Wireless
8705 Discussions
Intel Bluetooth service view has stopped working - Intel 6230 ProSet
When I try and connect to a bluetooth device, I receive this windows error: Intel Bluetooth service view has stopped working
In an attempt to troubleshoot this problem, I try and repair Intel(R) PROSet/Wireless Software for Bluetooth(R) Technology from Programs and features, the install fails and this error appears in the event log.
Product: Intel(R) PROSet/Wireless Software for Bluetooth(R) Technology -- Error 1920. Service 'Bluetooth Device Monitor' (Bluetooth Device Monitor) failed to start. Verify that you have sufficient privileges to start system services.
I have tried to download the latest drivers from Dell website, however it throws an error.
When i check services.msc , I cannot find a service called "Bluetooth Device Monitor"
Please help as I have been trying to troubleshoot for past 3 hrs
I had this problem for a long time, starting back when I got my Dell XPS laptop in April. I started researching it shortly after I got the computer, but gave up after a while. I started looking again when I went to update my drivers yesterday, and thanks to a few great folks, I FINALLY got everything working how it should be again...
Basically the issue is that in the folder C:\Program Files (x86)\Intel\Bluetooth, there should be a file called "devmonsrv.exe." For some reason, a lot of virus scanners pick this up as malicious and remove the file. Apparently, this is the missing file that causes A LOT of problems, namely the "Intel Bluetooth Service View Has Stopped Working" error, as well as the issue when trying to update drivers and the issue when trying to repair the installation. Your post covers the EXACT same error messages and problems that I had with my Intel Centrino Card, so this solution should hopefully work for you too. This is the exact order I did things in order for them to work:
1. Check the C:\Program Files (x86)\Intel\Bluetooth directory (this is the default location) to make sure that the "devmonsrv.exe" file is, in fact, missing
2. Turn off your real-time scanning on your antivirus software. I'm not sure if its totally necessary, but I think its a good idea in case it just deletes the file like it did in the first place, which is how the problem originated. I have McAfee, but I know other AV programs had this same issue as well.
3. Go to the following link and download the "devmonsrv.rar" file (it is on page 2) and extract it to get the actual "devmonsrv.exe" file (and while you're at the link, check out both pages for a deeper explanation of the problem):
http://forum.notebookreview.com/networking-wireless/568924-dell-xps-15-laptop-bluetooth-nokia-mobile.html http://forum.notebookreview.com/networking-wireless/568924-dell-xps-15-laptop-bluetooth-nokia-mobile.html
4. Next I copied and pasted the "devmonsrv.exe" file into my C:\Program Files (x86)\Intel\Bluetooth directory
STEPS 5-7 MAY BE ABLE TO BE DONE INTERCHANGABLY, AND ITS POSSIBLE THAT IT MAY WORK BY SKIPPING STEP 5 OR 6, BUT THIS IS THE WAY I DID IT WHEN IT CORRECTLY FIXED THE PROBLEM:
5. I paired the devices and tested to ensure that I was able to pick up on the "Bluetooth Services" for my Phone (this is where I was previously received the "Intel Bluetooth Service View Has Stopped Working" error, so I knew it was a good sign when it didn't come up this time). I was able to file transfer now and had access to the picture, sound, and video directories of my phone.
6. Choose the repair option on your Bluetooth installation again, as you had done in your problem statement. This time, it shouldn't give you the same error, and at the end should ask you to restart the computer. Do so...
7. Download and install the latest Bluetooth driver for your machine. For some reason, I think I had some sort of small error during this operation, but at the end it asked me to restart my computer again, so I did.
8. Once my computer was restarted, I tried to install the new driver again to make sure it actually installed (because I had gotten the error) and this time when I tried to install, it gave me a different screen (because the new driver had already been installed) with two options "Repair" and I think "Remove" (could have been "Change" though). THIS STEP IS TO MAKE ENSURE THAT THE DRIVER INSTALLED CORRECTLY.
9. Once I made sure that the driver was installed correctly, and that all the functionality worked, I turned my AV Software Real-Time Scanning back on. The "devmonsrv.exe" file was still there, everything was functioning properly, and the driver was updated
This is what fixed the problem for me, so I hope it works for you too. Please let me know if all or part of this solution was helpful in solving this problem, because I had this problem for months and it drove me nuts!!!! Good luck!!! :-)
I managed to solve the same problem. LB601 headphones refused to work on bluetooth.
There was an error intel bluetooth service
I have included all of the services
Bluetooth Media Service
Bluetooth OBEX Service
Then initiated the launch of Intel ® Centrino ® Bluetooth 3.0 + High Speed Service
BTHSSecurityMgr
Reboot and PROFIT
All works!
BTW but before that I downloaded from Intel http://downloadmirror.intel.com/22116/eng/Wireless_15.3.1_Ds64.exe http://downloadmirror.intel.com/22116/eng/Wireless_15.3.1_Ds64.exe
PJoha7
Hi StrongerThanAll528,
The link to download the "devmons" file, does it work regardless og brand, or only for Dell?
Per
PJoha7
Hi Pavel,
I have the same problem.
Can you explain in more detail how you proceeded to do this:
"I have included all of the services
BTHSSecurityMgr"
Per
