kernel versions or Windows.
For the most accurate and up-to-date information, it would be best to consult with the manufacturers of the Intel-powered systems you're interested in. They can provide detailed information about which of their systems support LE Audio and under what conditions or configurations.
Ramyer M.
Responder
